查看: 7310|回复: 1
单片机24秒倒计时代码
ID:544905 发表于 2020-6-10 11:19 | 显示全部楼层 |阅读模式
设计实现24秒计时器。要求:
(1)倒计时功能
(2)24秒复位键功能
(3)启动/暂停键功能
  1. #include<reg51.h>
  2. unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  3. typedef unsigned int uint;
  4. uint i,j,f1=0;
  5. uint q=4,p=2;
  6. uint sum = 0;
  7. sbit P2_0=P2^0;
  8. sbit P2_1=P2^1;
  9. sbit P2_2=P2^2;
  10. sbit P2_3=P2^3;
  11. uint num2=0,num=24,shi=2,ge=4;
  12. void T1_time()interrupt 3
  13. {
  14.                 TH1=(65536-49000)/256;
  15.                 TL1=(65536-49000)%256;
  16.                 num2++;
  17.                 if(num2==20){
  18.                 num2=0;
  19.
  20.                 if(!f1){
  21.                 if(num!=0)num--;
  22.                 shi=num/10;
  23.                 ge=num%10;
  24.                 }
  25.                 }
  26. }
  27. void ex_int()interrupt 0
  28. {
  29.          num=24;
  30. }
  31. void ex_int1()interrupt 2
  32. {
  33.         sum++;
  34.         if(sum%2==1)
  35.                 f1=1;
  36.         else
  37.                 f1=0;
  38. }
  39. void delay()
  40. {
  41.   uint j;
  42.   for(j=0;j<200;j++);
  43. }
  44. void disply()
  45. {
  46.          P2&=0XF0;
  47.
  48.          P1=table[shi];
  49.          P2_0=1;
  50.          delay();
  51.          P2&=0XF0;
  52.
  53.          P1=table[ge];
  54.          P2_1=1;
  55.          delay();
  56.          P1=0;
  57.          P2&=0XF0;
  58. }
  59. main()
  60. {
  61.           TMOD=0X10;
  62.           TH1=(65536-49000)/256;
  63.           TL1=(65536-49000)%256;
  64.           EA=1;
  65.           EX0=1;
  66.           IT0=1;
  67.           EX1=1;
  68.           IT1=1;
  69.           ET1=1;
  70.           TR1=1;
  71.
  72.            while(1)
  73.            {
  74.                   disply();
  75.
  76.            }
  77. }
ID:786804 发表于 2020-6-23 10:30 来自触屏版 | 显示全部楼层
能否解说一下程序。
