查看: 912|回复: 3
PWM逻辑不对,输出抽搐
ID:734017 发表于 2025-9-9 01:47 | 显示全部楼层 |阅读模式
u8 xdata RF_Energy = 1;                        //强度
bit start_RF = 0;                        //开关
u8 power_Delay_flag =0;
u16 power_Delay_con=0;
u8 xdata CET_MIN= 0;        //强度
u8 xdata CET_MAX= 0;        //强度
u16 code CET_MIN_Energy_0[21]=  {0,176,192,208,224,240,256,272,288,304,320,336,352,368,384,400,416,432,448,464,480};        //RF强度
u16 code CET_MAX_Energy_100[21]={0,512,528,544,560,576,592,608,624,640,656,672,688,704,720,736,752,768,784,800,816};
u16 PWM_DUTY_CCR4 =0;
u16 PWM_DUTY_CCR4_temp =0;
#define PWM_PSC                         (24-1)        //12分频,0.5us  1M   0-65536从0开始计算 0不分频,1:2分频 fck_cnt=fck_psc/(PSCR[15:0]+1  输出频率=时钟/分频 从0开始
#define PWM_PERIOD                 999                        //周期100us                         FS/(PSC +1/PWMA_ARR+1)
#define PWM_DUTY                         0                        //占空10us
void PWMA_ADJ_Config()                                //ADJ可调
        PWMA_PS =  0x40;                                   //2.7 4n
        PWMA_PSCRH = (u16)(PWM_PSC >> 8);
        PWMA_PSCRL = (u16)(PWM_PSC);
        PWMA_CCER2 = 0x00; // 写 CCMRx 前必须先清零 CCERx 关闭通道
        PWMA_CCMR4 = 0x60; // 设置 CC2 为 PWMA 输出模式,PWM模式1
        PWMA_CCER2 = 0x40; // 使能 CC4n
        PWMA_CCR4H = (u16)(PWM_DUTY >> 8);  //设置占空比
        PWMA_CCR4L = (u16)(PWM_DUTY);
        PWMA_ARRH = (u16)(PWM_PERIOD >> 8); // 设置PWM周期
        PWMA_ARRL = (u16)(PWM_PERIOD);
        PWMA_ENO = 0x80; // 使能 PWM4n 端口输出
        //PWMA_BKR = 0x80; // 使能主输出
        //PWMA_CR1 = 0x01; // 启动PWM定时器
void  TM26_Isr() interrupt 26                         //PWMa更新中断
    if(PWMA_SR1 & 0x01)
      PWMA_SR1 &= ~0x01;
      PWMA_BKR &= ~0x80; // 使能主输出
    PWMA_CR1 &= ~0x01; // 关闭PWM定时器
void power_Delay()   //T0调用 1MS
      if(power_Delay_flag ==1 && ++power_Delay_con>=1000 )//PWM 停止一秒
          power_Delay_con=0;
          power_Delay_flag =2;
     else if(power_Delay_flag ==2 && ++power_Delay_con>=200)// 每200MS 加8us
            power_Delay_con=0;
            PWM_DUTY_CCR4_temp += 8;
            if(PWM_DUTY_CCR4_temp >=PWM_DUTY_CCR4 )
                PWMA_CCR4H =(u16)(PWM_DUTY_CCR4 >> 8);
                PWMA_CCR4L =(u16)(PWM_DUTY_CCR4);
                return ;
            else   //保险一点吧
              PWMA_CCR4H =(u16)(PWM_DUTY_CCR4_temp >> 8);
              PWMA_CCR4L =(u16)(PWM_DUTY_CCR4_temp);
              PWMA_CR1 = 0x01; // PWM定时器
void RF_Intensity_add()                                                //强度加  串口接收操作,放在while(1)
                if(RF_Energy<99)
                                        RF_Energy++;
          if( 1 == page )
              if(start_RF)
                  power_Delay_con=0;
                  power_Delay_flag =1;
                  PWMA_CCR4H =(u16)(0);
                  PWMA_CCR4L =(u16)(0);
                  PWMA_IER  =0x01;    //  更新中断    //问题在这里
              PWM_DUTY_CCR4 = CET_MIN_Energy_0[CET_MIN]+ ((CET_MAX_Energy_100[CET_MAX] - CET_MIN_Energy_0[CET_MIN] )* RF_Energy / 99 );  //百分比插入
void RF_on()        //RF开启-
        if(!start_RF)
        start_RF =1;
            Time_continued=0;
             F_otu =0;
             // PWMA_CR1 = 0x01; // PWM定时器
调整强度时,想用PWMA 更新中断,关闭PWMA。
这里我的理解是CCR从0开始到ARR。产生更新中断.因为不要能直接停止PWMA使能,需要跑一个或多个空周期。或者使用重复设数器跑几个空的再关闭使能。 51hei图片_20250909014609.jpg 我要控制这个,竟然没找到资料。控制开关电源输出电压,PWM转模拟
ID:879809 发表于 2025-9-9 03:33 | 显示全部楼层
LM321构成LPF把PWM转成DC。
ID:1160098 发表于 2025-9-9 11:01 | 显示全部楼层
PWM刚入门,同时学一学
ID:734017 发表于 2025-9-9 13:27 | 显示全部楼层
rundstedt 发表于 2025-9-9 03:33
LM321构成LPF把PWM转成DC。
大佬啊
听大佬一句,胜查百万卷
