查看: 2159|回复: 1
基于51单片机的红外+按键密码锁
ID:588348 发表于 2019-7-22 20:29 | 显示全部楼层 |阅读模式
//包含头文件
#include <REG51.h>
#include<intrins.h>
//宏定义
#define LCM_Data  P0                  //将P0口定义为LCM_Data
#define uint  unsigned int
//1602的控制脚
sbit lcd1602_rs=P2^6;
sbit lcd1602_rw=P2^5;
sbit lcd1602_en=P2^7;
sbit Scl=P2^1;                        //24C02串行时钟
sbit Sda=P2^0;                        //24C02串行数据
sbit IRIN=P3^2;                        //红外
sbit ALAM = P3^7;                //报警
sbit LOC = P3^6;                //开锁
bit  pass=0;                        //密码正确标志
bit  ReInputEn=0;                //重置输入允许标志
bit  s3_keydown=0;                //3秒按键标志位
bit  key_disable=0;                //锁定键盘标志
unsigned char code CDIS1[13]={" Red Control "};
unsigned char code CDIS2[13]={" IR-CODE:--H "};
unsigned char IrValue[6];
unsigned char Time;
unsigned char kky;
unsigned char countt0,second;        //t0中断计数器,秒计数器
unsigned char Time;
void Delay5Ms(void);                //声明延时函数
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                                 //控盘扫描控制表
//液晶显示数据数组
unsigned char code start_line[]        = {"password:       "};
unsigned char code name[]                  = {"===Coded Lock==="};        //显示名称
unsigned char code Correct[]         = {"     correct    "};                //输入正确
unsigned char code Error[]           = {"      error     "};          //输入错误
unsigned char code codepass[]        = {"      pass      "};
unsigned char code LockOpen[]        = {"      open      "};                //OPEN
unsigned char code SetNew[]         = {"SetNewWordEnable"};
unsigned char code Input[]           = {"input:          "};                //INPUT
unsigned char code ResetOK[]         = {"ResetPasswordOK "};
unsigned char code initword[]        = {"Init password..."};
unsigned char code Er_try[]                = {"error,try again!"};
unsigned char code again[]                = {"input again     "};
unsigned char InputData[6];        //输入密码暂存区
unsigned char CurrentPassword[6]={0,0,0,0,0,0};                         //读取EEPROM密码暂存数组
unsigned char TempPassword[6];
unsigned char N=0;                                //密码输入位数记数
unsigned char ErrorCont;                        //错误次数计数
unsigned char CorrectCont;                        //正确输入计数
unsigned char ReInputCont;                         //重新输入计数
unsigned char code initpassword[6]={0,0,0,0,0,0};                        //输入管理员密码后将密码初始为000000
unsigned char code adminpassword[6]={1,3,1,4,2,0};                        //输入管理员密码后将密码初始为000000
* 函数名         : DelayMs()
* 函数功能                   : 延时
* 输入           : x
* 输出                  : 无
void DelayMs(unsigned int x)   //0.14ms误差 0us
unsigned char i;
  while(x--)
  for (i = 0; i<13; i++)
//=====================5ms延时==============================
void Delay5Ms(void)
        unsigned int TempCyc = 5552;
        while(TempCyc--);
//===================400ms延时==============================
void Delay400Ms(void)
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
//================================24C02========================================================
void mDelay(uint t) //延时
        uchar i;
           while(t--)
                   for(i=0;i<125;i++)
void Nop(void)                  //空操作
        _nop_();                  //仅作延时用一条语句大约1us
        _nop_();
        _nop_();
        _nop_();
/*****24c02程序参照24c02时序图*****/
/*起始条件*/
void Start(void)
        Sda=1;
        Scl=1;
        Nop();
        Sda=0;
        Nop();
/*停止条件*/
void Stop(void)
        Sda=0;
        Scl=1;
        Nop();
        Sda=1;
        Nop();
/*应答位*/
void Ack(void)
        Sda=0;
        Nop();
        Scl=1;
        Nop();
        Scl=0;
/*反向应答位*/
void NoAck(void)
        Sda=1;
        Nop();
        Scl=1;
        Nop();
        Scl=0;
/*发送数据子程序,Data为要求发送的数据*/
void Send(uchar Data)
           uchar BitCounter=8;
           uchar temp;
           do
                   temp=Data;                                           //将待发送数据暂存temp
                   Scl=0;
                   Nop();
                   if((temp&0x80)==0x80)                   //将读到的数据&0x80
                   Sda=1;
                   Sda=0;
                   Scl=1;
                   temp=Data<<1;                                   //数据左移
                   Data=temp;                                           //数据左移后重新赋值Data
                   BitCounter--;                                   //该变量减到0时,数据也就传送完成了
           while(BitCounter);                                   //判断是否传送完成
           Scl=0;
/*读一字节的数据,并返回该字节值*/
uchar Read(void)
    uchar temp=0;
        uchar temp1=0;
        uchar BitCounter=8;
        Sda=1;
        do
                Scl=0;
                Nop();
                Scl=1;
                Nop();
                if(Sda)                                   //数据位是否为1
                        temp=temp|0x01;           //为1 temp的最低位为1(|0x01,就是将最低位变为1)
                else                                   //如果为0
                        temp=temp&0xfe;           //temp最低位为0(&0xfe(11111110)最低位就是0)
                if(BitCounter-1)           //BitCounter减1后是否为真
                        temp1=temp<<1;           //temp左移
                        temp=temp1;
                BitCounter--;                   //BitCounter减到0时,数据就接收完了
        while(BitCounter);                   //判断是否接收完成
        return(temp);
void WrToROM(uchar Data[],uchar Address,uchar Num)
  uchar i;
  uchar *PData;
  PData=Data;
  for(i=0;i<Num;i++)
  Start();
  Send(0xa0);
  Ack();
  Send(Address+i);
  Ack();
  Send(*(PData+i));
  Ack();
  Stop();
  mDelay(20);
void RdFromROM(uchar Data[],uchar Address,uchar Num)
  uchar i;
  uchar *PData;
  PData=Data;
  for(i=0;i<Num;i++)
  Start();
  Send(0xa0);
  Ack();
  Send(Address+i);
  Ack();
  Start();
  Send(0xa1);
  Ack();
  *(PData+i)=Read();
  Scl=0;
  NoAck();
  Stop();
//=======================================LCD1602====================================================
#define yi 0x80 //LCD第一行的初始位置,因为LCD1602字符地址首位D7恒定为1(100000000=80)
#define er 0x80+0x40 //LCD第二行初始位置(因为第二行第一个字符位置地址是0x40)
//----------------延时函数,后面经常调用----------------------
void delay(uint xms)//延时函数,有参函数
        uint x,y;
        for(x=xms;x>0;x--)
         for(y=110;y>0;y--);
//--------------------------写指令---------------------------
void write_1602com(uchar com)//****液晶写入指令函数****
        lcd1602_rs=0;//数据/指令选择置为指令
        lcd1602_rw=0; //读写选择置为写
        P0=com;//送入数据
        delay(1);
        lcd1602_en=1;//拉高使能端,为制造有效的下降沿做准备
        delay(1);
        lcd1602_en=0;//en由高变低,产生下降沿,液晶执行命令
//-------------------------写数据-----------------------------
void write_1602dat(uchar dat)//***液晶写入数据函数****
        lcd1602_rs=1;//数据/指令选择置为数据
        P0=dat;//送入数据
        delay(1);
        lcd1602_en=1; //en置高电平,为制造下降沿做准备
        delay(1);
        lcd1602_en=0; //en由高变低,产生下降沿,液晶执行命令
//-------------------------初始化-------------------------
void lcd_init(void)
        write_1602com(0x38);//设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据
        write_1602com(0x0c);//开显示不显示光标
        write_1602com(0x06);//整屏不移动,光标自动右移
        write_1602com(0x01);//清显示
//==============将按键值编码为数值=========================
unsigned char coding(unsigned char m)
        unsigned char k;
        switch(m)
                case (0x11): k=1;break;
                case (0x21): k=2;break;
                case (0x41): k=3;break;
                case (0x81): k='A';break;
                case (0x12): k=4;break;
                case (0x22): k=5;break;
                case (0x42): k=6;break;
                case (0x82): k='B';break;
                case (0x14): k=7;break;
                case (0x24): k=8;break;
                case (0x44): k=9;break;
                case (0x84): k='C';break;
                case (0x18): k='*';break;
                case (0x28): k=0;break;
                case (0x48): k='#';break;
                case (0x88): k='D';break;
        return(k);
unsigned char cod_red(unsigned char m)
        unsigned char k;
        switch(m)
                case (0x16): k=0;break;
                case (0x0c): k=1;break;
                case (0x18): k=2;break;
                case (0x5e): k=3;break;
                case (0x08): k=4;break;
                case (0x1c): k=5;break;
                case (0x5a): k=6;break;
                case (0x42): k=7;break;
                case (0x52): k=8;break;
                case (0x4a): k=9;break;//数字键
                case (0x40): k='*';break;//左移一位
                case (0x43): k='#';break;//右移一位
                case (0x46): k='M';break;//时间设置
                case (0x47): k='B';break;//关掉声音
                case (0x44): k='K';break;//开锁
                case (0x07): k='E';break;//确认
                case (0x19): k='D';break;//重置密码
                case (0x45): k='A';break;                //未开发键
                case (0x15): k='V';break;
                case (0x09): k='O';break;
                case (0x0D): k='U';break;
        IrValue[2]=0x00;
        return(k);
//=====================按键检测并返回按键值===============================
unsigned char keynum(void)
        unsigned char row,col,i;
        P1=0xf0;
        if((P1&0xf0)!=0xf0)
                   Delay5Ms();
        Delay5Ms();
                   if((P1&0xf0)!=0xf0)
                    row=P1^0xf0;          //确定行线
                        i=0;
                        P1=a[i];                  //精确定位
                        while(i<4)
                                 if((P1&0xf0)!=0xf0)
                                           col=~(P1&0xff);          //确定列线
                                           break;            //已定位后提前退出
                                           i++;
                                           P1=a[i];
                        return 0;
                while((P1&0xf0)!=0xf0);
                return (row|col);                         //行线与列线组合后返回
        else return 0;                                 //无键按下时返回0
unsigned char red_num(void)
        if((IrValue[2]==0x16)||(IrValue[2]==0x0c)||(IrValue[2]==0x18)||(IrValue[2]==0x5e)||(IrValue[2]==0x08)||(IrValue[2]==0x1c)||(IrValue[2]==0x5a)||(IrValue[2]==0x42)||(IrValue[2]==0x52)||(IrValue[2]==0x4a)||(IrValue[2]==0x40)||(IrValue[2]==0x43)||(IrValue[2]==0x19))
           return IrValue[2];
//=======================一声提示音,表示有效输入========================
void OneAlam(void)
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//========================二声提示音,表示操作成功========================
void TwoAlam(void)
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//========================三声提示音,表示错误========================
void ThreeAlam(void)
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//=======================显示提示输入=========================
void DisplayChar(void)
        unsigned char i;
        if(pass==1)
                //DisplayListChar(0,1,LockOpen);
                write_1602com(er);                                   //在二行开始显示
                for(i=0;i<16;i++)
                        write_1602dat(LockOpen[i]);           //显示open 开锁成功
                if(N==0)
                        //DisplayListChar(0,1,Error);
                        write_1602com(er);
                        for(i=0;i<16;i++)
                                write_1602dat(Error[i]);        //显示错误
                        //DisplayListChar(0,1,start_line);
                        write_1602com(er);
                        for(i=0;i<16;i++)
                                write_1602dat(start_line[i]);//显示开始输入
//========================重置密码==================================================
void ResetPassword(void)
        unsigned char i;
        unsigned char j;
        if(pass==0)
                pass=0;
                DisplayChar();           //显示错误
                ThreeAlam();           //没开锁时按下重置密码报警3声
        else                                   //开锁状态下才能进行密码重置程序
            if(ReInputEn==1)   //开锁状态下,ReInputEn置1,重置密码允许
                        if(N==6)           //输入6位密码
                                ReInputCont++;                        //密码次数计数
                                if(ReInputCont==2)                //输入两次密码
                                        for(i=0;i<6;)
                                                if(TempPassword[i]==InputData[i])        //将两次输入的新密码作对比
                                                        i++;
                                                else        //如果两次的密码不同
                                                        write_1602com(er);
                                                        for(j=0;j<16;j++)
        write_1602dat(Error[j]);        //显示错误Error
                                                        ThreeAlam();                        //错误提示
                                                        pass=0;                                        //关锁
                                                        ReInputEn=0;                        //关闭重置功能,
                                                        ReInputCont=0;
                                                        DisplayChar();
                                                        break;
                                        if(i==6)
                                                //DisplayListChar(0,1,ResetOK);
                                                write_1602com(er);
                                                for(j=0;j<16;j++)
                                                        write_1602dat(ResetOK[j]);          //密码修改成功,显示
                                                TwoAlam();                                //操作成功提示
                                                 WrToROM(TempPassword,0,6);                //将新密码写入24C02存储
                                                ReInputEn=0;
                                        ReInputCont=0;
                                        CorrectCont=0;
                                        Delay400Ms();
                                                lcd_init();         //LCD初始化
        write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
        for(i=0;i<16;i++)
                write_1602dat(name[i]);//向液晶屏写开机画面
                                else                                          //输入一次密码时
                                        OneAlam();
                                        //DisplayListChar(0, 1, again);                 //显示再次输入一次
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(again[j]);                        //显示再输入一次
                                        for(i=0;i<6;i++)
                                                TempPassword[i]=InputData[i];                //将第一次输入的数据暂存起来
                        N=0;                                                //输入数据位数计数器清零
//=======================输入密码错误超过三过,报警并锁死键盘======================
void Alam_KeyUnable(void)
        P1=0x00;
                ALAM=~ALAM;                                 //蜂鸣器一直闪烁鸣响
                Delay5Ms();
//=======================取消所有操作============================================
void Cancel(void)
        unsigned char i;
        unsigned char j;
        //DisplayListChar(0, 1, start_line);
        write_1602com(er);
        for(j=0;j<16;j++)
                write_1602dat(start_line[j]);          //显示开机输入密码界面
        TwoAlam();                                //提示音
        for(i=0;i<6;i++)
                InputData[i]=0;                //将输入密码清零
                                        //关闭锁
        ALAM=1;                                        //报警关
        pass=0;                                        //密码正确标志清零
        ReInputEn=0;                        //重置输入充许标志清零
        ErrorCont=0;                        //密码错误输入次数清零
        CorrectCont=0;                        //密码正确输入次数清零
        ReInputCont=0;                        //重置密码输入次数清零
        s3_keydown=0;
        key_disable=0;                        //锁定键盘标志清零
        N=0;                                        //输入位数计数器清零
void WORK()
        LOC=1;
        Delay400Ms();
        LOC=0;
//==========================确认键,并通过相应标志位执行相应功能===============================
void Ensure(void)
        unsigned char i,j,m=150;
        RdFromROM(CurrentPassword,0,6);                                         //从24C02里读出存储密码
    if(N==6)
            if(ReInputEn==0)                                                        //重置密码功能未开启
                        for(i=0;i<6;)
                                if(CurrentPassword[i]==InputData[i])        //判断输入密码和24c02中的密码是否相同
                                        i++;        //相同一位 i就+1
                                else        //如果有密码不同
                                        ErrorCont++;                                                //错误次数++
                                        if(ErrorCont==3)                        //错误输入计数达三次时,报警并锁定键盘
                                                write_1602com(er);
                                                for(i=0;i<16;i++)
                                                do
                                                        Alam_KeyUnable(),Delay400Ms();
                                                while(m--);
                                        else                                         //错误次数小于3次时,锁死键盘3秒,然后重新可以输入
                                                TR1=1;                                //开启定时
                                                key_disable=1;                        //锁定键盘
                                                pass=0;                                        //pass位清零
                                                break;                                        //跳出
                        if(i==6)                                         //密码输入对时
                                if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
                                        WrToROM(initpassword,0,6);                                 //强制将初始密码写入24C02存储
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(initword[j]);                                //显示初始化密码
                                        TwoAlam();        //成功提示音
                                        Delay400Ms();        //延时400ms
                                        TwoAlam();        //成功提示音
                                        N=0;        //输入位数计数器清零
                                        CorrectCont++;                                        //输入正确变量++
                                        if(CorrectCont==1)                                //正确输入计数,当只有一次正确输入时,开锁
                                                write_1602com(er);
                                                for(j=0;j<16;j++)
                                                        write_1602dat(LockOpen[j]);                  //显示open开锁画面
                                                TwoAlam();                        //操作成功提示音
                                                WORK();        //开锁
                                                pass=1;        //置正确标志位
                                                TR1=1;        //开启定时
                                                for(j=0;j<6;j++)        //将输入清除
                                                        InputData[i]=0;        //开锁后将输入位清零
                                        else        //当两次正确输入时,开启重置密码功能
                                                write_1602com(er);
                                                for(j=0;j<16;j++)
                                                        write_1602dat(SetNew[j]);                                        //显示重置密码界面
                                                TwoAlam();        //操作成功提示
                                                ReInputEn=1;        //允许重置密码输入
                                                CorrectCont=0;        //正确计数器清零
                        else                        //=========================当第一次使用或忘记密码时可以用131420对其密码初始化============
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                        TwoAlam();        //成功提示音
                                        TwoAlam();        //成功提示音
                                        N=0;        //输入位数计数器清零
                                WORK();
                                else        //密码输入错误
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(Error[j]);                                 //显示错误信息
                                        ThreeAlam();        //错误提示音
                                        pass=0;
                else        //当已经开启重置密码功能时,而按下开锁键,
                        //DisplayListChar(0,1,Er_try);
                        write_1602com(er);
                        for(j=0;j<16;j++)
                                write_1602dat(Er_try[j]);                          //错误,请重新输入
        else                                   //密码没有输入到6位时,按下确认键时
                write_1602com(er);
                for(j=0;j<16;j++)
                pass=0;
        N=0;        //将输入数据计数器清零,为下一次输入作准备
//==============================红外显示函数==============================
//==============================主函数===============================
void main(void)
        unsigned char KEY,NUM,RED;
        unsigned char i,j;
        P1=0xFF;                                    //P1口复位
        IT0=1;//下降沿触发
        EX0=1;//打开中断0允许
        EA=1;        //打开总中断
        IRIN=1;//初始化端口
        TMOD=0x11;                                   //定义工作方式
        TL1=0xB0;
        TH1=0x3C;                                   //定时器赋初值
        EA=1;                                           //打开中断总开关
        ET1=1;                                           //打开中断允许开关
        TR1=0;                                           //打开定时器开关
        Delay400Ms();         //启动等待,等LCM讲入工作状态
        LOC=0;
        for(i=0;i<16;i++)
        write_1602com(er);
        for(i=0;i<16;i++)
                write_1602dat(start_line[i]);//写输入密码等待界面
        write_1602com(er+9);        //设置光标位置
        write_1602com(0x0f);        //设置光标为闪烁
        Delay5Ms(); //延时片刻(可不要)
        N=0;        //初始化数据输入位数
        while(1)                 //进入循环
                if(key_disable==1)                                                //锁定键盘标志为1时
                        Alam_KeyUnable();                                        //报警键盘锁
                        ALAM=1;        //关报警
                        RED=red_num();
                        if(RED!=0)        //当有按键按下时
                                second=0;                                                //秒清零
                        else        //没有锁定键盘时
                                NUM=cod_red(IrValue[2]);                                //根据按键的位置将其编码,编码值赋值给NUM
                                        switch(NUM)                                        //判断按键值
                                                case ('A'):        ;                                         break;
                                                case ('B'):        ;                                     break;
                                                case ('C'):
        for(i=0;i<16;i++)
        if(N>=1) N--;        OneAlam();        //按键提示音
        //DisplayOneChar(6+N,1,'*');
        for(j=N;j<16;j++)
        write_1602com(er+6+j);
        write_1602dat(' ');
        for(j=0;j<N;j++)
        write_1602com(er+6+j);                                //显示位数随输入增加而增加
        write_1602dat('*');                                        //但不显示实际数字,用*代替
        InputData[N]=N+4;
        break;                //ABC是无定义按键
                                                case ('D'): ResetPassword();                break;      //重新设置密码
                                                case ('*'): Cancel();                                break;      //取消当前输入
                                                case ('#'): Ensure();                                 break;           //确认键,
                                                default:        //如果不是功能键按下时,就是数字键按下
                                                        //DisplayListChar(0,1,Input);
                                                        if(N<6)                                                           //当输入的密码少于6位时,接受输入并保存,大于6位时则无效。
        write_1602com(er);
        for(i=0;i<16;i++)
        write_1602dat(Input[i]);                                //显示输入画面
        OneAlam();        //按键提示音
        for(j=0;j<=N;j++)
        InputData[N]=NUM;                                                //将数字键的码赋值给InputData[]数组暂存
        N++;        //密码位数加
                                                        else        //输入数据位数大于6后,忽略输入
        N=6;        //密码输入大于6位时,不接受输入
        break;
                 }         RED=0;
                KEY=keynum();                                                        //读按键的位置码
                if(KEY!=0)        //当有按键按下时
                                second=0;                                                //秒清零
                        else        //没有锁定键盘时
                                NUM=coding(KEY);                                //根据按键的位置将其编码,编码值赋值给NUM
                                        switch(NUM)                                        //判断按键值
                                                case ('C'):
        for(i=0;i<16;i++)
        for(j=N;j<16;j++)
        write_1602dat(' ');
        for(j=0;j<N;j++)
        InputData[N]=N+4;
        break;                //ABC是无定义按键
        write_1602com(er);
        for(i=0;i<16;i++)
        OneAlam();        //按键提示音
        for(j=0;j<=N;j++)
        N++;        //密码位数加
        break;
//*********************************中断服务函数**************************************
void  time1_int(void) interrupt 3                    //定时器T0
        TL1=0xB0;
        TH1=0x3C;                  //定时器重新赋初值
        //TR0=1;
        countt0++;                           //计时变量加,加1次时50ms
          if(countt0==20)                   //加到20次就是1s
                countt0=0;                   //变量清零
                second++;                   //秒加
                if(pass==1)                   //开锁状态时
                        if(second==1)                        //秒加到1s时
                                TR1=0;                                //关定时器
                                TL1=0xB0;
                                TH1=0x3C;                        //再次赋初值
                                second=0;                        //秒清零
                else                                                //不在开锁状态时
                        if(second==3)                        //秒加到3时
                                TR1=0;                                //关闭定时器
                                second=0;                        //秒清零
                                key_disable=0;                //锁定键盘清零
                                s3_keydown=0;
                                TL1=0xB0;
                                TH1=0x3C;                        //重新赋初值
                            TR1=1;                                //打开定时器
void ReadIr() interrupt 0
        unsigned char j,k;
        unsigned int err;
        Time=0,LOC=0;
        DelayMs(70);
        if(IRIN==0)                //确认是否真的接收到正确的信号
                err=1000;                                //1000*10us=10ms,超过说明接收到错误的信号
                /*当两个条件都为真是循环,如果有一个条件为假的时候跳出循环,免得程序出错的时
                侯,程序死在这里*/
                while((IRIN==0)&&(err>0))        //等待前面9ms的低电平过去
                        DelayMs(1);
                        err--;
                if(IRIN==1)                        //如果正确等到9ms低电平
                        err=500;
                        while((IRIN==1)&&(err>0))                 //等待4.5ms的起始高电平过去
                                DelayMs(1);
                                err--;
                        for(k=0;k<4;k++)                //共有4组数据
                                for(j=0;j<8;j++)        //接收一组数据
                                        err=60;
                                        while((IRIN==0)&&(err>0))//等待信号前面的560us低电平过去
//                                        while (!IRIN)
                                                DelayMs(1);
                                                err--;
                                        err=500;
                                        while((IRIN==1)&&(err>0))         //计算高电平的时间长度。
                                                DelayMs(1);//0.14ms
                                                Time++;
                                                err--;
                                                if(Time>30)
                                                        EX0=1;
                                                        return;
                                        IrValue[k]>>=1;         //k表示第几组数据
                                        if(Time>=8)                        //如果高电平出现大于565us,那么是1
                                                IrValue[k]|=0x80;
                                        Time=0;                //用完时间要重新赋值
                if(IrValue[2]!=~IrValue[3])
                        return;
密码锁3-红外+按键.zip
79.43 KB, 下载次数: 22, 下载积分: 黑币 -5
ID:1 发表于 2019-7-23 17:21 | 显示全部楼层
