查看: 5434|回复: 0
RX8010SJ驱动的关键代码,自己编写资源,与君共享
ID:81196 发表于 2021-4-30 11:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RX8010SJ.c的关键代码如下:
CLK_Time calendar;
/**************时钟芯片初始化************/
void RX8010_Init(void)
    CLK_IIC_Init();
/**************向时钟写入时间************/
void RX8010_Write_Time(CLK_Time SetRtc)
        u8 buf[7];
        buf[0] = SetRtc.second;
        RX8010_Write_Bytes(0x10,buf,1);
        buf[0] = SetRtc.minute;
        RX8010_Write_Bytes(0x11,buf,1);
        buf[0] = SetRtc.hour;
        RX8010_Write_Bytes(0x12,buf,1);
        buf[0] = RX8010_Week_Translate(WriteWeek ,CLK_Get_Week(2000 + BCD_To_Dec(SetRtc.year) ,BCD_To_Dec(SetRtc.month) ,BCD_To_Dec(SetRtc.day)));
        printf("W:%d\r\n",RX8010_Week_Translate(WriteWeek ,CLK_Get_Week(2000 + BCD_To_Dec(SetRtc.year) ,BCD_To_Dec(SetRtc.month) ,BCD_To_Dec(SetRtc.day))));
        RX8010_Write_Bytes(0x13,buf,1);
        buf[0] = SetRtc.day;
        RX8010_Write_Bytes(0x14,buf,1);
        buf[0] = SetRtc.month;
        RX8010_Write_Bytes(0x15,buf,1);
        buf[0] = SetRtc.year;
        RX8010_Write_Bytes(0x16,buf,1);
        buf[0] = 0x00;
        RX8010_Write_Bytes(0x1F,buf,1);
/**************从时钟读出时间************/
void RX8010_Read_Time (CLK_Time *GetRtc)
  u8 i;
        u8 buf[7];
        RX8010_Read_Bytes(0x10,buf,7);//读出温度值(器件地址,子地址,数据储存器,字节数)
        GetRtc->second = buf[0]&0x7f; //秒,低七位有效
        GetRtc->minute = buf[1]&0x7f; //分,低七位有效
        GetRtc->hour   = buf[2]&0x3f; //时,低六位有效
        GetRtc->week   = RX8010_Week_Translate(ReadWeek,buf[3]&0x7f); //周,低七位有效
        GetRtc->day    = buf[4]&0x3f; //日,低六位有效
        GetRtc->month  = buf[5]&0x1f; //月,低五位有效
        GetRtc->year   = buf[6]&0xff; //年,低八位有效
/**************向RAM指定地址写入数据************/
//slv_addr  器件地址
//sub_addr  内部寄存器地址
void RX8010_Read_Bytes(unsigned int sub_addr,unsigned char *s,unsigned char no)
        u8 i;
        CLK_IIC_Start(); //*发送启动信号*/
  if(CLK_IIC_Send_Byte(RX8010_WRITE) == 1)//*发送SLA+W*///0x64
                  CLK_IIC_Stop();
                        return;
        if(CLK_IIC_Send_Byte(sub_addr) == 1)//*发送SLA+W*///0x64
                  CLK_IIC_Stop();
                        return;
        CLK_IIC_Start();
        if(CLK_IIC_Send_Byte(RX8010_READ) == 1)
                  CLK_IIC_Stop();
                        return;
        for(i=0;i<no-1;i++)
                  *(s + i) = CLK_IIC_Read_Byte(1);
        *(s + no-1) = CLK_IIC_Read_Byte(0);
        CLK_IIC_Stop();
/**************从RAM指定地址读出数据************/
//slv_addr  器件地址
//sub_addr  内部寄存器地址
void RX8010_Write_Bytes(unsigned int sub_addr,unsigned char *s,unsigned char no)
        u8 i;
        CLK_IIC_Start();
                  CLK_IIC_Stop();
                        return;
                  CLK_IIC_Stop();
                  return;
        for(i=0;i<no;i++)
      if(CLK_IIC_Send_Byte(*(s + i)) == 1)
                                  CLK_IIC_Stop();
                                        return;
                        *s=CLK_IIC_Read_Byte(1);
      s++;
/**************获得现在是星期几************/
//设置时钟
//把输入的时钟转换为秒钟
//以1970年1月1日为基准
//1970~2099年为合法年份
//返回值:0,成功;其他:错误代码.
//月份数据表
u8 const Table_Week[12]={0,3,3,6,1,4,6,2,5,0,3,5}; //月修正数据表
//获得现在是星期几
//功能描述:输入公历日期得到星期(只允许1901-2099年)
//输入参数:公历年月日
//返回值:星期号
u8 CLK_Get_Week(u16 year,u8 month,u8 day)
        u16 temp2;
        u8 yearH,yearL;
        yearH=year/100;        yearL=year%100;
        // 如果为21世纪,年份数加100
        if (yearH>19)yearL+=100;
        // 所过闰年数只算1900年之后的
        temp2=yearL+yearL/4;
        temp2=temp2%7;
        temp2=temp2+day+Table_Week[month-1];
        if (yearL%4==0&&month<3)temp2--;
        return(temp2%7);
RX8010SJ.h的关键代码如下:
#define RX8010_READ   0x65
#define RX8010_WRITE  0x64
// register address , for RX-8010SJ
#define RX8010_ADDR_SECOND      ( 0x10 )
#define RX8010_ADDR_MINUTE      ( 0x11 )
#define RX8010_ADDR_HOUR        ( 0x12 )
#define RX8010_ADDR_WEEK        ( 0x13 )
#define RX8010_ADDR_DATE        ( 0x14 )
#define RX8010_ADDR_MONTH       ( 0x15 )
#define RX8010_ADDR_YEAR        ( 0x16 )
#define RX8010_ADDR_RSV17       ( 0x17 )
#define RX8010_ADDR_ALM_MINUTE  ( 0x18 )
#define RX8010_ADDR_ALM_HOUR    ( 0x19 )
#define RX8010_ADDR_ALM_WEEK    ( 0x1A )
#define RX8010_ADDR_ALM_DATE    ( 0x1A )
#define RX8010_ADDR_TMR_CNT0    ( 0x1B )
#define RX8010_ADDR_TMR_CNT1    ( 0x1C )
#define RX8010_ADDR_EXT_REG     ( 0x1D )
#define RX8010_ADDR_FLAG_REG    ( 0x1E )
#define RX8010_ADDR_CTRL_REG    ( 0x1F )
