查看: 1950|回复: 0
nvidia install problem(网摘)
ID:107189 发表于 2016-3-6 16:03 | 显示全部楼层 |阅读模式
I have Ubuntu 14.04 64bit and NVIDIA Geforce GTX 960 that caused me a lot of problems to install. Hopefully this can help somebody:
in terminal write
sudo apt-get update && sudo apt-get upgrade && sudo apt-get dist-upgrade && sudo apt-get install build-essential && sudo apt-get install linux-source && sudo apt-get install linux-headers-generic
sudo gedit /etc/default/grub #change line "GRUB_CMDLINE_LINUX_DEFAULT..."-line to
GRUB_CMDLINE_LINUX_DEFAULT="nouveau.blacklist=1     quiet splash nomodeset" #(forces low-level graphics to ensure putty does     not give black screen)
sudo update-grub2
sudo apt-get remove nvidia* && sudo apt-get autoremove #ensures no former installation clashes with new install
sudo reboot
After reboot get correct nvidia-driver (chose graphic-card and OS) at “wwwnvidiacom/Download/index.aspx?lang=en-us" (or search webb with “nvidia download”). Right-click on downloaded file and change if to executable.
sudo gedit /etc/modprobe.d/blacklist.conf #add these lines at the end:
blacklist vga16fb
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
blacklist lbm-nouveua
options nouveau modeset=0
alias nouveau off
alias lbm-nouveau off
Open a putty-terminal with Ctrl + Alt     + F1
sudo service lightdm stop #stops graphic session to enable nvidiainstallation
cd Downloads #(or wherever you downloaded your nvidia-file)
sudo ./{the downloadedfilename.run} #follow installation-instructions (normally yes to all)sudo nvidia-xconfig #(if you did not chose “yes” to this in the installation”
sudo nano /etc/default/grub # change the "GRUB_CMBLINE_LINUX_DEFAULT..."-line to below:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset”
sudo update-grub2 #update grub!
sudo reboot
