查看: 6600|回复: 14
基于stc89c52的4位数码管电子钟
ID:262 发表于 2014-10-21 01:45 | 显示全部楼层 |阅读模式
/*                                              TabLee                                                 */
#include<reg52.h>
#define uchar unsigned char;
#define uint unsigned int;
uchar position;
uchar tt;
uchar second;
uchar minute;
uchar hour;
uchar code table[]={0xc0,0xf9,0xa4,0x99,0x92,0x82,0xf8,0x80,0x90};
sbit smg_q=P1^0;
sbit smg_b=P1^1;
sbit smg_s=P1^2;
sbit smg_g=P1^3;
sbit key1=P3^7;
sbit key2=P3^6;
sbit key3=P3^5;
sbit key4=P3^4;
void keyscan();
void display(unsigned char hour,unsigned char minute);
void delay(unsigned int timer);
void init();
init();
if(tt==20)
tt=0;
second++;
if(second==60)
second=0;
minute++;
if(minute==60)
minute=0;
hour++;
if(hour==24)
hour=0;
display(hour,minute);
delay(1);
void keyscan()
if(key1==0)
TR0=0;
hour++;
if(hour==24)
hour=0;
delay(200);
TR0=1;
if(key2==0)
TR0=0;
hour--;
if(hour<0)
hour=23;
delay(200);
TR0=1;
if(key3==0)
TR0=0;
minute++;
if(minute==60)
minute=0;
delay(200);
TR0=1;
if(key4==0)
TR0=0;
minute--;
if(minute<0)
minute=59;
delay(200);
TR0=1;
void init()
tt=0;
position=0;
second=0;
minute=0;
hour=0;
smg_q=1;
smg_b=1;
smg_s=1;
smg_g=1;
key1=1;
key2=1;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void t0() interrupt 1
tt++;
P0=0xFF;
switch(position)
case 0:
smg_g=1;
smg_q=0;
P0=table[hour/10];
break;
case 1:
smg_q=1;
smg_b=0;
P0=table[hour%10];
if(tt>=10)
P0&=0x7f;
break;
case 2:
smg_b=1;
smg_s=0;
P0=table[minute/10];
break;
case 3:
smg_s=1;
smg_g=0;
P0=table[minute%10];
break;
position++;
if(position>3)
position=0;
void delay(unsigned int time)
unsigned int x,y;
for(x=time;x>0;x++)
for(y=110;y>0;y--);
ID:66787 发表于 2014-10-24 21:52 | 显示全部楼层
太凑合了,给点说明或者图文
ID:70614 发表于 2015-5-1 13:31 | 显示全部楼层
有电路图吗我想制作个时钟
ID:79329 发表于 2015-5-11 13:55 | 显示全部楼层
楼主真好
ID:79329 发表于 2015-5-11 13:56 | 显示全部楼层
谢谢楼主的分享
ID:56948 发表于 2015-5-17 10:36 | 显示全部楼层
谢谢楼主的分享
ID:80035 发表于 2015-5-17 11:17 | 显示全部楼层
有电路图吗
ID:86126 发表于 2015-7-19 11:45 | 显示全部楼层
不好看懂啊,可以再详细点吗?
ID:97771 发表于 2015-12-1 21:16 | 显示全部楼层
求电路图
ID:98731 发表于 2015-12-7 20:46 | 显示全部楼层
程序有个标注就好了
ID:98193 发表于 2015-12-21 23:03 | 显示全部楼层
我和楼主的思路大体相同,但是在调时间的时候某一位是怎么闪烁的呢。这个程序怎么写。没有闪烁不确定调哪一位啊
ID:77498 发表于 2017-5-4 15:30 | 显示全部楼层
求电路图
ID:77498 发表于 2017-5-4 15:40 | 显示全部楼层
有电路图吗我想制作个时钟
ID:192615 发表于 2017-5-7 16:54 | 显示全部楼层
谢谢楼主的分享
ID:197820 发表于 2017-5-7 17:35 | 显示全部楼层
楼主分享一个电路图啊
