查看: 2964|回复: 3
单片机+lcd1602修改时间和年月日出现问题
ID:728467 发表于 2020-5-3 23:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
为什么我想修改第一行的年月日,按下y1,光标直接跳到第二行上不来了,控制年月日的按键都没用,请教大佬们要怎么修改, 谢谢
#include<reg52.h>
sbit en=P3^4;
sbit rs=P3^5;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P2^0;
sbit s4=P2^1;
sbit dula=P2^6;
sbit wela=P2^7;
sbit y1=P3^3;
sbit y2=P2^2;
sbit y3=P2^4;
char shi,fen,miao;//char??-128~127
char nian,yue,ri;
uchar count,s1num,y1num; //uchar??0~255
uchar code table[]="  2020-05-03 SUN";
uchar code table1[]="    00:00:00";
void write_com(uchar com);
void write_date(uchar date);
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
rs=0;
en=0;
P0=com;
delay(5);
en=1;
delay(5);
en=0;
rs=1;
en=0;
P0=date;
delay(5);
en=1;
delay(5);
en=0;
void init()
uchar num;
dula=0;
wela=0;
num=0;
en=0;
TMOD=0X01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<16;num++)
  write_date(table[num]);
  delay(5);
write_com(0x80+0x40);
for(num=0;num<12;num++)
  write_date(table1[num]);
  delay(5);
void write_nyr(uchar add1,uchar date1)
uchar shi1,ge1;
shi1=date1/10;
ge1=date1%10;
write_com(0x80+add1);
write_date(0x30+shi1);
write_date(0x30+ge1);
void write_sfm(uchar add,uchar date)//?????????
{ uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void keyscan()
if(y1==0)
delay(5);
if(y1==0)
  y1num++;
  while(!y1);
  if(y1num==1)
   write_com(0x80+0+11);
   write_com(0x0f);
  if(y1num==2)
   write_com(0x80+0+8);
  if(y1num==3)
   write_com(0x80+0+5);
if(y1num!=0)
  if(y2==0)
   delay(5);
   if(y2==0)
    while(!y2);
    if(y1num==1)
     ri++;
     if(ri==30)
      ri=0;
     write_nyr(12,ri);
     write_com(0x80+0+12);
    if(y1num==2)
     yue++;
     if(yue==12)
      yue=0;
     write_nyr(9,yue);
     write_com(0x80+0+9);
    if(y1num==3)
     nian++;
     if(nian==99)
      nian=0;
     write_nyr(6,nian);
     write_com(0x80+0+6);
if(y3==0)
  delay(5);
  if(y3==0)
   while(!y3);
   if(y1num==1)
    ri--;
    if(ri==-1)
     ri=30;
    write_nyr(12,ri);
   if(y1num==2)
    yue--;
    if(yue==-1)
     yue=12;
    write_nyr(9,yue);
   if(y1num==3)
    nian--;
    if(nian==-1)
     nian=30;
    write_nyr(6,nian);
init();
  keyscan();
void timer0() interrupt 1
count++;
  if(count==20)
   count=0;
   miao++;
   if(miao==60)
   miao=0;
   fen++;
   if(fen==60)
    fen=0;
    shi++;
    if(shi==24)
     shi=0;
     write_sfm(4,shi);
    write_sfm(7,fen);
   write_sfm(10,miao);
ID:213173 发表于 2020-5-4 09:10 | 只看该作者
这个示例比较适合楼主目前的学习进度
LCD1602万年历 仿真.zip (153.36 KB, 下载次数: 25)
ID:728467 发表于 2020-5-4 16:20 | 只看该作者
wulin 发表于 2020-5-4 09:10
这个示例比较适合楼主目前的学习进度
已下载谢谢
ID:744088 发表于 2020-5-4 19:18 | 只看该作者
好牛逼啊楼主
