查看: 3277|回复: 3
单片机驱动16*16点阵源程序(多种驱动方式)Proteus8.15仿真
设计了四套驱动方案:1、154+595驱动  2、154+P口驱动 3、595驱动  4、单片机P口驱动
程序为文字左移显示
供初学者参考
单片机16×16点阵(154+595驱动)源程序如下:
  1. #include <intrins.h>                //函数,应用于程序设计
  2. #include <reg52.h>                //单片机头文件
  3. /**********接口说明**********/
  4. sbit SER=P3^0;                        //DS 第14脚 串行数据输入
  5. sbit SRCLK=P3^1;                //SH_CP        第11脚 数据输入时钟线
  6. sbit LATCH=P3^2;                //ST_CP        第12脚 输出存储器锁存时钟线
  7. sbit OE=P3^3;                                //OE 第13脚 输出有效,低电平有效
  8.
  9. /**********全局变量**********/
  10. unsigned int word=1;                //数据位指针
  11. unsigned char column=0;                //列数,最大数16
  12. unsigned char time=5;                //走字速度,可修改
  13. unsigned char code segout[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //列扫描数组
  14. unsigned char code tab[]=
  15.         {
  16.                 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//空白位置
  17.                 /*以下文字开始*/
  18.                 0x00,0x01,0x00,0x02,0x03,0xEC,0x02,0x20,0x02,0x20,0x02,0x28,0xFE,0x26,0x12,0x20,0x12,0x28,0x12,0x26,0x12,0x20,0x13,0xE0,0x10,0x08,0x10,0x07,0x00,0x00,0x00,0x00,//点,1
  19.                 0x00,0x00,0x7F,0xFF,0x40,0x10,0x44,0x08,0x5B,0x10,0x60,0xE0,0x10,0x10,0x13,0x10,0x1D,0x10,0xF1,0x10,0x17,0xFF,0x11,0x10,0x11,0x10,0x11,0x10,0x10,0x10,0x00,0x00,0x00,0x00,//阵,2
  20.                 0x08,0x20,0x06,0x20,0x40,0x7E,0x31,0x80,0x00,0x01,0x7F,0xE2,0x40,0x0C,0x4F,0xF0,0x40,0x08,0x7F,0xE4,0x00,0x00,0x1F,0xE2,0x00,0x01,0xFF,0xFE,0x00,0x00,0x00,0x00,//测,3
  21.                 0x02,0x00,0x02,0x00,0x42,0x00,0x33,0xFC,0x00,0x08,0x09,0x14,0x09,0x06,0x09,0xFC,0x09,0x08,0x09,0x08,0xFF,0x80,0x08,0x70,0x88,0x0C,0x68,0x02,0x08,0x0F,0x00,0x00,0x00,0x00,//试,4
  22.                 0x24,0x10,0x24,0x60,0x25,0x80,0x7F,0xFF,0xC4,0x80,0x44,0x60,0x00,0x02,0x7C,0x92,0x44,0x92,0x44,0x92,0x44,0xFE,0x44,0x92,0x44,0x92,0x7C,0x92,0x00,0x82,0x00,0x00,0x00,0x00,//程,5
  23.                 0x00,0x02,0x00,0x0C,0x3F,0xF0,0x20,0x00,0x20,0x80,0x20,0x80,0x28,0x80,0xA8,0x82,0x6A,0x81,0x29,0xFE,0x2A,0x80,0x2C,0x80,0x28,0x80,0x20,0xA0,0x20,0xC0,0x00,0x00,0x00,0x00,//序,6
  24.                 /*以上文字结束*/
  25.                 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//空白位置
  26.                 0xBB,//结束码
  27.                 };
  28.
  29. void Delay(unsigned char ms)
  30.         {
  31.                 unsigned char x,y;
  32.                 for(x=ms;x>0;x--)
  33.                 for(y=124;y>0;y--);
  34.         }
  35.
  36. void SendByte(unsigned char dat)
  37.         {
  38.                 unsigned char i;
  39.                 for(i=0;i<8;i++)
  40.                 {
  41.                         if(dat&0x01==1)
  42.                                 {
  43.                                         SER=1;
  44.                                 }
  45.                                 else
  46.                                         {
  47.                                                 SER=0;
  48.                                         }
  49.                                         dat>>=1;
  50.                                         SRCLK=0;
  51.                                         _nop_();
  52.                                         _nop_();                //空指令
  53.                                         SRCLK=1;
  54.                 }
  55.         }
  56.
  57. void Out595(void)                //给出上升沿
  58.         {
  59.                 LATCH=0;                //输出存储器锁存时钟线置0
  60.                 _nop_();
  61.                 _nop_();                //空指令
  62.                 LATCH=1;                //输出存储器锁存时钟线至1,给上升沿
  63.         }
  64.
  65. void Send_Rank(unsigned int dat)
  66.         {
  67.                 SendByte(tab[2*dat-1]);                //09~16行数据选择
  68.                 SendByte(tab[2*dat-2]);                //01~08行数据选择
  69.         }
  70.
  71. void main()
  72.         {
  73.                 while(1)                //无限循环
  74.                         {
  75.                                 unsigned char temp=0;
  76.                                 for(temp=time;temp>0;temp--)                //循环扫描,可修改走字速度
  77.                                         {
  78.                                                 for(column=0;column<16;column++)                //循环扫描16列
  79.                                                         {
  80.        P2=column;                //列扫描程序
  81.        Send_Rank(word);                //行数据显示程序
  82.        Out595();                //给出上升沿
  83.        OE=0;                //74HC595输出有效
  84.        Delay(2);
  85.        OE=1;                //消隐
  86.        word++;                //数据位指针加1,准备显示下一行数据
  87.        }
  88.                                                         if(tab[2*word-2]==0xBB)                //判断下一个显示数据是否为结束码,若是往下执行
  89.        {
  90.        word=1;                //行数据重新赋值
  91.        }
  92.        else
  93.        {
  94.        word-=16;                //行数据返回前16行
  95.        }
  96.                                         }
  97.                                         word++;                //行数据加1,达到显示数据左移目的
  98.                                         }
  99.                                 }
Keil代码与Proteus8.15版本的仿真下载(注意:不能兼容其他版本 只能用8.15打开):
点阵.7z (338.8 KB, 下载次数: 53)
参与人数 1黑币 +80 收起 理由
admin + 80 共享资料的黑币奖励!
收藏收藏3 分享淘帖 顶 踩
ID:408289 发表于 2023-2-7 13:44 | 只看该作者
很经典的,非常值得看,反复看
ID:830831 发表于 2023-7-28 09:34 | 只看该作者
老兄,请问Proteus8.15在哪下载的呀?
ID:1054732 发表于 2025-2-16 22:50 | 只看该作者
里面程序是空的
