查看: 1390|回复: 0
循迹小车程序
ID:625141 发表于 2019-12-25 20:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <STC12C5A60S2.H>
#define INPUT P1
sbit ENA=P2^0;
sbit IN1=P2^1;
sbit IN2=P2^2;
sbit IN3=P2^3;
sbit IN4=P2^4;
sbit ENB=P2^5;
void delay(uchar z);
uchar i,j,ton1,ton2,z;
void delay(uchar z)
   uchar x,y;
      for(x=z;x>0;x--)
   for(y=200;y>0;y--);
void init()
     TMOD=0x01;
  TH0=(65536-100)/256;
  TL0=(65536-100)%256;
  EA=1;
  ET0=1;
  TR0=1;
void turn_leftgo(uchar a,uchar b)
ton1=a;
ton2=b;
IN1=1;
IN2=0; //左轮正转
IN3=1; //右轮正转
IN4=0;
void turn_leftgo1(uchar a,uchar b)
ton1=a;
ton2=b;
IN1=0;
IN2=1; //左轮倒转
IN3=1; //右轮正转
IN4=0;
void turn_leftgo2(uchar a,uchar b)
ton1=a;
ton2=b;
IN1=1;
IN2=0; //左轮正转
IN3=0; //右轮倒转
IN4=1;
void xunji()
  if(INPUT==0xC0)  //1100 0000
   turn_leftgo1(15,30);
   delay(10);
      turn_leftgo(15,20);}
    if(INPUT==0x60)  //0110 0000
      turn_leftgo1(20,30);
   delay(10);
   turn_leftgo(18,20);}
else if(INPUT==0x30) //0011 0000
   turn_leftgo(30,35);}
else if(INPUT==0x18)//0000 1100
      turn_leftgo(30,25);}
else if(INPUT==0x06) //0000 0110
  turn_leftgo2(30,15);
  delay(7);
  turn_leftgo(35,18);}
else if(INPUT==0x03) //0000 0011
  turn_leftgo2(30,10);
  delay(10);
  turn_leftgo(30,15);}
else if(INPUT==0x80) //1000 0000
  turn_leftgo1(5,20);
  delay(10);
  turn_leftgo(12,25);}
else if(INPUT==0x40) //0100 0000
  delay(10);
  turn_leftgo(13,30);}
else if(INPUT==0x20) //0010 0000
  turn_leftgo(20,30);}
else if(INPUT==0x10) //0001 0000
  turn_leftgo(30,30);}
  else if(INPUT==0x08) //0000 1000
   else if(INPUT==0x04) //0000 0100
else if(INPUT==0x02) //0000 0010
  turn_leftgo2(20,10);
     delay(10);
  turn_leftgo(30,20);}
else if(INPUT==0x01) //0000 0001
  delay(10);
  turn_leftgo(20,10);}
  else if(INPUT==0x1c) //0001 1100
{turn_leftgo(35,35);}
   else if(INPUT==0x38) //0011 1000
   else if(INPUT==0x70) //0111 0000
   else if(INPUT==0x0e) //0000 1110
  turn_leftgo(35,30);}
else if(INPUT==0x07) //0000 0111
     delay(7);
else if(INPUT==0xe0) //1110 0000
  turn_leftgo1(10,20);
     delay(7);
  turn_leftgo1(25,30);}
{   ton1=30;
ton2=30;
   init();
    xunji();
void time0()interrupt 1
i++;
        j++;
if(i<=ton1)
    ENA=1;
else ENA=0;
if(i==100)
    ENA=1;
    i=0;
if(j<=ton2)
       ENB=1;
else ENB=0;
if(j==100)
    ENB=1;
    j=0;
