查看: 1489|回复: 5
求一个纯硬件呼吸灯的思路?
ID:1088099 发表于 2024-5-30 10:31 | 显示全部楼层 |阅读模式
想做点小玩意玩玩,突然就想到了呼吸灯,又想到了能不能纯硬件实现呼吸灯。各位大佬有没有思路?555定时器之类的
ID:123289 发表于 2024-5-30 13:54 | 显示全部楼层
不复杂:双稳,周期斜坡电流,驱动LED。
ID:401564 发表于 2024-5-30 14:30 | 显示全部楼层
运放输出三角波,后面加一个电压跟随器,输出加个电阻串联就可以了
不管是理论上还是实际上,这都是一个相对简单的电路的,我实际上也做过这个小电路
但是,意义何在?
ID:69038 发表于 2024-5-30 15:10 | 显示全部楼层
百度一下关键字:“LM358呼吸灯电路”,有你想要的。
ID:961114 发表于 2024-5-30 16:23 | 显示全部楼层
#include "reg51.h"
#include "intrins.h"
#define CYCLE       0x1000
sfr     P_SW2   =   0xba;
sfr     PWMSET      =   0xF1;
sfr     PWMCFG01    =   0xF6;
sfr     PWMCFG23    =   0xF7;
sfr     PWMCFG45    =   0xFE;
#define PWM0C       (*(unsigned int  volatile xdata *)0xFF00)
#define PWM0CH      (*(unsigned char volatile xdata *)0xFF00)
#define PWM0CL      (*(unsigned char volatile xdata *)0xFF01)
#define PWM0CKS     (*(unsigned char volatile xdata *)0xFF02)
#define PWM0TADC    (*(unsigned int  volatile xdata *)0xFF03)
#define PWM0TADCH   (*(unsigned char volatile xdata *)0xFF03)
#define PWM0TADCL   (*(unsigned char volatile xdata *)0xFF04)
#define PWM0IF      (*(unsigned char volatile xdata *)0xFF05)
#define PWM0FDCR    (*(unsigned char volatile xdata *)0xFF06)
#define PWM00T1     (*(unsigned int  volatile xdata *)0xFF10)
#define PWM00T1H    (*(unsigned char volatile xdata *)0xFF10)
#define PWM00T1L    (*(unsigned char volatile xdata *)0xFF11)
#define PWM00T2H    (*(unsigned char volatile xdata *)0xFF12)
#define PWM00T2     (*(unsigned int  volatile xdata *)0xFF12)
#define PWM00T2L    (*(unsigned char volatile xdata *)0xFF13)
#define PWM00CR     (*(unsigned char volatile xdata *)0xFF14)
#define PWM00HLD    (*(unsigned char volatile xdata *)0xFF15)
sfr     P0M1    =   0x93;
sfr     P0M0    =   0x94;
sfr     P1M1    =   0x91;
sfr     P1M0    =   0x92;
sfr     P2M1    =   0x95;
sfr     P2M0    =   0x96;
sfr     P3M1    =   0xb1;
sfr     P3M0    =   0xb2;
sfr     P4M1    =   0xb3;
sfr     P4M0    =   0xb4;
sfr     P5M1    =   0xc9;
sfr     P5M0    =   0xca;
void PWM0_Isr() interrupt 22
    static bit dir = 1;
    static int val = 0;
    if (PWMCFG01 & 0x08)
        PWMCFG01 &= ~0x08;                      //清中断标志
        if (dir)
            val++;
            if (val >= CYCLE) dir = 0;
            val--;
            if (val <= 1) dir = 1;
        _push_(P_SW2);
        P_SW2 |= 0x80;
        PWM00T2 = val;
        _pop_(P_SW2);
    P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
    PWMSET = 0x01;                              //使能PWM0模块(必须先使能模块后面的设置才有效)
    P_SW2 = 0x80;
    PWM0CKS = 0x00;                             // PWM0时钟为系统时钟
    PWM0C = CYCLE;                              //设置PWM0周期
    PWM00T1= 0x0000;
    PWM00T2= 0x0001;
    PWM00CR= 0x80;                              //使能PWM00输出
    P_SW2 = 0x00;
    PWMCFG01 = 0x05;                            //启动PWM0模块并使能PWM0中断
    EA = 1;
    while (1);
ID:996773 发表于 2024-5-31 14:58 | 显示全部楼层
楼主的想法无意义,这本来是在软件系统中比较优越的设计,例如,菜单设定栏可以用呼吸灯
效果表示当前选定,编程时钟调整分钟的时候,让分钟字体产生呼吸效果,其他字体常亮。楼主
仅仅让一盏灯实现硬件呼吸效果,怎么用,如何用,显摆都没技术含量
