查看: 1474|回复: 0
51单片机 99s 倒计时
ID:642805 发表于 2019-11-15 19:14 | 显示全部楼层 |阅读模式
原代码 如下:
#include   <reg52.h>
#define   uchar unsigned char
#define   uint  unsigned int
sbit    k1=P3^1;
sbit    k2=P3^0;
sbit    k3=P3^2;
sbit  led1=P2^2;
sbit  led2=P2^3;
sbit  led3=P2^4;
unsigned char code
table[]={0x3f,0x06,0x5b,0x4f,0x66,
         0x6d,0x7d,0x07,0x7f,0x6f,
         0x77,0x7c,0x39,0x5e};
uint  num;
uchar shi,ge,temp,l;
void delayms(uint xms)
    uint k,j;
for(k=xms;k>0;k--)
for(j=110;j>0;j--);
void key();
void  dip()
    led1=0;led2=0;led3=0;
    P0=table[ge];
    delayms(1);
        P0=0x00;
    led1=1;led2=0;led3=0;
    P0=table[shi];
    delayms(1);
        P0=0x00;
void timer0() interrupt 1
    TH0=(65536-50000)/256;
    TL0=(65536-50000)%256;
    num++;
    TMOD=0x01;
    EA=1;
    ET0=1;
    TR0=1;
        if(num==20)
            num=0;
            temp++;
            if(temp==100)
              temp=0;
                     key();
           shi=temp/10;
                    ge=temp%10;
               dip();
void key()
if(k1==0)
                  delayms(1);
                  if(k1==0)
                  temp=0;
                }   //清零
if(k2==0)
    ET0=0;
    TR0=0;
}        //暂停
