查看: 4062|回复: 2
DHT11温湿度arduino程序
DHT11温湿度检测程序
arduino单片机源程序如下:
  1. #include "dht.h"
  2.
  3. #define TIMEOUT 10000
  4. #define pin     D2
  5. // return values:
  6. //  0 : OK
  7. // -1 : checksum error
  8. // -2 : timeout
  9. int dht::read11()
  10. {
  11.     // READ VALUES
  12.    int rv = read();
  13.     if (rv != 0) return rv;
  14.     // CONVERT AND STORE
  15.     humidity    = bits[0];  // bit[1] == 0;
  16.     temperature = bits[2];  // bits[3] == 0;
  17.
  18.     // TEST CHECKSUM
  19.    uint8_t sum = bits[0] + bits[2]; // bits[1] && bits[3] both 0
  20.     if (bits[4] != sum) return -1;
  21.     return 0;
  22. }
  23. // return values:
  24. //  0 : OK
  25. // -1 : checksum error
  26. // -2 : timeout
  27. int dht::read22()
  28. {
  29.     // READ VALUES
  30.     int rv = read();
  31.     if (rv != 0) return rv;
  32.
  33.     // CONVERT AND STORE
  34.     humidity    = word(bits[0], bits[1]) * 0.1;
  35.
  36.     int sign = 1;
  37.     if (bits[2] & 0x80) // negative temperature
  38.     {
  39.         bits[2] = bits[2] & 0x7F;
  40.         sign = -1;
  41.     }
  42.     temperature = sign * word(bits[2], bits[3]) * 0.1;
  43.
  44.   // TEST CHECKSUM
  45.     uint8_t sum = bits[0] + bits[1] + bits[2] + bits[3];
  46.     if (bits[4] != sum) return -1;
  47.     return 0;
  48. }
  49. // return values:
  50. //  0 : OK
  51. // -2 : timeout
  52. int dht::read()
  53. {
  54.     // INIT BUFFERVAR TO RECEIVE DATA
  55.     uint8_t cnt = 7;
  56.     uint8_t idx = 0;
  57.    // EMPTY BUFFER
  58.    for (int i=0; i< 5; i++) bits[i] = 0;
  59.
  60.     // REQUEST SAMPLE
  61.    pinMode(pin, OUTPUT);
  62.    digitalWrite(pin, LOW);
  63.    delay(20);
  64.    digitalWrite(pin, HIGH);
  65.    delayMicroseconds(40);
  66.    pinMode(pin, INPUT);
  67.
  68.    // GET ACKNOWLEDGE or TIMEOUT
  69.    unsigned int loopCnt = TIMEOUT;
  70.    while(digitalRead(pin) == LOW)
  71.       if (loopCnt-- == 0) return -2;
  72.
  73.     loopCnt = TIMEOUT;
  74.     while(digitalRead(pin) == HIGH)
  75.        if (loopCnt-- == 0) return -2;
  76.
  77.     // READ THE OUTPUT - 40 BITS => 5 BYTES
  78.     for (int i=0; i<40; i++)
  79.     {
  80.         loopCnt = TIMEOUT;
  81.         while(digitalRead(pin) == LOW)
  82.             if (loopCnt-- == 0) return -2;
  83.         unsigned long t = micros();
  84.
  85.         loopCnt = TIMEOUT;
  86.         while(digitalRead(pin) == HIGH)
  87. ……………………
  88. …………限于本文篇幅 余下代码请从51黑下载附件…………
temperature.rar (1.77 KB, 下载次数: 24)
ID:234938 发表于 2018-4-12 15:41 | 只看该作者
看起来挺高大上的,过来学习一下。
ID:315637 发表于 2018-4-24 20:00 | 只看该作者
楼主能不能单独发一份???thanks。
