查看: 8130|回复: 16
这是单片机超声波测距,我想让它超过一定距离使蜂鸣器响,可蜂鸣器一直不响求详解
ID:301339 发表于 2018-5-7 16:40 | 显示全部楼层 |阅读模式
20黑币
#include<reg52.h>
#include<intrins.h>
sbit Lcd1602_RS = P2^6;
sbit Lcd1602_RW = P2^5;
sbit Lcd1602_EN = P2^7;
sbit Trig = P2^1;
sbit Echo = P2^0;
sbit beep = P2^3;
unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
unsigned int  time=0;
unsigned long S=0;
bit      flag =0;
uchar disdat[4] ={0,0,0,0,};
void delayms(uint ms)
    uchar i=100,j;
        for(;ms;ms--)
                while(--i)
                        j=10;
void Lcd1602_Write_com(uchar cmd)
        Lcd1602_RS=0;
        P0=cmd;
        delayms(1);
        Lcd1602_EN =1;
    delayms(1);
        Lcd1602_EN =0;
    delayms(1);
void Lcd1602_Write_Data(uchar shu)
        Lcd1602_RS=1;
        P0=shu;
        delayms(1);
        Lcd1602_EN =1;
    delayms(1);
        Lcd1602_EN =0;
        delayms(1);
void write_1602(uchar add,uchar sj)
        Lcd1602_Write_com(0x80+0x40+add);
        Lcd1602_Write_Data(sj) ;
void zifuchuan(uchar *ch)
    while(*ch!=0)
    Lcd1602_Write_Data(*ch++);
        delayms(5);
}        //仔细看一下那个程序
void feng()
   if((S>=50)||flag==1)
                beep = ~beep;
                beep = 1;                //取消报警
void LcdInit()
         Lcd1602_EN =0;
         Lcd1602_RW =0;
         Lcd1602_Write_com(0x38);
     Lcd1602_Write_com(0x0c);
         Lcd1602_Write_com(0x06);
         Lcd1602_Write_com(0x80);
         Lcd1602_Write_com(0x01);
         zifuchuan("cejujuli") ;
  void Conut(void)
         time=TH0*256+TL0;
         TH0=0;
         TL0=0;
         S=(time*1.7)/100;
         disdat[0]=S%1000/100;
         disdat[1]=S%1000%100/10;
         disdat[2]=S%1000%10%10;
         write_1602(1,disdat[0]+0x30);
         write_1602(2,disdat[1]+0x30);
         write_1602(3,disdat[2]+0x30);
         write_1602(5,'c');
     write_1602(6,'m');
void zd0() interrupt 1
    flag=1;
void  StartModule()
          Trig=1;
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          Trig=0;
void main(void)
         delayms(5);
     LcdInit();
         TMOD=0x01;
         TH0=0;
         TL0=0;
         ET0=1;
         EA=1;
         beep = 0;
         delayms(150);
         StartModule();
     while(!Echo);
         TR0=1;
     while(Echo);
         TR0=0 ;
         flag = 0;
                   feng ();
                        if(beep == 1);
                          Conut();
     delayms(5);
ID:244869 发表于 2018-5-7 18:07 | 显示全部楼层
有没有测试过你的测距结果是否准确?
ID:301339 发表于 2018-5-7 18:19 | 显示全部楼层
47253 发表于 2018-5-7 18:07
有没有测试过你的测距结果是否准确?
完全没有问题我用实物测得,现在只是蜂鸣器模块的问题这个蜂鸣器是无源的
ID:276761 发表于 2018-5-7 19:39 | 显示全部楼层
蜂鸣器取反之后(beep = ~beep;)没有延时,普通的无源蜂鸣器都要在特定的频率才会响,一般1~5KHZ
ID:301339 发表于 2018-5-7 23:20 | 显示全部楼层
能试着改一下吗,我加了延时没什么用啊,确实是需要频率但是这个不断取反是可以满足的。
ID:342731 发表于 2018-6-18 23:19 | 显示全部楼层
是不是io口没有接对。
ID:354047 发表于 2018-6-19 10:01 | 显示全部楼层
改过的程序能借用一下吗 大佬
ID:424310 发表于 2018-11-10 23:12 | 显示全部楼层
你无源接口电路有接三极管放大驱动吗,另外无源蜂螨器的驱动电压都要比较高。
ID:94031 发表于 2018-11-11 10:19 | 显示全部楼层
这和硬件也有关系,要有硬件原理图。
ID:408178 发表于 2018-11-11 15:26 | 显示全部楼层
你在进入feng()函数前,已经检测过一遍距离了,进入feng()之后不用在检测了   //建议
无缘蜂鸣器需要频率,你不断取反延时也可以,延时时间设置二十微秒,而且需要持续的给高低电平,可以给两个for循环,一个5次,一个100次,持续的高低电平时间不够的话,是不工作的
ID:303050 发表于 2018-11-11 19:40 | 显示全部楼层
能上原理图不?
ID:830647 发表于 2021-3-21 18:45 来自触屏版 | 显示全部楼层
你的是不响,我的是停不下来
ID:823677 发表于 2021-3-21 20:24 | 显示全部楼层
1.蜂鸣器必须加三极管驱动
2.你可以先用有源的蜂鸣器测试
ID:68800 发表于 2021-3-21 21:54 | 显示全部楼层
单片机驱动他激蜂鸣器的方式有两种:一种是PWM输出口直接驱动,另一种是利用I/O 定时翻转电平产生驱动波形对蜂鸣器进行驱动。
  PWM 输出口直接驱动是利用PWM输出口本身可以输出一定的方波来直接驱动蜂鸣器。在单片机的软件设置中有几个系统寄存器是用来设置PWM口的输出的,可以设置占空比、周期等等,通过设置这些寄存器产生符合蜂鸣器要求的频率的波形之后,只要打开PWM输出,PWM输出口就能输出该频率的方波,这个时候利用这个波形就可以驱动蜂鸣器了。比如频率为2000Hz的蜂鸣器的驱动,可以知道周期为500μs,这样只需要把PWM的周期设置为500μs,占空比电平设置为250μs,就能产生一个频率为2000Hz的方波,通过这个方波再利用三极管就可以去驱动这个蜂鸣器了。
  而利用I/O定时翻转电平来产生驱动波形的方式会比较麻烦一点,必须利用定时器来做定时,通过定时翻转电平产生符合蜂鸣器要求的频率的波形,这个波形就可以用来驱动蜂鸣器了。
    比如为2500Hz的蜂鸣器的驱动,可以知道周期为400μs,这样只需要驱动蜂鸣器的I/O口每200μs翻转一次电平就可以产生一个频率为2500Hz,占空比为1/2duty的方波,再通过三极管放大就可以驱动这个蜂鸣器了。
  驱动电路
  由于蜂鸣器的工作电流一般比较大,以致于单片机的I/O 口是无法直接驱动的*(但AVR可以驱动小功率蜂鸣器),所以要利用放大电路来驱动,一般使用三极管来放大电流就可以了。
    蜂鸣器驱动电路一般都包含以下几个部分:一个三极管、一个蜂鸣器、一个续流二极管和一个电源滤波电容
ID:420836 发表于 2021-3-22 02:15 | 显示全部楼层
无源蜂鸣器必须由交流信号驱动, 试着用频率为1kHz左右的。
ID:65956 发表于 2021-3-22 08:15 | 显示全部楼层
你应先计算和显示先来,然后再判断距离,超出才来响,看你这程序是先判断再来计算和显示,当然不会如你所愿了
ID:844772 发表于 2021-3-22 15:31 | 显示全部楼层
无源的要反复震荡才响啊,你只取反一次,发的那一声都难以察觉,我加了两句,频率控制在5k左右比较好,而且要反复调用这个函数百八十次,响个1秒半秒的才好。否则你就用有源的,你的程序就没问题。
void feng()
  {  beep = ~beep;
     delayms(1); //延时1ms
     beep = ~beep;
      beep = 1;      //取消报警
