查看: 3165|回复: 3
计算器计算的结果一闪而过,请大神指教
ID:150397 发表于 2017-3-23 11:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>        #include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar code wei[]={
0xff,0xdf,0xef,0xf7,0xfb};
void delayms(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
        for(j=110;j>0;j--);
void display(int num)
        int bai,shi,ge;
        if(num>=0&&num<=999)
                bai=num/100%10;
                shi=num/10%10;
                ge=(num%10);
                dula=1;
                P0=table[ge];
                dula=0;
                P0=0xff;
                wela=1;
                P0=wei[1];
                wela=0;
                delayms(5);
        if(num>=10)
                dula=1;
                P0=table[shi];
                dula=0;
                P0=0xff;
                wela=1;
                P0=wei[2];
                wela=0;
                delayms(5);
        if(num>=100)
                dula=1;
                P0=table[bai];
                dula=0;
                P0=0xff;
                wela=1;
                P0=wei[3];
                wela=0;
                delayms(5);
void matrixkeyscan()
        int temp,key,flag,key1,key2,x;
        P3=0xfe;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delayms(5);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xee:key=key*10+1;break;
                                case 0xde:key=key*10+2;break;
                                case 0xbe:key=key*10+3;break;
                                case 0x7e:key1=key;key=0;flag=1;break;
                        while(temp!=0xf0)        //等待按键释放
                                temp=P3;
                                temp=temp&0xf0;
        if(x==0)
        display(key);
        P3=0xfd;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delayms(5);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xed:key=key*10+4;break;
                                case 0xdd:key=key*10+5;break;
                                case 0xbd:key=key*10+6;break;
                                case 0x7d:key1=key;key=0;flag=2;break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp=temp&0xf0;
                        display(key);
        if(x==0)
        display(key);
        P3=0xfb;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delayms(5);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xeb:key=key*10+7;break;
                                case 0xdb:key=key*10+8;break;
                                case 0xbb:key=key*10+9;break;
                                case 0x7b:key1=key;key=0;flag=3;break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp=temp&0xf0;
                        display(key);
        if(x==0)
        display(key);
        P3=0xf7;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delayms(5);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xe7:key2=0;key=0;key1=0;x=0;break;
                                case 0xd7:key=key*10+0;key2=key;break;
                                case 0xb7:if(flag==1)key2=key1+key;
                                                  if(flag==2)key2=key1-key;
                                                  if(flag==3)key2=key1*key;
                                                  if(flag==4)key2=key1/key;key=0;x=1;break;
                                case 0x77:key1=key;key=0;flag=4;break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp=temp&0xf0;
                if(x!=0)
                display(key2);
                        matrixkeyscan();//不停用键盘扫描程序
ID:150397 发表于 2017-3-23 11:50 | 只看该作者
  1. #include<reg52.h>        #include<reg52.h>
  3. #define uint unsigned int
  4. sbit dula=P2^6;
  5. sbit wela=P2^7;
  6. uchar code table[]={
  7. 0x3f,0x06,0x5b,0x4f,
  8. 0x66,0x6d,0x7d,0x07,
  9. 0x7f,0x6f,0x77,0x7c,
  10. 0x39,0x5e,0x79,0x71};
  11. uchar code wei[]={
  12. 0xff,0xdf,0xef,0xf7,0xfb};
  13. void delayms(uint xms)
  14. {
  15.         uint i,j;
  16.         for(i=xms;i>0;i--)
  17.         for(j=110;j>0;j--);
  18. }
  19. void display(int num)
  20. {
  21.         int bai,shi,ge;
  22.
  23.         if(num>=0&&num<=999)
  24.         {
  25.                 bai=num/100%10;
  26.                 shi=num/10%10;
  27.                 ge=(num%10);
  28.                 dula=1;
  29.                 P0=table[ge];
  30.                 dula=0;
  31.                 P0=0xff;
  32.                 wela=1;
  33.                 P0=wei[1];
  34.                 wela=0;
  35.                 delayms(5);
  36.         if(num>=10)
  37.         {
  38.                 dula=1;
  39.                 P0=table[shi];
  40.                 dula=0;
  41.                 P0=0xff;
  42.                 wela=1;
  43.                 P0=wei[2];
  44.                 wela=0;
  45.                 delayms(5);
  46.         }
  47.         if(num>=100)
  48.         {
  49.                 dula=1;
  50.                 P0=table[bai];
  51.                 dula=0;
  52.                 P0=0xff;
  53.                 wela=1;
  54.                 P0=wei[3];
  55.                 wela=0;
  56.                 delayms(5);
  57.         }
  58.         }
  59. }
  60.
  61.
  62. void matrixkeyscan()
  63. {
  64.         int temp,key,flag,key1,key2,x;
  65.         P3=0xfe;
  66.         temp=P3;
  67.         temp=temp&0xf0;
  68.         if(temp!=0xf0)
  69.         {
  70.                 delayms(5);
  71.                 temp=P3;
  72.                 temp=temp&0xf0;
  73.                 if(temp!=0xf0)
  74.                 {
  75.                         temp=P3;
  76.                         switch(temp)
  77.                         {
  78.                                 case 0xee:key=key*10+1;break;
  79.                                 case 0xde:key=key*10+2;break;
  80.                                 case 0xbe:key=key*10+3;break;
  81.                                 case 0x7e:key1=key;key=0;flag=1;break;
  82.                         }
  83.                         while(temp!=0xf0)        //等待按键释放
  84.                         {
  85.                                 temp=P3;
  86.                                 temp=temp&0xf0;
  87.                         }
  88.
  89.                 }
  90.         }
  91.         if(x==0)
  92.         display(key);
  93.         P3=0xfd;
  94.         temp=P3;
  95.         temp=temp&0xf0;
  96.         if(temp!=0xf0)
  97.         {
  98.                 delayms(5);
  99.                 temp=P3;
  100.                 temp=temp&0xf0;
  101.                 if(temp!=0xf0)
  102.                 {
  103.                         temp=P3;
  104.                         switch(temp)
  105.                         {
  106.                                 case 0xed:key=key*10+4;break;
  107.                                 case 0xdd:key=key*10+5;break;
  108.                                 case 0xbd:key=key*10+6;break;
  109.                                 case 0x7d:key1=key;key=0;flag=2;break;
  110.
  111.                         }
  112.                         while(temp!=0xf0)
  113.                         {
  114.                                 temp=P3;
  115.                                 temp=temp&0xf0;
  116.                         }
  117.                         display(key);
  118.                 }
  119.         }
  120.         if(x==0)
  121.         display(key);
  122.         P3=0xfb;
  123.         temp=P3;
  124.         temp=temp&0xf0;
  125.         if(temp!=0xf0)
  126.         {
  127.                 delayms(5);
  128.                 temp=P3;
  129.                 temp=temp&0xf0;
  130.                 if(temp!=0xf0)
  131.                 {
  132.                         temp=P3;
  133.                         switch(temp)
  134.                         {
  135.                                 case 0xeb:key=key*10+7;break;
  136.                                 case 0xdb:key=key*10+8;break;
  137.                                 case 0xbb:key=key*10+9;break;
  138.                                 case 0x7b:key1=key;key=0;flag=3;break;
  139.                         }
  140.                         while(temp!=0xf0)
  141.                         {
  142.                                 temp=P3;
  143.                                 temp=temp&0xf0;
  144.                         }
  145.                         display(key);
  146.                 }
  147.         }
  148.         if(x==0)
  149.         display(key);
  150.         P3=0xf7;
  151.         temp=P3;
  152.         temp=temp&0xf0;
  153.         if(temp!=0xf0)
  154.         {
  155.                 delayms(5);
  156.                 temp=P3;
  157.                 temp=temp&0xf0;
  158.                 if(temp!=0xf0)
  159.                 {
  160.                         temp=P3;
  161.                         switch(temp)
  162.                         {
  163.                                 case 0xe7:key2=0;key=0;key1=0;x=0;break;
  164.                                 case 0xd7:key=key*10+0;key2=key;break;
  165.                                 case 0xb7:if(flag==1)key2=key1+key;
  166.                                                   if(flag==2)key2=key1-key;
  167.                                                   if(flag==3)key2=key1*key;
  168.                                                   if(flag==4)key2=key1/key;key=0;x=1;break;
  169.                                 case 0x77:key1=key;key=0;flag=4;break;
  170.                         }
  171.                         while(temp!=0xf0)
  172.                         {
  173.                                 temp=P3;
  174.                                 temp=temp&0xf0;
  175.                         }
  176.
  177.                 }
  178.                 if(x!=0)
  179.                 display(key2);
  180.         }
  181. }
  182. void main()
  183. {
  184.
  185.                 while(1)
  186.                 {
  187.                         matrixkeyscan();//不停用键盘扫描程序
  188.                 }
  189. }
ID:123289 发表于 2017-3-23 22:36 | 只看该作者
显示后不要再有刷屏的事发生就OK了
ID:150397 发表于 2017-3-24 09:12 | 只看该作者
yzwzfyz 发表于 2017-3-23 22:36
显示后不要再有刷屏的事发生就OK了
我该怎么改~我还是不懂
