查看: 3441|回复: 2
STM32无法循环点亮,求个大神帮帮忙
ID:783526 发表于 2020-6-21 11:22 | 显示全部楼层 |阅读模式
#include "stm32f10x.h"
uint16_t temp,i;
void Delay(unsigned int count)
        unsigned int i;
        for(;count!=0;count--)
                i=5000;
                while(i--);
void main(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
                if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==0)
                        Delay(500);
                                temp=0x0100;
                    for(i=0;i<8;i++)
                            GPIO_Write(GPIOB,~temp);
                             Delay(100);
                            temp=temp<<1;
                                        while(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==1);
           }else if (GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==1){
                         temp=0x8000;
                         for(i=7;i>=0;i--)
                             Delay(100);
                            temp=temp>>1;
ID:277948 发表于 2020-6-21 18:19 | 显示全部楼层
我把程序改为 按键按下灯取反四次
#include "sys.h"
//#include "intrins.h"
#define LED1 PDout(2)        // PD2
uint16_t temp,i;
        unsigned int i;
                i=5000;
                while(i--);
int main(void)
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;//注意GPIO_Mode_IPD不是GPIO_Mode_IPU
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
        GPIO_Init(GPIOD,&GPIO_InitStructure);
                                temp=0x0001;//注要放在循环前边
        if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==1)     //没按下按键为0 按下按键为1
                Delay(200);
                        for(i=0;i<8;i++)
//                                GPIO_Write(GPIOD,temp);
                                LED1=!LED1;
                                Delay(1000);
   }while(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==0); //按键释放应该放在按键判断之外
ID:355173 发表于 2020-6-22 14:47 | 显示全部楼层
是IPU(上拉输入),而IPD是(下拉),很明显PA0接了个电阻到VDD,而当有按键按下时,电路接通到地,所以PA0处读到的电压是0,当释放时,与VDD想接,是高电平为1
