查看: 2523|回复: 0
物理实验竞赛做的一个转动惯量测量仪的单片机源程序
ID:246215 发表于 2017-11-5 19:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
拿单片机运算,光电旋转编码器测量数据,很是羞愧哦,就给了个省三
给大家需要光电旋转编码器程序的同学参考下吧
不知道怎么上传c文件,就这样吧
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include <stdio.h>
  4. #include <string.h>
  5. #include <absacc.h>
  6. #include <math.h>
  7. #define uchar unsigned char
  8. #define uint  unsigned int
  9. long i = 0;
  10. long j = 0;
  11. float speed,angle_speed=0,distance,angle_speed2 ,PI=3.14,D=0.027,R=0.0135,NUMBER=600.0;
  12. int tt = 0;
  13. int g=0;
  14. int k = 0;
  15. int allk=0;
  16. sbit k1=P1^0;
  17.   sbit k2=P1^1;
  18. sbit E=P2^7;
  19. sbit RW=P2^5;
  20. sbit RS=P2^6;
  21. sbit PSB = P1^0;
  22. uchar b[10];
  23. void Delay(uint i);
  24. void Outside_Init(void)
  25. {
  26. EX0 = 1;
  27. IT0 = 1;
  28. EX1 = 1;
  29. IT1 = 1;
  30. EA = 1;
  31. }
  32. void Outside_Int1(void) interrupt 2
  33. {
  34. i++;
  35. }
  36. void delays()
  37. {
  38. _nop_();
  39. _nop_();
  40. _nop_();
  41. _nop_();
  42. _nop_();
  43. }
  44. // bit Busy(void)
  45. // {
  46. // bit busy_flag = 0;
  47. // RS = 0;
  48. // RW = 1;
  49. // E = 1;
  50. // delays();
  51. // busy_flag = (bit)(P0 & 0x80);
  52. // E = 0;
  53. // return busy_flag;
  54. // }
  55. void wcmd(uchar del)
  56. {
  57. // while(Busy());
  58. RS = 0;
  59. RW = 0;
  60. E = 0;
  61. delays();
  62. P0 = del;
  63. delays();
  64. E = 1;
  65. delays();
  66. E = 0;
  67. }
  68. void wdata(uchar del)
  69. {
  70. // while(Busy());
  71. RS = 1;
  72. RW = 0;
  73. E = 0;
  74. delays();
  75. P0 = del;
  76. delays();
  77. E = 1;
  78. delays();
  79. E = 0;
  80. }
  81. void L1602_init(void)
  82. {
  83. PSB=1;
  84. wcmd(0x30);
  85.         Delay(10);
  86. wcmd(0x0c);
  87.         Delay(10);
  88.         wcmd(0x01);
  89.         Delay(10);
  90.         wcmd(0x80);
  91. Delay(10);
  92. }
  93. void Delay(uint i)
  94. {
  95. uint x,j;
  96. for(j=0;j<i;j++)
  97. for(x=0;x<=148;x++);
  98. }
  99. void Time0_Init()
  100. {
  101. TMOD=0x01;
  102. TH0=(65536-45872)/256;
  103. TL0=(65536-45872)%256;
  104. ET0=0;
  105. TR0=0;
  106. }
  107. void Time0_Int() interrupt 1
  108. {
  109. TH0=(65536-45872)/256;
  110. TL0=(65536-45872)%256;
  111. tt++;
  112.         g++;
  113.         if(tt==2)
  114.         {
  115.         allk=allk+i;
  116. angle_speed=3;
  117. k=i;
  118. distance=PI*D/NUMBER;
  119. speed=k*distance/0.1;
  120. angle_speed2=speed/R ;
  121. tt=0;        i=0;
  122.   }
  123.
  124. }
  125. void main()
  126. {
  127. float ZD,ZD1,ZD2;
  128. uchar a[10];
  129. uchar c[]="脉冲触发";
  130. uchar d[]="转动惯量";
  131. uchar e[]="转动惯量测量仪";
  132. uchar f[]="大连民族大学";
  133. L1602_init();
  134. Time0_Init();
  135. Outside_Init();
  136.                                                 wcmd(0x80);
  137.         Delay(10);
  138.         for(j=0;j<14;j++)wdata(e[j]);
  139.                                                 wcmd(0x88);
  140.         Delay(10);
  141.                                                 for(j=0;j<12;j++)wdata(f[j]);
  142. while(1)
  143. {
  144. if(k1==0){Delay(7);if(k1==0)wcmd(0x01);break; }
  145. }
  146. wcmd(0x01);
  147. Delay(10);
  148.                                                 wcmd(0x90);
  149. Delay(10);
  150.                                                 for(j=0;j<8;j++)wdata(c[j]);
  151.                                                         wcmd(0x88);
  152. Delay(10);
  153.                                                         for(j=0;j<8;j++)wdata(d[j]);
  154. ET0=1;
  155. TR0=1;
  156. while(1)
  157. {
  158.
  159. if(allk>=100)
  160. {
  161.         g=0;
  162.         while(angle_speed2>=5||angle_speed2<=6);
  163.         while(1)
  164.         {
  165. if(g==20||g==21)
  166. ……………………
  167. …………限于本文篇幅 余下代码请从51黑下载附件…………
新建文本文档.zip (1.27 KB, 下载次数: 9)
收藏收藏2 分享淘帖 顶 踩
