#include<reg52.h>
sbit key1 = P3^4;
sbit key2 = P3^5;
sbit pwm1 = P0^1;
unsigned int target =12,percent = 0;
void Timer0Initial();
void initial_Timer();
void delay(unsigned int x);
void keyscan();
void keyscan()
delay(30);
if(key1 == 0)
delay(10);
if(key1 == 0)
if(target >= 10)
target -= 1;
if(key2 == 0)
delay(10);
if(key2 == 0)
if(target <= 20)
target += 1;
void initial()
key1 = 1;
key2 = 1;
initial_Timer();
TH0 = (65536-65)/256;
TL0 = (65536-65)%256;
EA = 1;
ET0 = 1;
TMOD = 0x01;
Timer0Initial();
TR0 = 1;
unsigned int i,j;
for(i=x;i>0;i--)
for(j=110;j>0;j--);
initial();
keyscan();
void Timer0() interrupt 1 using 0
percent+=1;
if(percent<=target)
pwm1=1;
pwm1=0;
if(percent==200)
percent=0;
Timer0Initial();
