查看: 6401|回复: 4
AT89C51单片机电子密码锁代码与Proteus仿真图
  1. //包含头文件
  2. #include<REG51.h>
  3. #include<intrins.h>
  4. //宏定义
  5. #define LCM_Data P0   //将P0口定义为LCM_Data
  6. #define uchar unsigned char
  7. #define uint unsigned int
  8. //1602的控制脚
  9. sbit lcd1602_rs=P2^5;//RS引脚为寄存器(1-数据寄存器,0-命令寄存器)
  10. sbit lcd1602_rw=P2^6;//RW为读写操作引脚(1-读,0-写)
  11. sbit lcd1602_en=P2^7;//使能信号
  12. sbit Scl=P3^4;       //24c02串行时钟
  13. sbit Sda=P3^5;       //24c02串行数据
  14. sbit ALAM=P2^1;      //报警,蜂鸣器
  15. sbit KEY=P3^6;       //开锁
  16. bit pass=0;          //密码正确标志
  17. bit ReInputEn=0;     //重置输入允许标志
  18. bit s3_keydown=0;    //3秒按键标志位
  19. bit key_disable=0;   //锁定键盘标志
  20. unsigned char countt0,second; //t0中断次数,秒计数
  21. //void Delay5Ms(void);      //声明延时函数
  22. unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};//控盘扫描控制表
  23. //液晶显示数据数组
  24. unsigned char code start_line[] = {"password:       "};
  25. unsigned char code name[]       = {"===Coded Lock==="}; //显示名称
  26. unsigned char code Correct[]    = {"     correct    "};//输入正确
  27. unsigned char code Error[]      = {"      error     "};//输入错误
  28. unsigned char code codepass[]   = {"       pass     "};
  29. unsigned char code LockOpen[]   = {"       open     "};//open
  30. unsigned char code SetNew[]     = {"SetNewWordEnable"};
  31. unsigned char code Input[]      = {"input:          "};//input
  32. unsigned char code ResetOK[]    = {"ResetPasswordOK "};
  33. unsigned char code initword[]   = {"Init password..."};
  34. unsigned char code Er_try[]     = {"error,try again!"};
  35. unsigned char code again[]      = {"input again     "};
  36. unsigned char InputData[6];//输入密码暂存区
  37. unsigned char CurrentPassword[6]={0,0,0,0,0,0};//读取EEPROM密码暂存数组
  38. unsigned char TempPassword[6];
  39. unsigned char N=0;//密码输入位数计数
  40. unsigned char ErrorCont;//错误次数计数
  41. unsigned char CorrectCont;//正确输入计数
  42. unsigned char ReInputCont;//重新输入计数
  43. unsigned char code initpassword[6]={0,0,0,0,0,0};//输入管理员密码后将密码初始为000000
  44. unsigned char code adminpassword[6]={1,3,1,4,2,0};//输入管理员密码后将密码初始为000000
  45. #include<delay.h>
  46. //=========================5ms延时==========================
  47. void Delay5Ms(void)
  48. {
  49.         unsigned int TempCyc = 5552;
  50.         while(TempCyc--);
  51. }
  52. //===========================400ms延时============================
  53. void Delay400Ms(void)
  54. {
  55.         unsigned char TempCycA = 5;
  56.         unsigned int TempCycB;
  57.         while(TempCycA--)
  58.         {
  59.                 TempCycB=7269;
  60.                 while(TempCycB--);
  61.         }
  62. }
  63. //==========================================================
  64. //===========================24c02===========================
  65. //==========================================================
  66. void mDelay(uint t)//延时
  67. {
  68.         uchar i;
  69.         while(t--)
  70.         {
  71.                 for(i=0;i<125;i++)
  72.                 {;}
  73.         }
  74. }
  75. void Nop(void)//空操作
  76. {
  77.         _nop_();       //仅作延时用一条语句大约1us
  78.         _nop_();
  79.         _nop_();
  80.         _nop_();
  81. }
  82. /*****24c02程序参照24c02时序图
  83. /*起始条件*/
  84. void Start(void)
  85. {
  86.         Sda=1;
  87.         Scl=1;
  88.         Nop();
  89.         Sda=0;
  90.         Nop();
  91. }
  92. //停止条件
  93. void Stop(void)
  94. {
  95.         Sda=0;
  96.         Scl=1;
  97.         Nop();
  98.         Sda=1;
  99.         Nop();
  100. }
  101. //应答位
  102. void Ack(void)
  103. {
  104.         Sda=0;
  105.         Nop();
  106.         Scl=1;
  107.         Nop();
  108.         Scl=0;
  109. }
  110. //反向应答位
  111. void NoAck(void)
  112. {
  113.         Sda=1;
  114.         Nop();
  115.         Scl=1;
  116.         Nop();
  117.         Scl=0;
  118. }
  119. //发送数据子程序,Data为要求发送的数据
  120. void Send(uchar Data)
  121. {
  122.         uchar BitCounter=8;
  123.         uchar temp;
  124.         do
  125.         {
  126.                 temp=Data;//将待发送数据暂存temp
  127.                 Scl=0;
  128.                 Nop();
  129.                 if((temp&0x80)==0x80)//将读到的数据&0x80
  130.                         Sda=1;
  131.                 else
  132.                         Sda=0;
  133.                 Scl=1;
  134.                 temp=Data<<1;//数据左移
  135.                 Data=temp;//数据左移后重新赋值Data
  136.                 BitCounter--;//该变量减到0时,数据也就传送完成了
  137.         }
  138.         while(BitCounter);//判断是否传送完成
  139.         Scl=0;
  140. }
  141. //读一字节的数据,并返回该字节值
  142. uchar Read(void)
  143. {
  144.         uchar temp=0;
  145.         uchar temp1=0;
  146.         uchar BitCounter=8;
  147.         Sda=1;
  148.         do
  149.         {
  150.                 Scl=0;
  151.                 Nop();
  152.                 Scl=1;
  153.                 Nop();
  154.                 if(Sda)              //数据位是否为1
  155.                         temp=temp|0x01;    //为1 temp的最低位为1(|0x01,就是将最低位变为1)
  156.                 else                 //如果为0
  157.                         temp=temp&0xfe;    //temp最低位为0(&0xfe(11111110)最地位就是0)
  158.                 if(BitCounter-1)     //BitCounter减1后是否为真
  159.                 {
  160.                         temp1=temp<<1;     //temp左移
  161.                         temp=temp1;
  162.                 }
  163.                 BitCounter--;        //BitCounter减到0时,数据就接收完了
  164.         }while(BitCounter);    //判断是否接收完成
  165.         return(temp);
  166. }
  167. void WrToROM(uchar Data[],uchar Address,uchar Num)
  168. {
  169.         uchar i;
  170.         uchar *PData;
  171.         PData=Data;
  172.         for(i=0;i<Num;i++)
  173.         {
  174.                 Start();
  175.                 Send(0xa0);
  176.                 Ack();
  177.                 Send(Address+i);
  178.                 Ack();
  179.                 Send(*(PData+i));
  180.                 Ack();
  181.                 Stop();
  182.                 mDelay(20);
  183.         }
  184. }
  185. void RdFromROM(uchar Data[],uchar Address,uchar Num)
  186. {
  187.         uchar i;
  188.         uchar *PData;
  189.         PData=Data;
  190.         for(i=0;i<Num;i++)
  191.         {
  192.                 Start();
  193.                 Send(0xa0);
  194.                 Ack();
  195.                 Send(Address+i);
  196.                 Ack();
  197.                 Start();
  198.                 Send(0xa1);
  199.                 Ack();
  200.                 *(PData+i)=Read();
  201.                 Scl=0;
  202.                 NoAck();
  203.                 Stop();
  204.         }
  205. }
  206. //=============================LCD1603==============================
  207. #define yi 0x80   //LCD第一行的初始位置,因为LCD1602字符地址首位D7恒定为1
  208. #define er 0x80+0x40   //LCD第二行初始位置(因为第二行第一个字符位置地址是0x40)
  209. //-----------------延时函数,后面经常调用-------------------------------
  210. void delay(uint xms)//延时函数,有参函数
  211. {
  212.   uint x,y;
  213.         for(x=xms;x>0;x--)
  214.         for(y=110;y>0;y--);
  215. }
  216. //===============写指令======================
  217. void write_1602com(uchar com)   //液晶写入指令函数
  218. {
  219.         lcd1602_rs=0;   //数据/指令选择置为指令
  220.         lcd1602_rw=0;   //读写选择置为写
  221.         P0=com;         //送入数据
  222.         delay(1);
  223.         lcd1602_en=1;  //拉高使能端,为制造有效的下降沿做准备
  224.         delay(1);
  225.         lcd1602_en=0;  //en由高变低。产生下降沿,液晶执行命令
  226. }
  227. //=============================写数据==================================
  228. void write_1602dat(uchar dat)   //液晶写入数据函数
  229. {
  230.         lcd1602_rs=1;  //数据/指令选择置为数据
  231.         lcd1602_rw=0;  //读写选择置为写
  232.   P0=dat;        //送入数据
  233.         delay(1);
  234.         lcd1602_en=1;  //en置高电平,为制造下降沿做准备
  235.         delay(1);
  236.         lcd1602_en=0;  //en由高变低,产生下降沿,液晶执行命令
  237. }
  238. //===================================初始化=========================================
  239. void lcd_init(void)
  240. {
  241.         write_1602com(0x38);  //设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据
  242.         write_1602com(0x0c);  //开显示不显示光标
  243.   write_1602com(0x06);  //整屏不移动,光标自动右移
  244.   write_1602com(0x01);  //清显示
  245. }
  246. //========================================
  247. //=================================================================
  248. //===============将按键值编码为数值============================
  249. unsigned char coding(unsigned char m)
  250. {
  251.         unsigned char k;
  252.         switch(m)
  253.         {
  254.                 case(0x11):k=1;break;
  255.                 case(0x21):k=2;break;
  256.                 case(0x41):k=3;break;
  257.           case(0x81):k='A';break;
  258.           case(0x12):k=4;break;
  259.           case(0x22):k=5;break;
  260.           case(0x42):k=6;break;
  261.           case(0x82):k='B';break;
  262.           case(0x14):k=7;break;
  263.           case(0x24):k=8;break;
  264.           case(0x44):k=9;break;
  265.           case(0x84):k='C';break;
  266.           case(0x18):k='*';break;
  267.           case(0x28):k=0;break;
  268.           case(0x48):k='#';break;
  269.           case(0x88):k='D';break;
  270.         }
  271.         return(k);
  272. }
  273. //====================按键检测并返回按键值========================
  274. unsigned char keynum(void)
  275. {
  276.         unsigned char row,col,i;
  277.         P1=0xf0;  //所有行线为0,列线为输入
  278.         if((P1&0xf0)!=0xf0)  //一旦有键被按下,列线上的四位便不再全为1
  279.         {
  280.                 Delay5Ms();
  281.                 Delay5Ms();
  282.                 if((P1&0xf0)!=0xf0)  //如果有键被按下
  283.                 {
  284.                         col=P1^0xf0;   //确定列线,任何一个数(0,1)与1异或,结果取反,与0异或,结果为其本身
  285.                   i=0;
  286.                   P1=a[i];  //精确定位
  287.                   while(i<4)  //逐行扫描
  288.                         {
  289.                                 if((P1&0xf0)!=0xf0)
  290.                                 {
  291.                                         row=~(P1&0xff);  //确定行线
  292.                             break;  //已定位后提前退出
  293.                                 }
  294.                                 else
  295.                                 {
  296.                                          i++;
  297.                              P1=a[i];
  298.                                 }
  299.                         }
  300.                 }
  301.                 else
  302.                 {
  303.                         return 0;
  304.                 }
  305.                 while((P1&0xf0)!=0xf0);
  306.     return(col|row);  //行线与列线组合后返回
  307.         }
  308.         else return 0;  //无键按下时返回0
  309. }
  310. //===================一声提示音,表示有效输入=============================
  311. void OneAlam(void)
  312. {
  313.         ALAM=0;
  314.         Delay5Ms();
  315.         ALAM=1;
  316. }
  317. //====================两声提示音,表示操作成功===============================
  318. void TwoAlam(void)
  319. {
  320.         ALAM=0;
  321.         Delay5Ms();
  322.         ALAM=1;
  323.         Delay5Ms();
  324.         ALAM=0;
  325.         Delay5Ms();
  326.         ALAM=1;
  327. }
  328. //====================三声提示音,表示错误=============================
  329. void ThreeAlam(void)
  330. {
  331.         ALAM=0;
  332.         Delay5Ms();
  333.         ALAM=1;
  334.         Delay5Ms();
  335.         ALAM=0;
  336.         Delay5Ms();
  337.         ALAM=1;
  338.         Delay5Ms();
  339.         ALAM=0;
  340.         Delay5Ms();
  341.         ALAM=1;
  342. }
  343. //====================一直响,表示错误=============================
  344. void Alam_KeyUnable(void){
  345.                 ALAM=0;         //提示音一直响
  346. }
  347. //==================显示提示输入==============================
  348. void DisplayChar(void)
  349. {
  350.         unsigned char i;
  351.         if(pass==1)
  352.         {
  353.                 write_1602com(er);   //在二行开始显示
  354.                 for(i=0;i<16;i++)
  355.                 {
  356.                         write_1602dat(LockOpen[i]);   //显示open,开锁成功
  357.                 }
  358.         }
  359.         else
  360.         {
  361.                 if(N==0)   //输入密码位数
  362.                 {
  363.                         write_1602com(er);
  364.                   for(i=0;i<16;i++)
  365.                         {
  366.                                 write_1602dat(Error[i]);  //显示错误
  367.                         }
  368.                 }
  369.                 else
  370.                 {
  371.                         write_1602com(er);
  372.                         for(i=0;i<16;i++)
  373.                         {
  374.                                 write_1602dat(start_line[i]);   //显示开始输入
  375.                         }
  376.                 }
  377.         }
  378. }
  379.
  380. //========================确认键,并通过相应标志位执行相应功能
  381. void Ensure(void)
  382. {
  383.         unsigned char i,j;
  384.         RdFromROM(CurrentPassword,0,6);  //从24c02里读出存储密码
  385.         if(N==6)
  386.         {
  387.             if(ReInputEn==0)   //重置密码功能未开启
  388.                         {
  389.                                 if((CurrentPassword[0]==InputData[0])&&(CurrentPassword[1]==InputData[1])&&(CurrentPassword[2]==InputData[2])&&(CurrentPassword[3]==InputData[3])&&(CurrentPassword[4]==InputData[4]))
  390.                                 {
  391.                                         ErrorCont=0;   //只要密码正确了就将错误次数清零
  392.                                         CorrectCont++;   //输入正确变量++
  393.                                         if(CorrectCont==1)
  394.                                         {
  395.                                           write_1602com(er);
  396.                                           for(j=0;j<16;j++)
  397.                                           {
  398.                                                   write_1602dat(LockOpen[j]);  //显示open开锁画面
  399.                                           }
  400.                                           TwoAlam();   //操作成功提示音
  401.                                           KEY=0;   //开锁
  402.                                           pass=1;   //密码正确标志位置1
  403.                                           for(j=0;j<6;j++)  //将输入清除
  404.                                           {
  405.                                                   InputData[i]=0;   //开锁后将输入位清零
  406.                                           }
  407.                                   }
  408.                                         else  //当两次输入正确时,开启重置密码功能
  409.                                         {
  410.                                                 write_1602com(er);
  411.                                                 for(j=0;j<16;j++)
  412.                                                 {
  413.                                                         write_1602dat(SetNew[j]);  //显示重置密码界面
  414.                                                 }
  415.                                                 TwoAlam();   //操作成功提示
  416.                                                 ReInputEn=1;   //允许重置密码输入
  417.                                                 CorrectCont=0;  //正确计数器清零
  418.                                         }
  419.                                 }
  420.                                         else if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4]))
  421.                                         {
  422.                                                 WrToROM(initpassword,0,6);   //强制将初始密码写入24c02存储
  423.                                                 write_1602com(er);
  424.                                                 for(j=0;j<16;j++)
  425.                                                 {
  426.                                                         write_1602dat(initword[j]);  //显示初始化密码
  427.                                                 }
  428.                                                 TwoAlam();  //成功提示音
  429.                                                 Delay400Ms();  //延时400ms
  430.                                                 N=0;
  431.                                         }
  432.                                         else   //密码错误时
  433.                                         {
  434.                                                 CorrectCont=0;   //正确计数器清零,密码一旦错误,对密码正确次数重新清零
  435.                                                 ErrorCont++;   //错误次数++
  436.                                                 write_1602com(er);
  437.                                                 for(j=0;j<16;j++)
  438.                                                 {
  439.                                                         write_1602dat(Error[j]);   //显示错误信息
  440.                                                 }
  441.                                                 pass=0;
  442.                                                 TR0=1;   //开启定时
  443.                                                 key_disable=1;   //锁定键盘
  444.                                                 KEY=1;   //关闭锁
  445.                                                 if(ErrorCont==3)   //错误输入连续达3次时,报警并锁定键盘
  446.                                                 {
  447.                                                         write_1602com(er);
  448.                                                         for(i=0;i<16;i++)
  449.                                                         {
  450.        write_1602dat(Error[i]);
  451.                                                         }
  452.                                                 do
  453.                                                         Alam_KeyUnable();
  454.                                                 while(1);   //死循环,超过三次密码错误则一直报警并锁定键盘,直到重新运行或按下复位键
  455.                                           }
  456.                                 }
  457.                         }
  458.         else   //当已经开启重置密码功能时,而按下确认键
  459.         {
  460.                 write_1602com(er);
  461.                 for(j=0;j<16;j++)
  462.                 {
  463.                         write_1602dat(Er_try[j]);   //错误,请重新输入
  464.                 }
  465.                 ThreeAlam();   //错误提示音
  466.         }
  467. }
  468. else    //密码没有输入到6位时,按下确认键
  469. {
  470.         write_1602com(er);
  471.         for(j=0;j<16;j++)
  472.         {
  473.                 write_1602dat(Error[j]);   //显示错误
  474.         }
  475.         ThreeAlam();    //错误提示音
  476.         pass=0;
  477. }
  478. N=0;   //将输入数据计数器清零,为下一次输入做准备
  479. }
  480. //===========================重置密码===================================================================================
  481. void ResetPassword(void)
  482. {
  483.         unsigned char i;
  484.         unsigned char j;
  485.         if(pass==0)   //没开锁时
  486.         {
  487.                 pass=0;
  488.                 DisplayChar();   //显示开始输入password
  489.                 ThreeAlam();    //没开锁时按下重置密码报警3声
  490.         }
  491.         else   //开锁状态下才能进行密码重置
  492.         {
  493.                 if(ReInputEn==1)    //开锁状态下,ReInputEn置1,重置密码允许
  494.                 {
  495.                         if(N==6)   //输入6位密码
  496.                         {
  497.                                 ReInputCont++;    //重置密码次数计数
  498.                                 if(ReInputCont==1)   //输入一次密码时
  499.                                 {
  500.                                         OneAlam();
  501.                                         for(i=0;i<6;i++)
  502.                                         {
  503.                                                 TempPassword[i]=InputData[i];    //将第一次输入的数据暂存起来
  504.                                         }
  505.                                         write_1602com(er);
  506.                                         for(j=0;j<16;j++)
  507.                                         {
  508.                                                 write_1602dat(again[j]);    //显示再输入一次
  509.                                         }
  510.                                 }
  511.                                 if(ReInputCont==2)    //输入两次密码时
  512.                                 {
  513.                                         if((TempPassword[0]==InputData[0])&&(TempPassword[1]==InputData[1])&&(TempPassword[2]==InputData[2])&&(TempPassword[3]==InputData[3])&&(TempPassword[4]==InputData[4]))
  514.                                         {
  515.                                                 write_1602com(er);
  516.                                                 for(j=0;j<16;j++)
  517.                                                 {
  518.                                                         write_1602dat(ResetOK[j]);   //密码修改成功,显示
  519.                                                 }
  520.                                                 TwoAlam();     //操作成功显示
  521.                                                 WrToROM(TempPassword,0,6);   //将新密码写入24c02存储
  522.                                                 ReInputEn=0;   //关闭重置功能
  523.                                         }
  524.                                         else     //如果两次的密码不同
  525.                                         {
  526.                                                 write_1602com(er);
  527.                                                 for(j=0;j<16;j++)
  528.                                                 {
  529.                                                         write_1602dat(Error[j]);   //显示错误Error
  530.                                                 }
  531.                                                 ThreeAlam();   //错误提示
  532.                                                 pass=0;    //关锁
  533.                                                 ReInputEn=0;   //关闭重置功能
  534.                                                 ReInputCont=0;   //重置密码次数清零
  535.                                                 KEY=1;     //关闭锁
  536.                                                 DisplayChar();
  537.                                         }
  538.                                         ReInputCont=0;
  539.                                         CorrectCont=0;
  540.                                 }
  541.                                 N=0;   //输入数据位数计数器清零
  542.                         }
  543.                         else     //密码没有输入到6位时,按下重置键时
  544.                         {
  545.                                 write_1602com(er);
  546.                                 for(j=0;j<16;j++)
  547.                                 {
  548.                                         write_1602dat(Error[j]);  //显示错误
  549.                                 }
  550.                                 ThreeAlam();   //错误提示音
  551.                                 N=0;
  552.                         }
  553.                 }
  554.         }
  555. }
  556. //===========================输入密码错误超过三次,报警并锁死键盘=====
  557. //========================取消所有操作===
  558. void Cancel(void)
  559. {
  560.         unsigned char i;
  561.         unsigned char j;
  562.         //DisplayListChar(0,1,start_line);
  563.         write_1602com(er);
  564.         for(j=0;j<16;j++)
  565.         {
  566.                 write_1602dat(start_line[j]);   //显示开机输入密码界面
  567.         }
  568.         TwoAlam();   //提示音
  569.         for(i=0;i<6;i++)
  570.         {
  571.                 InputData[i]=0;   //将输入密码清零
  572.         }
  573.         KEY=1;   //关闭锁
  574.         ALAM=1;   //报警关
  575.         pass=0;   //密码正确标志清零
  576.         ReInputEn=0;   //重置输入允许标志清零
  577.         ErrorCont=0;   //密码错误输入次数清零
  578.         CorrectCont=0;   //密码正确输入次数清零
  579.         ReInputCont=0;   //重置密码输入次数清理
  580.         s3_keydown=0;
  581.         key_disable=0;    //锁定键盘标志清零
  582.         N=0;      //输入位数计数器清零
  583. }
  584. //=========================主函数==
  585. void main(void)
  586. {
  587.         unsigned char KEY,NUM;
  588.         unsigned char i,j;
  589.         P1=0xFF;     //P1口复位
  590.         TMOD=0x01;   //定义工作方式
  591.         TL0=0xB0;
  592.         TH0=0x3C;    //定时器赋初值,定时50ms
  593.         EA=1;        //打开中断总开关
  594.         ET0=1;       //打开中断允许开关
  595.         TR0=1;       //打开定时器开关
  596.         Delay400Ms();           //启动等待,等LCM讲入工作状态
  597.         lcd_init();            //LCD初始化
  598.         write_1602com(yi);    //日历显示固定符号从第一行第0个位置之后开始显示
  599.         for(i=0;i<16;i++)
  600.         {
  601.                 write_1602dat(name[i]);   //向液晶屏写开机画面
  602.         }
  603.         write_1602com(er);
  604.         for(i=0;i<16;i++)
  605.         {
  606.                 write_1602dat(start_line[i]);    //写输入密码等待界面
  607.         }
  608.         write_1602com(er+9);    //设置光标位置
  609.         write_1602com(0x0f);     //设置光标为闪烁
  610.         Delay5Ms();   //延时片刻(可不要)
  611.         N=0;   //初始化数据输入位数
  612.         while(1)   //进入循环
  613.         {
  614.                 if(key_disable==1)     //锁定键盘标志为1时
  615.                         Alam_KeyUnable();    //报警键盘锁
  616.                 else
  617.                         ALAM=1;             //关报警
  618.                 KEY=keynum();         //读按键的位置码
  619.                 if(KEY!=0)            //当有按键按下时
  620.                 {
  621.                         if(key_disable==1)   //锁定键盘标志为1时
  622.                         {
  623.                                 second=0;    //秒清零
  624.                         }
  625.                         else    //没有锁定键盘时
  626.                         {
  627.                                 NUM=coding(KEY);    //根据按键的位置将其编码,编码值赋值给NUM
  628.                                 {
  629.                                         switch(NUM)   //判断按键值
  630.                                         {
  631.                                                 case ('A'):      ;                   break;
  632.                                                 case ('B'):      ;                   break;
  633.                                                 case ('C'):      ;                   break;   //ABC是无意义按键
  634.                                                 case ('D'):ResetPassword();          break;   //重新设置密码
  635.                                                 case ('*'):Cancel();                 break;   //取消当前输入
  636.                                                 case ('#'):Ensure();                 break;   //确认键
  637.                                                 default:      //如果不是功能键按下时,就是数字键按下
  638.                                                 {
  639.                                                         if(N<6)   //当输入密码少于6位时,接受输入并保存,大于6位时则无效
  640.                                                         {
  641.        write_1602com(er);
  642.        for(i=0;i<16;i++)
  643.        {
  644.        write_1602dat(Input[i]);   //显示输入画面
  645.        }
  646.        OneAlam();   //按键提示音
  647.        for(j=0;j<=N;j++)
  648.        {
  649.        write_1602com(er+6+j);   //显示位数随输入增加而增加
  650.        write_1602dat('*');     //但不显示实际数字,用*代替
  651.        }
  652.        InputData[N]=NUM;   //将数字键的码赋值给InputData【】数组暂存
  653.        N++;   //密码位数加
  654.                                                         }
  655.                                                         else   //输入数据位数大于6后,忽略输入
  656.                                                         {
  657.        N=6;     //密码输入大于6位时,不接受输入
  658.        break;
  659.                                                         }
  660.                                                 }
  661.                                         }
  662.                                 }
  663.                         }
  664.                 }
  665.         }
  666. }
  667. //=====中断服务函数======
  668. void time0_int(void) interrupt 1    //定时器T0
  669. {
  670.         TL0=0xB0;
  671.         TH0=0x3C;    //定时器重新赋初值
  672.         countt0++;    //计时器变量加,加1次时50ms
  673.
  674.
Keil代码与Proteus仿真和word下载:
仿真程序文档.7z (1.33 MB, 下载次数: 107)
电子密码锁仿真
电子密码锁仿真
收藏收藏10 分享淘帖 顶顶2 踩踩
ID:1142224 发表于 2025-1-2 23:43 | 只看该作者
可以改成密码输入错误灯亮吗
ID:76027 发表于 2025-1-4 07:02 | 只看该作者
此程序我试过,少了关键语句,无法更改密码,其它的都没有问题。
ID:1151936 发表于 2025-5-28 12:07 来自触屏版 | 只看该作者
有没有大佬知道我弄完后为啥继电器LED跟蜂鸣报警器都没有反应啊
ID:1151936 发表于 2025-5-28 12:12 | 只看该作者
我用了后灯不亮,报警器也不响,有大佬知道为啥吗?
