查看: 2866|回复: 0
第一次发帖,自己写的电子表程序,运用lcd1602显示,按键调剂,供参考。欢迎提建议。
ID:305252 发表于 2018-8-5 18:44 | 显示全部楼层 |阅读模式
程序如下:#include<reg52.h>
sbit rs = P2^6;       //LCD的数据/命令选择端
sbit rw = P2^5;       //LCD的读写选择端
sbit e = P2^7;        //LCD的使能信号端
sbit s1 = P3^0;
sbit s2 = P3^1;
sbit s3 = P3^2;
sbit s4 = P3^3;
uchar count,s1num,s4num;
char i,miao,shi,fen;
uchar nian,yue,ri,xq,xqs;
uchar code table[] = "  2018-00-00 xxx";
uchar code table1[] = "    00:00:00 ";
uchar code week1[] = "Sun";
uchar code week2[] = "Mon";
uchar code week3[] = "Tue";
uchar code week4[] = "Wed";
uchar code week5[] = "Thu";
uchar code week6[] = "Fri";
uchar code week7[] = "Sat";
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com(uchar com)        //写命令
        rs = 0;
        rw = 0;
        P0 = com;
        delay(5);
        e = 1;
        delay(5);
        e = 0;
void write_data(uchar date)          //写数据
        rs = 1;
        rw = 0;
        P0 = date;
        delay(5);
        e = 1;
        delay(5);
        e = 0;
void int_all()
        uchar num;
//        miao = 58;
//        fen = 59;
//        shi = 23;
        nian = 18;
//        yue = 12;
//        ri = 31;
        write_com(0x38);
        delay(5);
        write_com(0x0c);
        delay(5);
        write_com(0x06);
        delay(5);
        write_com(0x01);
        write_com(0x80);
        for(num=0;num<16;num++)
                write_data(table[num]);
                delay(20);
        write_com(0x80+0x40);
        for(num=0;num<13;num++)
                write_data(table1[num]);
                delay(20);
        TMOD = 0X01;
        TH0 = (65536-50000)/256;
        TL0 = (65536-50000)%256;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
void write_sfm(uchar add,uchar date)
        uchar shi,ge;
        shi = date/10;
        ge = date%10;
        write_com(0x80+0x40+add);
        write_data(0x30+shi);
        write_data(0x30+ge);
void write_ry(uchar add,uchar date)
        uchar ge,shi;
        shi = date/10;
        ge = date%10;
        write_com(0x80+add);
void write_ryn(uchar add,uchar date)
        uchar ge,shi,bai,qian;
        //qian =0;
        //bai =0;
        shi =date/10;
        ge =date%10;
        //write_data(0x30+qian);
        //write_data(0x30+bai);
void write_xq(uchar add,uchar date)
        switch(xq)
                case(1):
                                for(i=0;i<3;i++)
                                        write_com(0x80+13+i);
                                        write_data(week1[i]);
                                break;
                case(2):
                                for(i=0;i<3;i++)
                                        write_data(week2[i]);
                                break;
                case(3):
                                for(i=0;i<3;i++)
                                        write_data(week3[i]);
                                break;
                case(4):
                                for(i=0;i<3;i++)
                                        write_data(week4[i]);
                                break;
                case(5):
                                for(i=0;i<3;i++)
                                        write_data(week5[i]);
                                break;
                case(6):
                                for(i=0;i<3;i++)
                                        write_data(week6[i]);
                                break;
                case(7):
                                for(i=0;i<3;i++)
                                        write_data(week7[i]);
                                break;
void keyscan()
        if(s1==0 && s4num==0)
                delay(5);
                if(s1==0)
                        s1num++;
                        while(!s1);
                        if(s1num==1)
                                TR0 = 0;
                                write_com(0x0f);
                                write_com(0x80+0x40+10);
                        if(s1num==2)
                                write_com(0x80+0x40+7);
                        if(s1num==3)
                                write_com(0x80+0x40+4);
                        if(s1num==4)
                                s1num = 0;
                                write_com(0x0c);
                                TR0=1;
        if(s1num!=0 && s4num==0)
                if(s2==0)
                        delay(5);
                        if(s2==0)
                                while(!s2);
                                if(s1num==1)
                                        miao++;
                                        if(miao==60)
                                                miao = 0;
                                        write_sfm(10,miao);
                                if(s1num==2)
                                        fen++;
                                        if(fen==60)
                                                fen = 0;
                                        write_sfm(7,fen);
                                if(s1num==3)
                                        shi++;
                                        if(shi==24)
                                                shi = 0;
                                        write_sfm(4,shi);
                if(s3==0)
                        delay(5);
                        if(s3==0)
                                while(!s3);
                                if(s1num==1)
                                        miao--;
                                        if(miao==-1)
                                                miao = 59;
                                        write_sfm(10,miao);
                                if(s1num==2)
                                        fen--;
                                        if(fen==-1)
                                                fen = 59;
                                        write_sfm(7,fen);
                                if(s1num==3)
                                        shi--;
                                        if(shi==-1)
                                                shi = 23;
                                        write_sfm(4,shi);
        if(s4==0 && s1num==0)
                delay(5);
                if(s4==0)
                        s4num++;
                        while(!s4);
                        if(s4num==1)
                                TR0 = 0;
                                write_com(0x80+10);
                                write_com(0x0f);
                        if(s4num==2)
                                write_com(0x80+7);
                        if(s4num==3)
                                write_com(0x80+4);
                        if(s4num==4)
                                write_com(0x80+13);
                        if(s4num==5)
                                s4num = 0;
                                write_com(0x0c);
                                TR0=1;
        if(s4num!=0 && s1num==0)
                if(s2==0)
                        if(s2==0)
                                delay(5);
                                while(!s2);
                                if(s4num==1)
                                        ri++;
                                        if(ri==32)
                                                ri = 1;
                                        write_ry(10,ri);
                                        write_com(0x80+10);
                                if(s4num==2)
                                        yue++;
                                        if(yue==13)
                                                yue = 1;
                                        write_ry(7,yue);
                                        write_com(0x80+7);
                                if(s4num==3)
                                        nian++;
                                        write_ryn(4,nian);
                                        write_com(0x80+4);
                                if(s4num==4)
                                        xq++;
                                        if(xq==8)
                                                xq = 1;
                                        write_xq(13,xq);
                                        write_com(0x80+13);
                if(s3==0)
                        if(s3==0)
                                delay(5);
                                while(!s3);
                                if(s4num==1)
                                        if(ri==0)
                                                ri = 31;
                                        ri--;
                                        write_ry(10,ri);
                                        write_com(0x80+10);
                                if(s4num==2)
                                        if(yue==0)
                                                yue = 12;
                                        yue--;
                                        write_ry(7,yue);
                                        write_com(0x80+7);
                                if(s4num==3)
                                        if(nian==0)
                                                nian = 1;
                                        nian--;
                                        write_ryn(4,nian);
                                        write_com(0x80+4);
                                if(s4num==4)
                                        if(xq==0)
                                                xq = 7;
                                        xq--;
                                        write_xq(13,xq);
                                        write_com(0x80+13);
        int_all();
                keyscan();
                if(miao==60)
                                miao = 0;
                                fen++;
                                if(fen==60)
                                        fen = 0;
                                        shi++;
                                        if(shi==24)
                                                shi = 0;
                                                ri++;
                                                xq++;
                                                if(xq==8)
                                                        xq = 1;
                                                write_xq(15,xq);
                                                if(ri==32)
                                                        ri = 1;
                                                        yue++;
                                                        if(yue==13)
        yue = 1;
        nian++;
        write_ryn(4,nian);
                                                         write_ry(7,yue);
                                                write_ry(10,ri);
                                        write_sfm(4,shi);
                                write_sfm(7,fen);
                        write_sfm(10,miao);
void timer0() interrupt 1
        count++;
        if(count==20)
                        count = 0;
                        miao++;
数字表,年月日星期时分秒.rar
30.51 KB, 下载次数: 9, 下载积分: 黑币 -5
参与人数 2黑币 +65 收起 理由
杨雪飞 + 15 很给力!
