查看: 11525|回复: 5
正点原子STM32的ESP8266程序
ID:287002 发表于 2018-3-2 17:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
让大家参考参考
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "key.h"
  7. #include "usmart.h"
  8. #include "malloc.h"
  9. #include "mmc_sd.h"
  10. #include "flash.h"
  11. #include "ff.h"
  12. #include "exfuns.h"
  13. #include "text.h"
  14. #include "usart2.h"
  15. #include "touch.h"
  16. #include "common.h"
  17. //ALIENTEK战舰STM32开发板扩展实验6
  18. //ATK-ESP8266 WIFI模块测试实验
  19. int main(void)
  20. {
  21.         u8 key,fontok=0;
  22.            Stm32_Clock_Init(9);        //系统时钟设置
  23.         delay_init(72);                        //延时初始化
  24.         uart_init(72,115200);         //串口1初始化
  25.         usart2_init(36,115200);  //串口2初始化
  26.         u2_printf("nihao/r/n");
  27.         LCD_Init();                                //初始化液晶
  28.         LED_Init();                 //LED初始化
  29.         KEY_Init();                                //按键初始化
  30.         usmart_dev.init(72);        //usmart初始化
  31.         TP_Init();                                //初始化触摸屏
  32.         mem_init(SRAMIN);                //初始化内部内存池
  33.         exfuns_init();                        //为fatfs相关变量申请内存
  34.   f_mount(0,fs[0]);                 //挂载SD卡
  35.         f_mount(1,fs[1]);                                             //挂载FLASH.
  36.         key=KEY_Scan(0);
  37.         if(key==KEY_RIGHT)                //强制校准
  38.         {
  39.                 LCD_Clear(WHITE);        //清屏
  40.                 TP_Adjust();                  //屏幕校准
  41.                 TP_Save_Adjdata();
  42.                 LCD_Clear(WHITE);        //清屏
  43.         }
  44.         fontok=font_init();                //检查字库是否OK
  45.         if(fontok||key==KEY_DOWN)//需要更新字库
  46.         {
  47.                 LCD_Clear(WHITE);                           //清屏
  48.                 POINT_COLOR=RED;                        //设置字体为红色
  49.                 LCD_ShowString(60,50,200,16,16,"ALIENTEK STM32");
  50.                 while(SD_Initialize())                //检测SD卡
  51.                 {
  52.                         LCD_ShowString(60,70,200,16,16,"SD Card Failed!");
  53.                         delay_ms(200);
  54.                         LCD_Fill(60,70,200+60,70+16,WHITE);
  55.                         delay_ms(200);
  56.                 }
  57.                 LCD_ShowString(60,70,200,16,16,"SD Card OK");
  58.                 LCD_ShowString(60,90,200,16,16,"Font Updating...");
  59.                 key=update_font(20,110,16,0);//从SD卡更新
  60.                 while(key)//更新失败
  61.                 {
  62.                         LCD_ShowString(60,110,200,16,16,"Font Update Failed!");
  63.                         delay_ms(200);
  64.                         LCD_Fill(20,110,200+20,110+16,WHITE);
  65.                         delay_ms(200);
  66.                 }
  67.                 LCD_ShowString(60,110,200,16,16,"Font Update Success!");
  68.                 delay_ms(1500);
  69.                 LCD_Clear(WHITE);        //清屏
  70.         }
  71.         atk_8266_test();                //进入ATK_ESP8266测试
  72. }
(适合战舰V2 STM32开发板)扩展实验6 ATK-ESP8266 WIFI模块测试实验.rar (847.32 KB, 下载次数: 316)
收藏收藏3 分享淘帖 顶 踩
ID:403087 发表于 2018-12-13 15:42 | 只看该作者
谢谢分享!
ID:445515 发表于 2019-1-2 22:32 | 只看该作者
这是stm32f4的吗
ID:362745 发表于 2019-1-3 16:58 | 只看该作者
52是51的增强型,S52比C51,定时器多一个T2(这个东东强悍的很),RAM多128B,ROM多4K,中断多2个,多一个看门狗,在掉电、数据指针等方面还有一些改进。
S52的最高外接晶振可以达到33MHz,C51大概只有24MHz。
现在市面上,C51都差不多淘汰了,价格两者接近(可能一样),要买的话,摊主一般会推荐你买S52。
ID:474606 发表于 2019-5-17 14:21 | 只看该作者
感谢楼主热心分享,正好用的上。
ID:664066 发表于 2020-6-6 11:44 | 只看该作者
感谢分享。
