查看: 4049|回复: 2
关于stc15单片机芯片定时器0改变频率和pwm的程序
50黑币
我的问题是为啥我用定时器8位自动重装初值可以改变频率,但我用16自动重装初值却改变不了频率;一下是程序;
#include"stc15f2k60s2.h"
#define  uint  unsigned int
#define  uchar  unsigned char
#define ulong unsigned long
sbit lcden=P2^7;
sbit lcdrw=P2^6;
sbit lcdrs=P2^5;
#define CCP_S0 0x10                         //P_SW1.4
#define CCP_S1 0x20                         //P_SW1.5
#define FOSC  11059200
sbit s1=P2^0;
sbit s2=P2^1;
sbit s3=P2^2;
sbit s4=P2^3;
float zhankongbi=0x80;
uchar code table1[]="zkb";
void display1();
void pwminit();
void keyscan();
ulong high=10;
void delay(uint z)
  uint i,j;
   for(i=z;i>0;i--)
    for(j=110;j>0;j--);
void pwmshe(uchar t)//这是占空比调节函数
                CCAP1H=t;
                CCAP1L=t;
void write_com(uchar com)//        液晶写命令函数
      lcdrs=0;
      lcdrw=0;
      P0=com;
      delay(5);
      lcden=1;
      delay(5);
      lcden=0;
void write_date(uchar date)//液晶写数据函数
     lcdrs=1;
     lcdrw=0;
     P0=date;
     delay(5);
     lcden=1;
     delay(5);
     lcden=0;
void init()        //初始化函数
        uchar num;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);//设置显示初始坐标
        for(num=0;num<3;num++)
                        write_date(table1[num]);
                        delay(5);
void initc()
   AUXR=0x80;          //时钟不分频,是原来51单片机的12倍;
   TMOD=0x00;;        //定时器0,为16位自动重装载定时器;
   TMOD &= ~0x04;
   TL0=(65536-FOSC/high);
   TH0=(65536-FOSC/high)>>8;
   INT_CLKO=0x01;         //时钟输出
    TR0=1;
void pwminit()   //pwm初始化
   CMOD=0x04;
   CCON=0x00;
   CL=0x00;
   CH=0x00;
   PCA_PWM1=0x00;
   CCAPM1=0x42;
   CCAP1H=0xff;
   CCAP1L=0xff;
   CR=1;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
        P6M0 = 0x00;
    P6M1 = 0x00;
        P7M0 = 0x00;
    P7M1 = 0x00;
        ACC = P_SW1;
    ACC &= ~(CCP_S0 | CCP_S1);              //CCP_S0=0 CCP_S1=0
    P_SW1 = ACC;                            //(P1.2/ECI, P1.1/CCP0, P1.0/CCP1, P3.7/CCP2)
//  ACC = P_SW1;
//  ACC &= ~(CCP_S0 | CCP_S1);              //CCP_S0=1 CCP_S1=0
//  ACC |= CCP_S0;                          //(P3.4/ECI_2, P3.5/CCP0_2, P3.6/CCP1_2, P3.7/CCP2_2)
//  P_SW1 = ACC;
//  ACC = P_SW1;
//  ACC &= ~(CCP_S0 | CCP_S1);              //CCP_S0=0 CCP_S1=1
//  ACC |= CCP_S1;                          //(P2.4/ECI_3, P2.5/CCP0_3, P2.6/CCP1_3, P2.7/CCP2_3)
//  P_SW1 = ACC;
    init();
            initc();
        pwminit();
    display1();
        while(1) //进入主程序大循环
              keyscan();
                  display1();
              pwmshe(zhankongbi);
void keyscan()
                if(s1==0)
                delay(5);
                if(s1==0)
                          while(!s1);
                    zhankongbi=zhankongbi-100;
                if(s2==0)
             delay(5);
                if(s2==0)
                                while(!s2);
                    zhankongbi=zhankongbi+10;
                        if(zhankongbi>256)
                        zhankongbi=0x80;
         if(s3==0)
      delay(5);
      if(s3==0)
        high++;
        if(high>65535)
           high=0;
        while(!s3);
   if(s4==0)
      delay(5);
      if(s4==0)
        high--;
        if(high<0)
           high=65535;
        while(!s4);
void display1(float m)
        float a=0,c=0;
        uchar b=0;
    m=zhankongbi;
    m=(float)m*100/256;
        a=m/100;
        b=(uchar)m%100/10;
        c=(uchar)m%10;
        write_com(0x84);
        write_date(a+0x30);
        write_com(0x85);
        write_date(b+0x30);
        write_com(0x86);
        write_date(c+0x30);
        write_com(0x87);
        write_date('%');
        write_com(0x83);
        write_date(':');
收藏收藏1 分享淘帖 顶 踩
ID:480680 发表于 2019-8-5 08:52 | 只看该作者
已解决
ID:213173 发表于 2019-8-5 09:08 | 只看该作者
楼主的数据类型使用有点混乱。可以参考STC官方例程
