查看: 11611|回复: 0
用openssl做rsa数字签名、校验,及n、e到PEM格式转换
ID:51024 发表于 2014-8-16 23:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
0. 产生测试用的文件
echo "hello world" >hello.txt
1. 做一下sha256 hash
$ openssl dgst -sha256 hello.txt
SHA256(hello.txt)= a948904f2f0f479b8f8197694b30184b0d2ed1c1cd2a1ec0fb85d299a192a447
或者,来个二进制输出
$ openssl dgst -sha256 -binary -out hello.sha256 hello.txt
$ od -v -An -t x1 hello.sha256
a9 48 90 4f 2f 0f 47 9b 8f 81 97 69 4b 30 18 4b
0d 2e d1 c1 cd 2a 1e c0 fb 85 d2 99 a1 92 a4 47
2. 创建rsa密钥
$ openssl genrsa -out key.pri -f4 2048
Generating RSA private key, 2048 bit long modulus
e is 65537 (0x10001)
3. 看一下密钥内容
$ openssl rsa -inform PEM -in key.pri -text
4. 导出公钥
$ openssl rsa -inform PEM -outform PEM -in key.pri -out key.pub -pubout
writing RSA key
5. 查看公钥
$ openssl rsa -inform PEM -in key.pub -pubin -text
6. hash并用私钥签名
$ openssl dgst -sha256 -out hello.sig -sign key.pri -keyform PEM hello.txt
$ od -v -An -t x1 hello.sig
7. 公钥校验
$ openssl dgst -sha256 -keyform PEM -verify key.pub -signature hello.sig hello.txt
Verified OK
上面这个命令只能输出"Verification OK"或者"Verification Failure"。如果想看到恢复的数据,可以用下面的命令:
$ openssl rsautl -in hello.sig -inkey key.pub -pubin -verify -hexdump
0000 - 30 31 30 0d 06 09 60 86-48 01 65 03 04 02 01 05   010...`.H.e.....
0010 - 00 04 20 a9 48 90 4f 2f-0f 47 9b 8f 81 97 69 4b   .. .H.O/.G....iK
0020 - 30 18 4b 0d 2e d1 c1 cd-2a 1e c0 fb 85 d2 99 a1   0.K.....*.......
0030 - 92 a4 47                                          ..G
或者不去掉pkcs填充的字节:
$ openssl rsautl -in hello.sig -inkey key.pub -pubin -verify -hexdump -raw
0000 - 00 01 ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
0010 - ff ff ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
0020 - ff ff ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
0030 - ff ff ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
0040 - ff ff ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
0050 - ff ff ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
0060 - ff ff ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
0070 - ff ff ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
0080 - ff ff ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
0090 - ff ff ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
00a0 - ff ff ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
00b0 - ff ff ff ff ff ff ff ff-ff ff ff ff ff ff ff ff   ................
00c0 - ff ff ff ff ff ff ff ff-ff ff ff ff 00 30 31 30   .............010
00d0 - 0d 06 09 60 86 48 01 65-03 04 02 01 05 00 04 20   ...`.H.e.......
00e0 - a9 48 90 4f 2f 0f 47 9b-8f 81 97 69 4b 30 18 4b   .H.O/.G....iK0.K
00f0 - 0d 2e d1 c1 cd 2a 1e c0-fb 85 d2 99 a1 92 a4 47   .....*.........G
或者来个二进制的文件:
$ openssl rsautl -in hello.sig -out hello.rec -inkey key.pub -pubin -verify
$ od -v -An -t x1 hello.rec
30 31 30 0d 06 09 60 86 48 01 65 03 04 02 01 05
00 04 20 a9 48 90 4f 2f 0f 47 9b 8f 81 97 69 4b
30 18 4b 0d 2e d1 c1 cd 2a 1e c0 fb 85 d2 99 a1
92 a4 47
最后32个字节是hello.txt的sha256值,前面19个字节是按照pkcs规范添加的用来标示hash算法的数据。
有时候你拿到的公钥可能不是PEM格式的,而只是一个n和e,openssl的标准命令是不能直接用的,也没有提供转换命令(存疑,反正我是没发现比自己写个小程序更简单的办法)。这时候就需要用openssl库自己写个小程序来做转换了。好在这个程序写起来不麻烦,用到的几个函数在下面几个头文件中定义:
openssl/bn.h、openssl/rsa.h、openssl/pem.h
