查看: 5784|回复: 5
esp8266控制智能小车
ID:198428 发表于 2017-5-8 23:02 | 显示全部楼层 |阅读模式
#include<reg52.h>
//#include<reg51.h>
sbit led1=P1^0;
sbit led2=P1^1;
sbit beef=P3^6;
sbit relay=P0^0;
uchar k = 0;
uchar Receive;
uchar Receive_table[30];
void Delay_Ms(uint ms)
uint i,j;
for(i = ms; i > 0; i--)
for(j = 110; j > 0; j--);
void Delay_Us(uchar us)
while(us--);
void InitUART(void)
        TMOD=0x21;
        TH0=(65536-87)/256;
        TL0=(65536-87)%256;
        EA=1;
        ET0=1;
        TR0=0;
//    SCON = 0x50;
//    TH1 = 0xFA;
//    TL1 = TH1;
//    PCON = 0x80;
//    ES = 1;
//    EA = 1;
//    TR1 = 1;
SCON = 0X50;
TH2=0XFF;
TL2=0XFD;
RCAP2H=0XFF;
RCAP2L=0XFD;
TCLK=1;
RCLK=1;
C_T2=0;
EXEN2=0;
TR2=1;
ES = 1;
EA = 1;
void Uart_Send_Char(uchar dat)
ES = 0;
TI = 0;
SBUF = dat;
while(!TI);
TI = 0;
ES = 1;
void Uart_Send_String(uchar *string)
    while(*string)
      Uart_Send_Char(*string++);
      Delay_Us(5);
    Delay_Ms(1000);
void ESP8266_Send(uchar *puf)
        Delay_Ms(20);
   Uart_Send_String("AT+CLDSENDRAW=9\r\n");
        Delay_Ms(20);
   Uart_Send_String(puf);
void ESP8266_Init()
//   Uart_Send_String("AT+CIPMUX=1\r\n");
//   Uart_Send_String("AT+CIPSERVER=1,5000\r\n");
           Uart_Send_String("AT+CLDSTART\r\n");
void main(void)
          led1=0;
          led2=0;
    InitUART();
          ESP8266_Init();
          if((Receive_table[0]=='+')&&(Receive_table[1]=='C')&&(Receive_table[2]=='R'))//MCU???????+IPD???????0\1???????
    if((Receive_table[3]=='A')&&(Receive_table[6]=='1'))
        switch(Receive_table[8])
          case '0':
                 led1=1;
                 ESP8266_Send("LED1 OPEN\r\n");
                                               Receive_table[8]='f';
                 break;
          case '1':
                 led1=0;
                 ESP8266_Send("LED1  OFF\r\n");
                 break;
                                        case '2':
                 led2=1;
                 ESP8266_Send("LED2 OPEN\r\n");
                 break;
          case '3':
                 led2=0;
                 ESP8266_Send("LED2  OFF\r\n");
                 break;
                                        case '4':TR0=1;break;
                                        case '5':TR0=0;break;
          case '6':
                 relay=0;
                 ESP8266_Send("relayOPEN\r\n");
                 break;
                                        case '7':
                 relay=1;
                 ESP8266_Send("relay OFF\r\n");
                 break;
                                  default:;
void UARTInterrupt(void) interrupt 4
        EA=0;
    if(RI==1)
      RI = 0;
                        Receive = SBUF;
      Receive_table[k++] = Receive;
      if((Receive_table[k-1] == '\n') || (k == 29))
         k = 0;
   EA=1;
void time_0()interrupt 1
        uchar num;
        TH0=(65536-87)/256;
        TL0=(65536-87)%256;
        num++;
        if(num==2)
                beef=~beef;
                num=0;
ID:106272 发表于 2017-9-22 09:29 | 显示全部楼层
有没有详细资料
ID:236757 发表于 2017-10-5 19:30 | 显示全部楼层
能问下esp8266传输数据中间有卡顿的原因是什么?我的q是1632401541
ID:228875 发表于 2017-10-14 14:26 | 显示全部楼层
AT+CLDSENDRAW=9这条指令是什么意思
ID:79544 发表于 2017-11-27 09:15 | 显示全部楼层
这个程序可用吗?我感觉缺点什么?
ID:243748 发表于 2017-12-21 20:34 来自触屏版 | 显示全部楼层
有电路图吗,8266连单片机线怎么接?
