查看: 3628|回复: 0
ucosII信号量学习资料及代码
ID:773304 发表于 2020-6-8 21:45 | 显示全部楼层 |阅读模式
附件中有某高校ucosII有关信号量的ppt及相关代码。
在uCOS_II.H中增加变量定义    1
在test.c中注释掉变量y    1
文件OS_SEM.C中的OSSemPend函数中添加红色部分代码    1
文件OS_SEM.C中的OSSemPost函数中添加红色部分代码    3
在uCOS_II.H中增加变量定义
                                            GLOBAL VARIABLES
OS_EXT  INT8U             y;   //定义打印输出位置变量
OS_EXT  INT32U            OSCtxSwCtr;               /* Counter of number of context switches           */
#if (OS_EVENT_EN > 0) && (OS_MAX_EVENTS > 0)
OS_EXT  OS_EVENT         *OSEventFreeList;          /* Pointer to list of free EVENT control blocks    */
OS_EXT  OS_EVENT          OSEventTbl[OS_MAX_EVENTS];/* Table of EVENT control blocks                   */
#endif
在test.c中注释掉变量y
void  OSSemPend (OS_EVENT *pevent, INT16U timeout, INT8U *err)
#if OS_CRITICAL_METHOD == 3      /* Allocate storage for CPU status register      */
    OS_CPU_SR  cpu_sr;
#endif
    char str[25];
    if (OSIntNesting > 0) {  /* See if called from ISR ...   */
        *err = OS_ERR_PEND_ISR;  /* ... can't PEND from an ISR         */
        return;
#if OS_ARG_CHK_EN > 0
    if (pevent == (OS_EVENT *)0) {   /* Validate 'pevent'             */
        *err = OS_ERR_PEVENT_NULL;
        return;
    if (pevent->OSEventType != OS_EVENT_TYPE_SEM) {   /* Validate event block type  */
        *err = OS_ERR_EVENT_TYPE;
        return;
#endif
    OS_ENTER_CRITICAL();
    if (pevent->OSEventCnt > 0) { /* If sem. is positive, resource available ...   */
        pevent->OSEventCnt--;    /* ... decrement semaphore only if positive.     */
        OS_EXIT_CRITICAL();
        *err = OS_NO_ERR;
        sprintf(str, "task%d--resource count: %d", OSTCBCur->OSTCBPrio, pevent->OSEventCnt);
        PC_DispStr(15, y++, str, DISP_FGND_YELLOW+DISP_BGND_BLUE);
        return;
    /* Otherwise, must wait until event occurs       */
    OSTCBCur->OSTCBStat |= OS_STAT_SEM;  /* Resource not available, pend on semaphore     */
    OSTCBCur->OSTCBDly   = timeout;  /* Store pend timeout in TCB      */
    OS_EventTaskWait(pevent);    /* Suspend task until event or timeout occurs    */
    OS_EXIT_CRITICAL();
    sprintf(str, "task%d--I'll wait", OSTCBCur->OSTCBPrio);
    OS_Sched();        /* Find next highest priority task ready         */
    if (OSTCBCur->OSTCBStat & OS_STAT_SEM) { /* Must have timed out if still waiting for event*/
        OS_EventTO(pevent);
        OS_EXIT_CRITICAL();
        *err = OS_TIMEOUT;    /* Indicate that didn't get event within TO      */
        sprintf(str, "task%d--time out", OSTCBCur->OSTCBPrio);
        return;
    OSTCBCur->OSTCBEventPtr = (OS_EVENT *)0;
    OS_EXIT_CRITICAL();
    sprintf(str, "task%d--finally get it", OSTCBCur->OSTCBPrio);
    *err = OS_NO_ERR;
INT8U  OSSemPost (OS_EVENT *pevent)
    OS_CPU_SR  cpu_sr;
#endif
    char str[25];
        return (OS_ERR_PEVENT_NULL);
        return (OS_ERR_EVENT_TYPE);
#endif
    if (pevent->OSEventGrp != 0x00) { /* See if any task waiting for semaphore    */
        OS_EventTaskRdy(pevent, (void *)0, OS_STAT_SEM);   /* Ready highest prio task waiting on event */
        OS_EXIT_CRITICAL();
        sprintf(str, "task%d--I'll Sched", OSTCBCur->OSTCBPrio);
        OS_Sched();   /* Find highest priority task ready to run  */
        sprintf(str, "task%d--back from Sched", OSTCBCur->OSTCBPrio);
        return (OS_NO_ERR);
    if (pevent->OSEventCnt < 65535) {   /* Make sure semaphore will not overflow    */
        pevent->OSEventCnt++;     /* Increment semaphore count to register event   */
        OS_EXIT_CRITICAL();
        return (OS_NO_ERR);
    OS_EXIT_CRITICAL();       /* Semaphore value has reached its maximum       */
    sprintf(str, "task%d--OS_SEM_OVF", OSTCBCur->OSTCBPrio);
    return (OS_SEM_OVF);
07-任务的同步与通信.zip
300.99 KB, 下载次数: 22, 下载积分: 黑币 -5
