查看: 7370|回复: 1
MPLAB IDE老是弹出一个窗口,怎么解决?the extended cpu mode configuration bit is...
ID:82438 发表于 2015-6-15 22:45 | 显示全部楼层 |阅读模式
使用pic18F66J60单片机编译时,总是提示the extended cpu mode configuration bit is enabled, but the program that was loaded was not built using extended cpu instructions.therefore,your code may not work properly.  加了这条指令#pragma config XINST = OFF也不管用。哪位大神帮忙解答一下?
ID:109298 发表于 2016-3-17 10:56 | 显示全部楼层
请问您的问题解决了么,我也遇到这样的问题了。我的QQ1399791321,谢谢
