查看: 1699|回复: 1
esp32-cam不断reboot
回帖奖励 5 黑币 回复本帖可获得 5 黑币奖励! 每人限 2 次
ID:1008389 发表于 2022-11-30 10:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
就是在调用esp_http_client_init()函数时,板子会出错,运行时不断reboot,有什么解决的办法吗?我已经困扰好久了
以下是相关的函数
  1.     esp_http_client_config_t config;
  2.     config.event_handler = ocr_http_event_handler;
  3.     config.buffer_size = 4 * 1024;
  4.     config.timeout_ms = 4000;
  5.     config.url  = temp_url.c_str();
  6.     config.cert_pem = root_ca;
  7.     Serial.print("config.url = ");
  8.     Serial.println(config.url);
  9.     esp_http_client_handle_t client = esp_http_client_init(&config);
  10.     esp_http_client_set_method(client, HTTP_METHOD_POST);
  11.     esp_http_client_set_header(client, "Content-Type", "application/x-www-form-urlencoded");
  12.     esp_http_client_set_post_field(client, temp_url.c_str(), sizeof(temp_url.c_str()));
以下报错的内容
  1. Core 1 register dump:
  2. PC      : 0x4008d858  PS      : 0x00060730  A0      : 0x800d7a48  A1      : 0x3ffb1e00
  3. A2      : 0x0000000f  A3      : 0x0000000b  A4      : 0x000000ff  A5      : 0x0000ff00
  4. A6      : 0x00ff0000  A7      : 0xff000000  A8      : 0x00000001  A9      : 0x00000000
  5. A10     : 0x3ffdf50c  A11     : 0x3f401614  A12     : 0x000000ff  A13     : 0x0000ff00
  6. A14     : 0x00ff0000  A15     : 0xff000000  SAR     : 0x00000019  EXCCAUSE: 0x0000001c
  7. EXCVADDR: 0x0000000f  LBEG    : 0x4008d879  LEND    : 0x4008d889  LCOUNT  : 0xfffffffd
  8. ELF file SHA256: 0000000000000000
  9. Backtrace: 0x4008d858:0x3ffb1e00 0x400d7a45:0x3ffb1e10 0x400d161b:0x3ffb1e30 0x400d1bb9:0x3ffb1ec0 0x400d537c:0x3ffb1fb0 0x400908de:0x3ffb1fd0
以下是报错的定位
  1. C:\Users\28032\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0\bin>xtensa-esp32-elf-addr2line -e python.ino.elf 0x4008d858:0x3ffb1e00 0x400d7a45:0x3ffb1e10 0x400d161b:0x3ffb1e30 0x400d1bb9:0x3ffb1ec0 0x400d537c:0x3ffb1fb0 0x400908de:0x3ffb1fd0
  2. /home/mak/e/p/newlib_old/newlib_xtensa-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/strlen.S:46
  3. /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_http_client/esp_http_client.c:335
  4. C:\Users\28032\Documents\Arduino\python/python.ino:163
  5. C:\Users\28032\Documents\Arduino\python/python.ino:283
  6. C:\Users\28032\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/main.cpp:30
  7. /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c:355 (discriminator 1)
ID:372579 发表于 2022-12-2 16:06 | 只看该作者
在报错定位处查查
