查看: 2750|回复: 1
自己在51单片机开发板上弄得七音电子琴程序
ID:452204 发表于 2019-6-6 16:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大致功能为在一定的按键时间内记一次数,并且会发出音符。记录20个播放该段音乐。
  1. #include <reg52.h>
  2. #define uint unsigned int
  4. sbit dula=P2^6;
  5. sbit wela=P2^7;
  6. sbit beep=P2^3;
  7. uint a,b;
  8. uchar key,shu[20];
  9. int i=-1;
  10. uint code Freqtab[] = {
  11.      64580,64684,64777,
  12.      64820,64898,64968,65030};
  13. uchar code table[]={
  14. 0x00,0x06,0x5b,0x4f,
  15. 0x66,0x6d,0x7d,0x07,
  16. 0x7f,0x6f,0x77,0x7c,
  17. 0x39,0x5e,0x79,0x71};
  18. void delay(uint x)
  19. {
  20.         uint i,j;
  21.         for(i=x;i>0;i--)
  22.                 for(j=110;j>0;j--);
  23. }
  24. void send(uchar x)
  25. {
  26.         SBUF=x;
  27.         while(!TI);
  28.         ;
  29.         TI=0;
  30. }
  31. void display(uchar num)
  32. {
  33.         dula=1;
  34.         P0=table[num];
  35.         dula=0;
  36.         P0=0xff;
  37.         wela=1;
  38.         P0=0xfe;
  39.         wela=0;
  40.         delay(5);
  41. }
  42. uchar matrixkeyscan()
  43. {
  44.         uchar temp;
  45.
  46.         P3=0xfb;
  47.     temp=P3;
  48.     temp=temp&0xf0;
  49.     if(temp!=0xf0)
  50.     {
  51.           delay(10);
  52.           temp=P3;
  53.           temp=temp&0xf0;
  54.       if(temp!=0xf0)
  55.       {
  56.         temp=P3;
  57.         switch(temp)
  58.         {
  59.           case 0xeb:
  60.                           key=1;
  61.
  62.      //     beep=1;
  63.                   a=Freqtab[0]/256;
  64.                   b=Freqtab[0]%256;
  65.                         TR0=1;                  i++;
  66.                   shu[i]=1;
  67.                   delay(150);
  68.                           send(key);
  69.
  70.                break;
  71.           case 0xdb:
  72.                           key=2;
  73.
  74.         //  beep=1;
  75.                   a=Freqtab[1]/256;
  76.                   b=Freqtab[1]%256;
  77.                   TR0=1;                  i++;
  78.                   shu[i]=2;
  79.                   delay(150);
  80.                           send(key);
  81.
  82.                break;
  83.           case 0xbb:
  84.                           key=3;
  85.
  86.           TR0=1;
  87.                 //  beep=1;
  88.                   a=Freqtab[2]/256;
  89.                   b=Freqtab[2]%256;                  i++;
  90.                   shu[i]=3;
  91.                   delay(150);
  92.                           send(key);
  93.
  94.                                 break;
  95.           case 0x7b:
  96.                           key=4;
  97.
  98.        //   beep=1;
  99.                   a=Freqtab[3]/256;
  100.                   b=Freqtab[3]%256;
  101.                  TR0=1;                  i++;
  102.                   shu[i]=4;
  103.                  delay(150);
  104.                           send(key);
  105.
  106.                break;
  107.          }
  108.         display(key);
  109.       }
  110.     }
  111.         /*        switch(i)
  112.         {
  113.                 case 0:shu[i]=0;break;
  114.                 case 1:shu[i]=1;break;
  115.                 case 2:shu[i]=2;break;
  116.                 case 3:shu[i]=3;break;
  117.                 case 4:shu[i]=4;break;
  118.                 case 5:shu[i]=5;break;
  119.                 case 6:shu[i]=6;break;
  120.         }
  121.         */
  122.
  123.         P3=0xf7;
  124.     temp=P3;
  125.     temp=temp&0xf0;
  126.     if(temp!=0xf0)
  127.     {
  128.           delay(10);
  129.       temp=P3;
  130.       temp=temp&0xf0;
  131.       if(temp!=0xf0)
  132.       {
  133.         temp=P3;
  134.         switch(temp)
  135.         {
  136.           case 0xe7:
  137.                           key=5;
  138.
  139.       //    beep=1;
  140.
  141.                   a=Freqtab[4]/256;
  142.                   b=Freqtab[4]%256;
  143.                   TR0=1;
  144.                   shu[i]=5;
  145.                   delay(150);
  146.                         i++;
  147.                           send(key);
  148.
  149.                break;
  150.           case 0xd7:
  151.                           key=6;
  152.
  153.       //    beep=1;
  154.
  155.                   a=Freqtab[5]/256;
  156.                   b=Freqtab[5]%256;
  157.                   TR0=1;                  i++;
  158.                   shu[i]=6;
  159.                   delay(150);
  160.                           send(key);
  161.
  162.                break;
  163.           case 0xb7:
  164.                           key=7;
  165.       //    beep=1;
  166.
  167.                   a=Freqtab[6]/256;
  168.                   b=Freqtab[6]%256;
  169.                   TR0=1;                  i++;
  170.                   shu[i]=7;
  171.                   delay(150);
  172.                           send(key);
  173.                           break;
  174.                 /*  case 0x77:
  175.                           wela=1;
  176.                   P0=0x00;
  177.                   wela=0;
  178.                   break;*/
  179.          }
  180.          display(key);
  181.       }
  182.       }
  183.         /*        switch(i)
  184.         {
  185.                 case 0:shu[i]=0;break;
  186.                 case 1:shu[i]=1;break;
  187.                 case 2:shu[i]=2;break;
  188.                 case 3:shu[i]=3;break;
  189.                 case 4:shu[i]=4;break;
  190.                 case 5:shu[i]=5;break;
  191.                 case 6:shu[i]=6;break;
  192.         }
  193.         */
  194.           P3=0x0f;
  195.           temp=P3;
  196.           temp=temp&0xf0;
  197.           switch(temp)
  198.           {
  199.                   case 0x00:
  200.                   beep=1;
  201.                   TR0=0;
  202.                   break;
  203.           }
  204.           return key;
  205. }
  206. /*
  207. uchar keyscan()
  208. {
  209.         uchar temp;
  210.
  211.         P3=0xfe;
  212.     temp=P3;
  213.     temp=temp&0xf0;
  214.     while(temp!=0xf0)
  215.     {
  216.           delay(5);
  217.           temp=P3;
  218.           temp=temp&0xf0;
  219.       while(temp!=0xf0)
  220.       {
  221.         temp=P3;
  222.         switch(temp)
  223.         {
  224.           case 0xee:
  225.                           key=1;
  226.                break;
  227.           case 0xde:
  228.                           key=2;
  229.                break;
  230.           case 0xbe:
  231.                           key=3;
  232.                                 break;
  233.           case 0x7e:
  234.                           key=4;
  235.                break;
  236.          }
  237.                 while(temp!=0xf0)
  238.                         {
  239.                                 temp=P3;
  240.                                 temp=temp&0xf0;
  241.                         }
  242.                 }
  243.         }
  244.
  245.         P3=0xfd;
  246.         temp=P3;
  247.         temp=temp&0xf0;
  248.         while(temp!=0xf0)
  249.     {
  250.           delay(5);
  251.       temp=P3;
  252.       temp=temp&0xf0;
  253.       while(temp!=0xf0)
  254.       {
  255.         temp=P3;
  256.         switch(temp)
  257.         {
  258.           case 0xed:
  259.                           key=5;
  260.                break;
  261.           case 0xdd:
  262.                           key=6;
  263.                break;
  264.           case 0xbd:
  265.                           key=7;
  266.                break;
  267.          }
  268.                 while(temp!=0xf0)
  269.                 {
  270.                         temp=P3;
  271.                         temp=temp&0xf0;
  272.                 }
  273.       }
  274.       }
  275.           return key;
  276. }
  277. */
  278. void main()
  279. {
  280.         uint j;
  281.
  282.         TMOD |= 0x01;
  283.         EA=1;
  284.         ET0=1;
  285.
  286.         TMOD |= 0x20;
  287.         SCON=0x40;
  288.         PCON=0x00;
  289.         TH1=0xfd;
  290.         TL1=0xfd;
  291.         TR1=1;
  292.
  293. //        k=matrixkeyscan();
  294.         while(1)
  295.         {
  296.                 matrixkeyscan();
  297.                 if(i==19)
  298.                         break;
  299.         }
  300.
  301.         for(i=0;i<20;i++)
  302.         {
  303.                 j=shu[i];
  304.                 switch(j)
  305.                 {
  306.                         case 0:
  307.                         a=Freqtab[0]/256;
  308.                         b=Freqtab[0]%256;
  309.                         TR0=1;
  310.                         delay(350);
  311.                         display(j);
  312.                         TR0=0;
  313.                         delay(30);
  314.                         beep=1;
  315.                         break;
  316.
  317.                         case 1:
  318.                         a=Freqtab[1]/256;
  319.                         b=Freqtab[1]%256;
  320.                         TR0=1;
  321.                         delay(350);
  322.                         display(j);
  323.                         TR0=0;
  324.                         delay(30);
  325.                         beep=1;
  326.                         break;
  327.
  328.                         case 2:
  329.                         a=Freqtab[2]/256;
  330.                         b=Freqtab[2]%256;
  331.                         TR0=1;
  332.                         delay(350);
  333.                         display(j);
  334.                         TR0=0;
  335.                         delay(30);
  336.                         beep=1;
  337.                         break;
  338.
  339.                         case 3:
  340.                         a=Freqtab[3]/256;
  341.                         b=Freqtab[3]%256;
  342.                         TR0=1;
  343.                         delay(350);
  344.                         display(j);
  345.                         TR0=0;
  346.                         delay(30);
  347.                         beep=1;
  348.                         break;
  349.
  350.                         case 4:
  351.                         a=Freqtab[4]/256;
  352.                         b=Freqtab[4]%256;
  353.                         TR0=1;
  354.                         delay(350);
  355.                         display(j);
  356.                         TR0=0;
  357.                         delay(30);
  358.                         beep=1;
  359.                         break;
  360.
  361.                         case 5:
  362.                         a=Freqtab[5]/256;
  363.                         b=Freqtab[5]%256;
  364.                         TR0=1;
  365.                         delay(350);
  366.                         display(j);
  367.                         TR0=0;
  368.                         delay(30);
  369.                         beep=1;
  370.                         break;
  371.
  372.                         case 6:
  373.                         a=Freqtab[6]/256;
  374.                         b=Freqtab[6]%256;
  375.                         TR0=1;
  376.                         delay(350);
  377.                         display(j);
  378.                         TR0=0;
  379.                         delay(30);
  380.                         beep=1;
  381.                         break;
  382.                 }
  383.         }
  384. }
  385. void T0_time() interrupt 1
  386. {
  387.         TH0=a;
  388.         TL0=b;
  389.         beep=~beep;
  390. }
所有程序51hei提供下载:
程序.docx (17.07 KB, 下载次数: 7)
ID:1 发表于 2019-6-7 01:46 | 只看该作者
