查看: 2748|回复: 4
rn8302
ID:329383 发表于 2018-5-14 10:13 | 显示全部楼层 |阅读模式
#ifndef __RN8302_H_
#define __RN8302_H_
#include "config.h"
#define STDUn                         220
#define STDIb                         5
#define CalVoltate 44000000         //220V电压下校表
#define CalCurrent 50000000         //5A 电流下校表
#define STDP               262260437        //标准的有功功率
#define STDP_05L         131130218        //标准的有功功率
#define RN8302_fosc         8000000        //晶振频率 标准 8192000
#define RN8302_ENABLE                      GPIO_ResetBits(GPIOA,GPIO_Pin_15)
#define RN8302_DISABLE              GPIO_SetBits(GPIOA,GPIO_Pin_15)
#define PinWrite_ADSCLK_1 GPIO_SetBits(GPIOB, GPIO_Pin_3)
#define PinWrite_ADSCLK_0 GPIO_ResetBits(GPIOB, GPIO_Pin_3)
#define PinWrite_ADSDI_1 GPIO_SetBits(GPIOB, GPIO_Pin_4)
#define PinWrite_ADSDI_0 GPIO_ResetBits(GPIOB, GPIO_Pin_4)
#define PinWrite_ADSDO_1 GPIO_SetBits(GPIOB, GPIO_Pin_5)
#define PinWrite_ADSDO_0 GPIO_ResetBits(GPIOB, GPIO_Pin_5)
#define PinRead_ADSDI GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_4)
#define RO  0x00
#define RW  0x01
#define bank0 0x00
#define bank1 0x01
#define bank2 0x02
#define bank3 0x03
#define bank4 0x04
#define WRENABLE           0xE5
#define WRDISABLE           0xDC
#define SAMPTEMPCLR         0x10                //50Hz采样,缓冲区清零
#define CLREMMIFH           0xFF                //清采样缓冲中断标志
#define CLREMMIFL           0xFF
#define SAMPSTART         0x20
#define SOFTRST           0xFA
#define EMMOD                   0xA2                //EMM模式
#define SLPMOD                 0x18
#define NVM1MOD                 0xE1
#define NVM2MOD                 0x5C
#define CHANNELEN        0xFF
#define ADCGAINVAL        0x00                //ADC 通道增益设定。电压通道1倍增益。
//#define HF6400                0x031F                        //6400常数
#define EGYRDMODVAL 0x40                //视在电能读取后清零。
#define LNWIREMODE         0x00        //三相四线接线模式。
#define LLWIREMODE         0x33        //三相三线接线模式。
#define GAIN_1  0x00
#define GAIN_2  0x01
#define GAIN_4  0x10
#define GAIN_8  0x11
//#define HFCONST1 0x39
//#define HFCONST0 0x07                        //测试常数
//#define HFCONST1 0xCE
typedef struct
        unsigned char bank;
        unsigned char addr;
        unsigned char bytenum;
  unsigned char rw;
  unsigned int  data;
}RegStructure;
ID:402638 发表于 2018-9-26 12:50 | 显示全部楼层
非常感谢分享,,可惜我没看懂。。
ID:430729 发表于 2018-11-21 18:15 | 显示全部楼层
这个有完整的源码吗
ID:388371 发表于 2019-12-9 16:58 | 显示全部楼层
不错不错
ID:577511 发表于 2020-3-30 20:41 | 显示全部楼层
可以给完整的代码吗
