查看: 4075|回复: 12
PY32F403C驱动SPI液晶屏2.8寸LVGL8演示程序
ID:14088 发表于 2024-12-8 21:39 | 显示全部楼层 |阅读模式
普冉的M4单片机系列,资源丰富,价格便宜。实在是太香了,用来驱动2.8寸SPI屏跑LVGL8超值划算。
* 文件名程: main.c
* 作    者: 东莞-邓凯歌
* 功    能: 主程序
* 硬    件: PY32F403C_KFB_V0.1
* 说明:
* 软件版本 V1.0.1(2024/4/7 16:02)
#include "main.h"
#include "user_uart.h"
#include "user_dma.h"
#include "user_timer.h"
#include "user_gpio.h"
#include "user_spi.h"
#include "lcd_driver.h"
#include "user_touch.h"
#include "lv_port_disp.h"
#include "lv_port_indev.h"
#include "lvgl.h"
#include "gui_guider.h"
#include "events_init.h"
#include "custom.h"
lv_ui guider_ui;
uint8_t aRxBuffer,bRxBuffer;
/* Private define ------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private user code ---------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
static void APP_SystemClockConfig(void);
uint32_t senpwm = 120;
extern uint8_t pwmbit;
uint8_t lcdbit;
  * @brief  Main program.
  * @retval int
int main(void)
        /* Reset of all peripherals, Initializes the Systick. */
        HAL_Init();
        /* Configure the system clock */
        APP_SystemClockConfig();
        MX_DMA_Init();
        MX_SPI1_Init();
        MX_SPI2_Init();
        MX_GPIO_Init();
//        APP_GpioConfig();
//        MX_USART1_UART_Init();
        MX_TIM1_Init();
        MX_TIM2_Init();
//        MX_TIM6_Init();
//        HAL_UART_Receive_IT(&huart1,&aRxBuffer,1);
//        LCD_Init();
////        LCD_Fill(0,0,320,240,RED);
////        LCD_Fill(0,0,320,240,WHITE);
//        LCD_DMA_Fill(0,0,320,240,RED);
//        LCD_DMA_Fill(0,0,320,240,WHITE);
        lv_init();
    lv_port_disp_init();
        lv_port_indev_init();
//        lv_example_textarea_1();
        custom_init(&guider_ui);         //自定义的功能要放在UI初始化前面,切记!!!!
        setup_ui(&guider_ui);
    events_init(&guider_ui);
        while (1)
                if( tp_dev.calibit)
                  TP_Adjust();
                }else{
                  lv_timer_handler();
  * @brief  System Clock Configuration
  * @param  None
  * @retval None
        RCC_OscInitTypeDef  OscInitstruct = {0};
        RCC_ClkInitTypeDef  ClkInitstruct = {0};
        OscInitstruct.OscillatorType  = RCC_OSCILLATORTYPE_HSE | RCC_OSCILLATORTYPE_HSI | RCC_OSCILLATORTYPE_LSE |
        RCC_OSCILLATORTYPE_LSI | RCC_OSCILLATORTYPE_HSI48M;
        OscInitstruct.HSEState        = RCC_HSE_ON;                               /* Enable HSE */
        OscInitstruct.HSEFreq         = RCC_HSE_16_32MHz;                         /* HSE working frequency range: 16M~32M */
        OscInitstruct.HSI48MState     = RCC_HSI48M_OFF;                           /* Disable HSI48M */
        OscInitstruct.HSIState        = RCC_HSI_ON;                               /* Enable HSI */
        OscInitstruct.LSEState        = RCC_LSE_OFF;                              /* Disable LSE */
//        OscInitstruct.LSEDriver       = RCC_LSEDRIVE_HIGH;                     /* Drive capability level: High */
        OscInitstruct.LSIState        = RCC_LSI_OFF;                              /* Disable LSI */
        OscInitstruct.PLL.PLLState    = RCC_PLL_ON;                              /* Disable PLL */
        OscInitstruct.PLL.PLLSource   = RCC_PLLSOURCE_HSE;                    /* PLL clock source: HSE */
        OscInitstruct.PLL.PLLMUL      = RCC_PLL_MUL7;                         /* PLL multiplication factor: 6 */
        /* Configure Oscillators */
        if(HAL_RCC_OscConfig(&OscInitstruct) != HAL_OK)
                Error_Handler();
        ClkInitstruct.ClockType       = RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
        ClkInitstruct.SYSCLKSource    = RCC_SYSCLKSOURCE_PLLCLK;                 /* SYSCLK source select as HSE */
        ClkInitstruct.AHBCLKDivider   = RCC_SYSCLK_DIV1;                      /* AHB clock not divided */
        ClkInitstruct.APB1CLKDivider  = RCC_HCLK_DIV1;                        /* APB1 clock not divided */
        ClkInitstruct.APB2CLKDivider  = RCC_HCLK_DIV2;                        /* APB1 clock divided by 2 */
        /* Configure Clocks */
        if(HAL_RCC_ClockConfig(&ClkInitstruct, FLASH_LATENCY_6) != HAL_OK)
                Error_Handler();
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
void Error_Handler(void)
  /* Infinite loop */
  while (1)
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     for example: printf("Wrong parameters value: file %s on line %d\r\n", file, line)  */
  /* Infinite loop */
  while (1)
#endif /* USE_FULL_ASSERT */
PY32F403C_KFB_LVGL028(V0.1).7z
5.52 MB, 下载次数: 0, 下载积分: 黑币 -5
Schematic_PY32F403C_KFB_V0.1.pdf
151.71 KB, 下载次数: 0, 下载积分: 黑币 -5
ID:619259 发表于 2024-12-9 08:51 | 显示全部楼层
我用STC32驱动过这个屏,主屏上到30MHz,刷新速度非常快,不知楼主的这个案例速度如何?
ID:14088 发表于 2024-12-9 14:21 | 显示全部楼层
F403C 理论上SPI的频率最高达到36M
ID:691028 发表于 2024-12-20 13:23 | 显示全部楼层
不知道是什么原因,普冉的单片机死活下载不进固件,研究了大半个月都没成功
ID:14088 发表于 2024-12-23 09:21 | 显示全部楼层
降低SWD下载速度改成500K试试
ID:691028 发表于 2024-12-23 17:51 | 显示全部楼层
换了三个DAP和ULINK都试过了,能识别得到芯片,但无法下载固件,尝试问了店家,店家也不清楚
ID:378108 发表于 2024-12-31 17:16 | 显示全部楼层
eyancool 发表于 2024-12-23 09:21
降低SWD下载速度改成500K试试
下载器到 MCU 的线太长了,那个线 大于 5cm 下载就会不可靠
ID:468456 发表于 2025-4-15 11:48 | 显示全部楼层
请问一下你的py32F403能读取内存卡吗?我用STM32能读,但是用py32没法读取
ID:14088 发表于 2025-4-25 18:54 | 显示全部楼层
我没用到PY32F403的SDIO功能,看一下PY32F403官方的开发注意事项说明.不能全照STM32来
ID:1066795 发表于 2025-6-17 17:39 | 显示全部楼层
请问您这个ui是用nxp的上位机编译模拟的么
ID:14088 发表于 2025-7-4 08:15 | 显示全部楼层
是的,用NXP的LVGL UI上位机软件
ID:344943 发表于 2025-7-22 16:47 | 显示全部楼层
感谢分享。
ID:344943 发表于 2025-7-22 16:48 | 显示全部楼层
谢谢分享
