查看: 2209|回复: 1
16个按钮扫描亮灯单片机程序问题
小白写子函数写不下去了,网上找的仿真图,每个按键亮对应位置的段码灯,有大哥指导一下思路吗?
#include "reg52.h"
#define key P1
#define dmg1 P2
#define dmg2 P3
void delay(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--);
uchar Keys()
        uchar Keym;
        key=0xf0;
        if(key!=0xf0)
                delay(10);
                        if(key!=0xf0)
                                key=0xfe;
                                        if(key!=0xfe)
                                                Keym=key;
                                                delay(10);
                                                while(key!=0xfe);
                                                return Keym;
                                key=0xfd;
                                        if(key!=0xf0)
                                                delay(10);
                                                        if(key!=0xfd)
        Keym=key;
        delay(10);
        while(key!=0xfd);
        return Keym;
                                 key=0xfb;
                                         if(key!=0xfb)
                                                delay(10);
                                                if(key!=0xfb)
                                                        Keym=key;
                                                        delay(10);
                                                        while(key!=0xfb);
                                                        return Keym;
                                 key=0xf7;
                                         if(key!=0xf7)
                                                delay(10);
                                                if(key!=0xf7)
                                                        Keym=key;
                                                        delay(10);
                                                        while(key!=0xf7);
                                                        return Keym;
        return 0xff;
uchar Keyz()
        uchar i;
        switch(Keys())
                case 0x7e:return dmg1;break;
                case 0x7d:return dmg1;break;
                case 0x7b:return dmg1;break;
                case 0x77:return dmg1;break;
                case 0xbe:return dmg1;break;
                case 0xbd:return dmg1;break;
                case 0xbb:return dmg1;break;
                case 0xb7:return dmg1;break;
                case 0xde:return dmg2;break;
                case 0xdd:return dmg2;break;
                case 0xdb:return dmg2;break;
                case 0xd7:return dmg2;break;
                case 0xee:return dmg2;break;
                case 0xed:return dmg2;break;
                case 0xeb:return dmg2;break;
                case 0xe7:return dmg2;break;
ID:739545 发表于 2021-3-11 15:12 | 只看该作者
矩阵键盘巡检,不知道要问什么问题,
