查看: 2989|回复: 1
单片机红外测距
ID:299887 发表于 2018-4-2 15:27 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <intrins.h> //°üo¬NOP¿ÕÖ¸áîoˉêy_nop_
#include<stdio.h>
typedef unsigned char BYTE;
typedef unsigned int WORD;
typedef bit BOOL;
#define uint  unsigned int
sbit eoc=P3^0;
sbit oe =P3^1;
sbit st =P3^2;
sbit clk=P3^6;
sbit rs=P0^7;
sbit rw=P0^6;
sbit ep=P0^5;
uchar code table[]="0123456789";
uchar code tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x0,0x0};//êyÂë1ü12òõ¼¶ÏÔê¾0¡«9
uint ad_0809,a1,a2,a3;
uchar out;
void delaynms(uint x);
void display();
void ad0809();
void delayms(uint x)
        uint i,j;
        for(i=x;i>0;i--)
                for(j=110;j>0;j--);
void delay (int m)
unsigned char i,j;
for (i=0;i<m;i++)
for (j=0;j<253;j++);
BOOL lcd_bz()
  BOOL result;
  rs=0;           // ¶áÃ|DÅoÅ
  rw=1;
  ep=1;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  result = (BOOL)(P2&0x80);
  ep=0;
  result ;
lcd_wcmd (BYTE cmd)
  while (lcd_bz());
  rs=0;
  rw=0;
  ep=0;
  _nop_();
  _nop_();
  P2=cmd ;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  ep=1;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  ep=0;
lcd_pos (BYTE pos)
  lcd_wcmd (pos|0x80);
lcd_wdat (BYTE dat)
   while (lcd_bz());
  rs=1;
  rw=0;
  ep=0;
  _nop_();
  _nop_();
  P2=dat ;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  ep=1;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  ep=0;
lcd_init ()
  lcd_wcmd (0x38);
  delay (1);
  lcd_wcmd (0x0c);
  delay (1);
  lcd_wcmd (0x06);
  delay (1);
  lcd_wcmd (0x01);
  delay (1);
  lcd_init ();
  delay (10);
TMOD=0X01;
TH0=(65536-2)/256;
TL0=(65536-2)%256;
EA=1;
ET0=1;
TR0=1;
  ad0809();
  ad_0809=out;
  display();
    lcd_pos (7);
  lcd_wdat(table[a1]);
   lcd_pos (8);
lcd_wdat(table[a2]);
    lcd_pos (9);
lcd_wdat(table[a3]);
void T0_time()interrupt 1
TH0=(65536-2)/256;
TL0=(65536-2)%256;
clk=~clk;
while(x-->0)
          unsigned char k;
          for(k=10;k>0;k--);
void display()
  a1=(ad_0809*49/25)/100;  //the highest bit
  a2=(ad_0809*49/25)/10%10;
  a3=(ad_0809*49/25)%100%10;
void ad0809()
  P1=0xff;//input
  oe=0;
  st=0;
  st=1;//Çå0
  st=0;//Æô¶ˉ
  delaynms(1);
  while(!eoc);           //eocμèóúáãμÄ»°£¬ÔúÕaàïμè′yÖ±μ½eoc=1£¬½áêøÑ-»·£¬ÏòÏÂÖ′DD
  oe=1;
  out=P1;
  oe=0;
ID:673258 发表于 2019-12-25 10:33 | 显示全部楼层
有仿真图吗?仿真成功了吗?
