查看: 4517|回复: 1
STM32F030工程模板下载
关于STM32F030的具体模板,共开发者参考
  1. ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
  2. /*
  3. STM32F030C8T6模板
  4. 时钟都在system_stm32f0xxx.里设定。用那个开那个,输出都是48MHZ,最大频率,可以在里面改变大小频率
  5. #define PLL_SOURCE_HSI        // HSI (~8MHz) used to clock the PLL, and the PLL is used as system clock source(~ 8MHz)
  6. //#define PLL_SOURCE_HSE        // HSE (8MHz) used to clock the PLL, and the PLL is used as system clock source
  7. //#define PLL_SOURCE_HSE_BYPASS // HSE bypassed with an external clock (8MHz, coming from ST-Link) used to clock
  8.
  9. 使用内部时钟 48MHZ
  10. */
  11. #include "stm32f0xx.h"
  12. #include "delay.h"
  13. void LedInit(void)
  14. {
  15.   GPIO_InitTypeDef GPIO_InitStructure;
  16.   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);        //GPIOF时钟打开
  17.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;
  18.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;          //模式:输出
  19.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;                //输入类型:上拉/下拉/无
  20.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;                //输出类型:推挽输出
  21.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //输出速率
  22.   GPIO_Init(GPIOA,&GPIO_InitStructure);
  23. }
  24. int main(void)
  25. {
  26.         delay_init();///定时器初始化,
  27.         LedInit();///LED灯初始代,
  28.
  29.    while (1)
  30.   {
  31.                  GPIO_ResetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2);
  32.                  delay_ms(200);                                                  //延时
  33.                  GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2);
  34.                  delay_ms(200);
  35.   }
  36. }
工程模板-F030.zip (297.96 KB, 下载次数: 222)
收藏收藏1 分享淘帖 顶顶 踩踩
ID:8977 发表于 2020-6-28 17:13 | 只看该作者
感谢分享,刚好下载看一下
