查看: 3146|回复: 2
ad7705驱动子程序 项目上实践过得
ID:144296 发表于 2017-12-3 12:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "AD7705.h"
功能:延时
参数:循环次数
返回:无
void adc_delay(unsigned char NUM)
  for(;NUM>0;NUM--);
功能:写入AD芯片一个字节
参数:要写入的命令或参数
返回:无
void write_adc_byte(unsigned char chr)
unsigned char i;
for(i=0;i<8;i++)
  ADC_CLK= 0;
  chr=chr<<1;
  ADC_DI= CY;
  ADC_CLK= 1;
ADC_CLK = 1;
功能:从AD芯片读取一个字(16位)
参数:无
返回:读取的字(16位)
unsigned int read_adc_word()
unsigned char i;
unsigned int coder = 0;
for(i=0;i<16;i++)
  ADC_CLK = 0;
  coder = coder<<1;
  if(ADC_DO)coder+=1;
  ADC_CLK = 1;
ADC_CLK = 1;
return(coder);
功能:AD芯片复位
参数:无
返回:无
void adc_rest()
unsigned char i,j;
ADC_DI  = 1;
ADC_CLK = 1;
ADC1_CS = 1;
// ADC2_CS = 1;
ADC_RESET = 0;
for(i=300;i>0;i--)
for(j=300;j>0;j--);
ADC_RESET = 1;
功能:AD芯片初始化
参数:calmode      工作模式选择(如:ADC_SELF  ……)
      gainsetting  输入增益选择(如:ADC_GAIN_128  ……)
      operation    单极性/双极性(如:ADC_BIPOLAR  ……)
      rate         输出更新率(如:ADC_50  ……)
返回:无
void adc1_init(unsigned char calmode, unsigned char gainsetting, unsigned char operation, unsigned char rate)
ADC1_CS = 0;
write_adc_byte(0xFF);
ADC1_CS = 1;
adc_delay(100);
ADC1_CS = 0;
write_adc_byte( 0x20 );//
ADC1_CS = 1;
adc_delay(100);
ADC1_CS = 0;
write_adc_byte( rate );//
ADC1_CS = 1;
adc_delay(100);
ADC1_CS = 0;
   write_adc_byte( 0x10 );//
   ADC1_CS = 1;
adc_delay(100);
ADC1_CS = 0;
write_adc_byte( calmode|gainsetting|operation);//
ADC1_CS = 1;
adc_delay(100);
功能:读取AD转换码
参数:通道号   如:1、2
返回:读取的AD转换结果(如果等于零表示正忙)
unsigned int adc1_read_value(unsigned char ch)
unsigned int  value;
if(!ADC1_DRDY)
  ADC1_CS = 0;
  if(ch == 1)
         write_adc_byte(0x38);//
     else if(ch == 2)
         write_adc_byte(0x39);//
  else    {ADC1_CS = 1;return 0;}
  ADC1_CS = 1;
  adc_delay(1);
  ADC1_CS = 0;
  value = read_adc_word();
  ADC1_CS = 1;
  return value;
  return 0;
收藏收藏2 分享淘帖 顶 踩
ID:511272 发表于 2019-8-4 10:43 | 只看该作者
你好,能发一下头文件吗,我想看看初始化是怎么定义的
功能:AD芯片初始化
返回:无
ID:511272 发表于 2019-8-4 15:43 | 只看该作者
感谢楼主,调出来了
