查看: 9344|回复: 21
已经调通的STM32 HAL库IIC驱动OLED源码
ID:336427 发表于 2019-1-26 13:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "main.h"
  2. #include "stm32f1xx_hal.h"
  3. #include "tim.h"
  4. #include "usart.h"
  5. #include "gpio.h"
  6. /* USER CODE BEGIN Includes */
  7. #include "oled.h"
  8. #include "delay.h"
  9. #include "bmp.h"
  10. /* USER CODE END Includes */
  11. /* Private variables ---------------------------------------------------------*/
  12. /* USER CODE BEGIN PV */
  13. /* Private variables ---------------------------------------------------------*/
  14. /* USER CODE END PV */
  15. /* Private function prototypes -----------------------------------------------*/
  16. void SystemClock_Config(void);
  17. /* USER CODE BEGIN PFP */
  18. /* Private function prototypes -----------------------------------------------*/
  19. /* USER CODE END PFP */
  20. /* USER CODE BEGIN 0 */
  21. /* USER CODE END 0 */
  22. /**
  23.   * @brief  The application entry point.
  24.   *
  25.   * @retval None
  26.   */
  27. int main(void)
  28. {
  29.   /* USER CODE BEGIN 1 */
  30.                 u8 t;
  31.   /* USER CODE END 1 */
  32.   /* MCU Configuration----------------------------------------------------------*/
  33.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  34.   HAL_Init();
  35.   /* USER CODE BEGIN Init */
  36.   /* USER CODE END Init */
  37.   /* Configure the system clock */
  38.   SystemClock_Config();
  39.   /* USER CODE BEGIN SysInit */
  40.   /* USER CODE END SysInit */
  41.   /* Initialize all configured peripherals */
  42.   MX_GPIO_Init();
  43.   MX_TIM4_Init();
  44.   MX_USART1_UART_Init();
  45.   /* USER CODE BEGIN 2 */
  46. delay_init();
  47.                  OLED_Init();                        //初始化OLED
  48.                 OLED_Clear()          ;
  49.   /* USER CODE END 2 */
  50.   /* Infinite loop */
  51.   /* USER CODE BEGIN WHILE */
  52.                         t=' ';
  53.   while (1)
  54.   {
  55.   /* USER CODE END WHILE */
  56.   /* USER CODE BEGIN 3 */
  57.                         OLED_Clear();
  58.         //        LED_ON;
  59. //显示汉字
  60. /*void OLED_ShowCHinese(u8 x,u8 y,u8 no)
  61.   x,y分别代表要显示的汉字在屏上的坐标位置,最后一位是汉字在汉字数组的位数
  62. */
  63.                 OLED_ShowCHinese(0,0,0);//中
  64.                 OLED_ShowCHinese(18,0,1);//景
  65.                 OLED_ShowCHinese(36,0,2);//园
  66.                 OLED_ShowCHinese(54,0,3);//电
  67.                 OLED_ShowCHinese(72,0,4);//子
  68.                 OLED_ShowCHinese(90,0,5);//科
  69.                 OLED_ShowCHinese(108,0,6);//技
  70.                 OLED_ShowString(0,3,"1.3' OLED TEST");
  71.                 //OLED_ShowString(8,2,"ZHONGJINGYUAN");
  72.          //        OLED_ShowString(20,4,"2014/05/01");
  73.                 OLED_ShowString(0,6,"ASCII:");
  74.                 OLED_ShowString(63,6,"CODE:");
  75.                 OLED_ShowChar(48,6,t);//显示ASCII字符
  76.                 t++;
  77.                 if(t>'~')t=' ';
  78.                 OLED_ShowNum(103,6,t,3,16);//显示ASCII字符的码值
  79.
  80.
  81.                 delay_ms(2000);
  82.                 OLED_Clear();
  83.                 delay_ms(2000);
  84.         //                LED_OFF;
  85.                 OLED_DrawBMP(0,0,128,8,BMP1);  //图片显示(图片显示慎用,生成的字表较大,会占用较多空间,FLASH空间8K以下慎用)
  86.                 delay_ms(2000);
  87.                 OLED_DrawBMP(0,0,128,8,BMP2);
  88.                 delay_ms(2000);
  89.   }
  90.   /* USER CODE END 3 */
  91. }
  92. /**
  93.   * @brief System Clock Configuration
  94.   * @retval None
  95.   */
  96. void SystemClock_Config(void)
  97. {
  98.   RCC_OscInitTypeDef RCC_OscInitStruct;
  99.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  100.     /**Initializes the CPU, AHB and APB busses clocks
  101.     */
  102.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  103.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  104.   RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  105.   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  106.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  107.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  108.   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  109.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  110.   {
  111.     _Error_Handler(__FILE__, __LINE__);
  112.   }
  113.     /**Initializes the CPU, AHB and APB busses clocks
  114.     */
  115.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  116.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  117.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  118.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  119.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  120.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  121.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
  122.   {
  123.     _Error_Handler(__FILE__, __LINE__);
  124.   }
  125.     /**Configure the Systick interrupt time
  126.     */
  127.   HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  128.     /**Configure the Systick
  129.     */
  130.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  131.   /* SysTick_IRQn interrupt configuration */
  132.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  133. }
  134. /* USER CODE BEGIN 4 */
  135. /* USER CODE END 4 */
  136. /**
  137.   * @brief  This function is executed in case of error occurrence.
  138.   * @param  file: The file name as string.
  139.   * @param  line: The line in file as a number.
  140.   * @retval None
  141.   */
  142. void _Error_Handler(char *file, int line)
  143. {
  144.   /* USER CODE BEGIN Error_Handler_Debug */
  145.   /* User can add his own implementation to report the HAL error return state */
  146.   while(1)
  147.   {
  148.   }
  149.   /* USER CODE END Error_Handler_Debug */
  150. }
  151. #ifdef  USE_FULL_ASSERT
  152. /**
  153.   * @brief  Reports the name of the source file and the source line number
  154.   *         where the assert_param error has occurred.
  155.   * @param  file: pointer to the source file name
  156.   * @param  line: assert_param error line source number
  157.   * @retval None
  158.   */
  159. void assert_failed(uint8_t* file, uint32_t line)
  160. {
  161.   /* USER CODE BEGIN 6 */
  162.   /* User can add his own implementation to report the file name and line number,
  163.      tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  164.   /* USER CODE END 6 */
  165. }
  166. #endif /* USE_FULL_ASSERT */
  167. /**
  168.   * @}
  169.   */
  170. /**
  171.   * @}
  172.   */
  173. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
oled.7z (3.01 MB, 下载次数: 302)
收藏收藏6 分享淘帖 顶 踩
ID:150565 发表于 2019-5-10 13:49 | 只看该作者
您好资料可以共享吗?
ID:150565 发表于 2019-5-10 13:50 | 只看该作者
怎么下载不了
ID:189285 发表于 2019-5-11 11:26 | 只看该作者
可以,我正需要这个
ID:443010 发表于 2019-5-15 12:41 | 只看该作者
楼主资料能够分享一下?
ID:311744 发表于 2019-5-26 17:24 | 只看该作者
果断下载学习一下
ID:336427 发表于 2019-7-12 10:06 | 只看该作者
lvmingchillout 发表于 2019-5-15 12:41
楼主资料能够分享一下?
中景园电子的oled屏幕,IIC和SPIO兼容的型号
ID:438552 发表于 2019-8-30 15:13 | 只看该作者
原来是模拟IIC
ID:428034 发表于 2019-9-5 09:51 | 只看该作者
谢谢分享,感谢无私奉献的精神。
ID:409964 发表于 2019-9-25 10:31 | 只看该作者
确实下载不了,感觉是论坛系统问题:必须完善资料才能下载?可是资料已经很完善了啊,且不是QQ快捷登录~~
ID:242300 发表于 2019-10-3 03:31 | 只看该作者
一开始我也是怎么认为后来发现是设置的权限太高了70.
ID:242300 发表于 2019-10-3 03:32 | 只看该作者
楼主能把权限降点吗
ID:336427 发表于 2020-1-15 22:19 | 只看该作者
qweer 发表于 2019-10-3 03:32
楼主能把权限降点吗
怎么降权限
ID:336427 发表于 2020-6-21 21:46 | 只看该作者
对啊嘿嘿嘿
ID:591382 发表于 2020-8-25 15:10 | 只看该作者
我还没使用过HAL库,在接下来学习的时间里,我会好好探究一下。
ID:160860 发表于 2020-12-2 08:32 | 只看该作者
感谢楼主分享啊,资料很有用
ID:388135 发表于 2020-12-2 14:20 | 只看该作者
你这是I2C吗?
ID:248852 发表于 2020-12-11 12:51 | 只看该作者
感谢楼主 感谢楼主 感谢楼主
ID:336427 发表于 2021-1-6 17:35 | 只看该作者
SPI的,也有IIC
ID:686730 发表于 2021-1-7 20:53 | 只看该作者
厉害啊大神
ID:336427 发表于 2021-3-15 17:22 | 只看该作者
应该是SPI,弄错了,不好意思
正确来说是模拟SPI
