查看: 15756|回复: 23
基于状态机的按键长按,短按,双击 单片机源程序
ID:573901 发表于 2019-8-23 14:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
先前根据以为前辈的程序理解了一段时间,之后自己写了一份控制led灯的简单按键程序
  1. #include<stc15w202s.h>
  2. #include<stdio.h>
  3. #define key_state_0 0
  4. #define key_state_1 1
  5. #define key_state_2 2
  6. #define key_state_3 3
  7. #define key_no 0
  8. #define key_click 1
  9. #define key_double 2
  10. #define key_long 3
  11. sbit KEY = P3^3;
  12. sbit LED_E1P = P3^1;
  13. sbit LED_G1 = P3^2;
  14. sbit LED2 = P5^5;        //W2OUT
  15. sbit LED3 = P5^4;
  16. unsigned char flag;
  17. unsigned char cnt = 0;
  18. static unsigned char key_driver(void)
  19. {
  20.         static unsigned char key_state_buffer1 = key_state_0;
  21.         static unsigned char key_timer_cnt1 = 0;
  22.         unsigned char key_return = key_no;
  23.         unsigned char key;
  24.
  25.         key = KEY;  //read the I/O states
  26.
  27.         switch(key_state_buffer1)
  28.         {
  29.                 case key_state_0:
  30.                         if(key == 0)
  31.                                 key_state_buffer1 = key_state_1;
  32.                                 //按键被按下,状态转换到按键消抖和确认状态//
  33.                         break;
  34.                 case key_state_1:
  35.                         if(key == 0)
  36.                         {
  37.                                 key_timer_cnt1 = 0;
  38.                                 key_state_buffer1 = key_state_2;
  39.                                 //按键仍然处于按下状态
  40.                                 //消抖完成,key_timer开始准备计时
  41.                                 //状态切换到按下时间计时状态
  42.                         }
  43.                         else
  44.                                 key_state_buffer1 = key_state_0;
  45.                                 //按键已经抬起,回到按键初始状态
  46.                         break;  //完成软件消抖
  47.                 case key_state_2:
  48.                         if(key == 1)
  49.                         {
  50.                                 key_return = key_click;  //按键抬起,产生一次click操作
  51.                                 key_state_buffer1 = key_state_0;  //转换到按键初始状态
  52.                         }
  53.                         else if(++key_timer_cnt1 >= 100)  //按键继续按下,计时超过1000ms
  54.                         {
  55.                                 key_return = key_long;  //送回长按事件
  56.                                 key_state_buffer1 = key_state_3;  //转换到等待按键释放状态
  57.                         }
  58.                         break;
  59.                 case key_state_3:  //等待按键释放
  60.                         if(key == 1)  //按键释放
  61.                                 key_state_buffer1 = key_state_0;  //切回按键初始状态
  62.                         break;
  63.         }
  64.         return key_return;
  65. }
  66. unsigned char key_read(void)
  67. {
  68.         static unsigned char key_state_buffer2 = key_state_0;
  69.         static unsigned char key_timer_cnt2 = 0;
  70.         unsigned char key_return = key_no;
  71.         unsigned char key;
  72.
  73.         key = key_driver();
  74.
  75.         switch(key_state_buffer2)
  76.         {
  77.                 case key_state_0:
  78.                         if(key == key_click)
  79.                         {
  80.                                 key_timer_cnt2 = 0;  //第一次单击,不返回,到下个状态判断是否会出现双击
  81.                                 key_state_buffer2 = key_state_1;
  82.                         }
  83.                         else
  84.                                 key_return = key;  //对于无键、长按,返回原事件
  85.                         break;
  86.                 case key_state_1:
  87.                         if(key == key_click)  //又一次单击,时间间隔小于500ms
  88.                         {
  89.                                 key_return = key_double;  //返回双击事件,回到初始状态
  90.                                 key_state_buffer2 = key_state_0;
  91.                         }
  92.                         else if(++key_timer_cnt2 >= 50)
  93.                         {
  94.                         //这里在下一次的按键来临之前,并且时间是小于500ms的时候,就会一直执行的是这个key_timer_cnt2++.直到下一次的按键到来,再判断看是双击还是单击。
  95.                                 //这里500ms内肯定读到的都是无键事件,因为长按大于1000ms
  96.                                 //在1s前底层返回的都是无键
  97.
  98.                                 key_return = key_click;  //500ms内没有再次出现单击事件,返回单击事件
  99.                                 key_state_buffer2 = key_state_0;  //返回初始状态
  100.
  101.                         }
  102.                         break;
  103.         }
  104.
  105.         return key_return;
  106. }
  107. void Timer0Init(void)                //1毫秒@11.0592MHz
  108. {
  109.         AUXR |= 0x80;                //定时器时钟1T模式
  110.         TMOD &= 0xF0;                //设置定时器模式
  111.         TL0 = 0xCD;                //设置定时初值
  112.         TH0 = 0xD4;                //设置定时初值
  113.         TF0 = 0;                //清除TF0标志
  114.         TR0 = 1;                //定时器0开始计时
  115.         ET0 = 1;
  116. }
  117. void IO_init()
  118. {
  119.
  120.     P3M0 = 0x01;
  121.     P3M1 = 0x01;
  122.     P5M0 = 0x00;
  123.     P5M1 = 0x00;
  124.
  125. }
  126. void main(void)
  127. {
  128.        unsigned char key = 1;
  129.              Timer0Init();
  130.            IO_init();
  131.            LED_E1P = 1;
  132.            LED_G1 = 1;
  133.            LED2 = 1;
  134.            LED3 = 0;
  135.                    EA = 1;
  136.            while(1)
  137.            {
  138.              if(flag)
  139.                  {
  140.                    flag=0;
  141.            key = key_read();
  142.                    switch(key)
  143.                    {
  144.                             case key_click:LED2 = !LED2; break;
  145.                          case key_double:LED2 = !LED2;LED3 = !LED3; break;
  146.                          case key_long: LED2 = 1; LED3 = 1; LED_G1 = 0; LED_E1P = 0; break;
  147.                          default : break;
  148.                    }
  149.                  }
  150.            }
  151. }
  152. void Timr0_ISR() interrupt 1
  153. {
  154.    cnt++;
  155.    if(cnt>=10)
  156.    {
  157.        cnt = 0;
  158.               flag = 1;
  159.    }
  160. }
以上资料51hei提供下载:
基于状态机的按键长按短按双击控制程序.zip (1.87 KB, 下载次数: 367)
收藏收藏58 分享淘帖 顶顶2 踩踩
ID:405604 发表于 2020-1-13 16:51 | 只看该作者
程序写的非常完美,没毛病。提一个存在的小问题,在定时器中断函数Timr0_ISR()里面要重装定时器初值,不然主函数第一次初始化定时器以后定时器溢出,会从0~65535计数,并且一直这样,这样的cnt++就不能计时10ms了,导致前面的按键都不能用,以上本人STC89C52亲测,这个问题头疼了2天后来发现是没有重装初值的问题。其他不懂也没学过!希望后来的朋友不要走弯路,楼主加油!
ID:377382 发表于 2020-2-9 17:22 | 只看该作者
51需要改不少的地方
ID:334781 发表于 2020-2-15 21:20 | 只看该作者
谢谢楼主,下载试一下。对于按键的长按与短按,一直是困或我的问题,先谢谢了!
ID:465279 发表于 2020-3-7 12:39 | 只看该作者
wxqhigh 发表于 2020-1-13 16:51
程序写的非常完美,没毛病。提一个存在的小问题,在定时器中断函数Timr0_ISR()里面要重装定时器初值,不然 ...
仔细看了代码并测试,回复没毛病。正在学习按键处理这块,向你学习。
ID:448556 发表于 2020-3-10 15:48 | 只看该作者
是啊不重装初值 定时中断只运行一次就停止了
ID:573901 发表于 2020-6-1 10:37 | 只看该作者
这个是stc15w系列的单片机,定时器用的是16位自动重装载,所以不需要从新赋初值了,不过还是谢谢提醒,一起加油!
ID:573901 发表于 2020-6-1 10:39 | 只看该作者
嗯嗯 ,怪我没注意,51系列的要装初值,我这个是stc系列的芯片,定时器0是16位自动重装载的,一起加油
ID:573901 发表于 2020-6-1 10:42 | 只看该作者
嗯,是的,手上没有51的板子,所以用了stc的程序写的,不过这个按键的状态机是可以用的,其他注意51的重装初值问题。
ID:389488 发表于 2020-9-22 15:27 | 只看该作者
stc15不用重装初值
ID:610086 发表于 2020-11-27 10:59 | 只看该作者
单击的时候500ms检测,会不会有些卡顿感?
ID:88256 发表于 2020-11-27 13:39 | 只看该作者
下载学习一下,谢谢分享!
ID:367948 发表于 2021-2-18 12:04 | 只看该作者
谢谢楼主,正需要单片机检测连续按下按键程序
ID:275826 发表于 2021-2-26 18:05 | 只看该作者
程序可以,就是太复杂了,可以简化很多
ID:508724 发表于 2021-3-10 09:51 | 只看该作者
这个状态机写的很不错,nice
ID:430492 发表于 2021-3-23 11:40 | 只看该作者
写得不错,是个很好的参考例程。
ID:839438 发表于 2021-6-3 21:38 | 只看该作者
谢谢,正在学习状态机
ID:935260 发表于 2021-6-10 10:03 | 只看该作者
针对特定的单片机写程序和通用的单片机程序,还是有差别
ID:601234 发表于 2021-10-20 16:53 | 只看该作者
key_read  和  key_drive可以合并吗
ID:601234 发表于 2021-10-20 16:54 | 只看该作者
key_read和key_drive可以合并吗
ID:821788 发表于 2022-8-28 15:19 | 只看该作者
感谢!感谢!
key_read和key_drive可以尝试合并,少用一个状态机、少占用一个byte RAM
ID:59300 发表于 2023-9-11 09:28 | 只看该作者
很好的文章,对我正在学习状态机非常有帮助,谢谢
ID:1127891 发表于 2024-7-2 14:35 | 只看该作者
楼主这么nb
ID:786399 发表于 2024-7-2 21:11 | 只看该作者
受益匪浅
