查看: 3493|回复: 0
步进电机闭环控制程序
ID:209673 发表于 2017-6-9 21:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<intrins.h>
#include<reg51.h>
uint i,j,m,n,flag,t;
signed int a,b,c,d;
double tt;
uchar code  LEDData[]="0123456789";
uchar TX[6]={0,};
uchar run[]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09};
控制口定义
sbit EnA  =P2^6;
sbit SA1  =P2^2;
sbit SA2  =P2^3;
sbit EnB  =P2^7;
sbit SB1  =P2^4;
   sbit SB2  =P2^5;
sbit en   =P3^3;
   sbit rw   =P3^1;
sbit rs   =P3^0;
sbit start=P1^4;
sbit vh   =P1^5;
sbit vl   =P1^6;
sbit stop =P1^7;
延时1ms程序
void delay0(int t)
{int w;
for(;t>0;t--)
for(w=110;w>0;w--);
键盘扫描程序
void key()
{if(start==0)
  {delay0(10);
while(start==0);
{j++;   n=1;   }
  if(stop==0)
{delay0(10);
while(stop==0);
    {n--;
j=0;
if(vh==0)
  {delay0(10);
  while(vh==0);
{m++;    a++;}
if(vl==0)
{delay0(10);
while(vl==0);
    {m--;
b--;}
写指令程序
void write_com(uchar com)
{  rs=0;
P0=com;
delay0(5);
en=1;
delay0(5);
en=0;
写数据程序
void write_data(uchar date)
  rs=1;
P0=date;
delay0(5);
en=1;
delay0(5);
en=0;
PID程序
void PID()
{uint e1,e2,e3;
e1=TX[5]-TX[4];
e2=TX[3]-TX[2];
e3=TX[1]-TX[0];
  if(e1>e2>10)
  { t=10*e1-6*e2+4*e3;   }
if(2<e1<e2)
{ t=3*e1-5*e2+2*e3;
中断0服务程序
void interrupt0()
interrupt 1 using 2
{c++;
定时器0服务程序
void timer0() interrupt 1
   {  uint e;
uint f;
   TH0=(65536-(1250-t))/256;
  TL0=(65536-(1250-t))%256;
  if(f<7)
  {P2=run[f];
  f++;
else     {P2=run[f];
  f=0;
  d++;
  if(d==m)
{if(e<6)
  {e++;
  TX[e]=c;
{e=0;
PID();
c=0;
   d=0;
内部资源初始化
void Init(void) {
   TMOD=0x11;
   TH1=(65536-50000)/256;
  TL1=(65536-50000)%256;
  IT0=1;
    EX0=1;
IP=0x03;
   EA=1;
   ET0=1;
TR0=1;
en=0;
rw=0;
   write_com(0x38);
  write_com(0x0c);
write_com(0x04);
write_com(0x01);
  write_com(0x80);
  write_data('S');
   write_data('S');
  write_data('P');
   write_data('E');
write_data('E');
   write_data('D');
  write_data(':');
   write_com(0x80+0x0B);
  write_data('R');
write_data('/');
  write_data('S');
  write_com(0x80+0x40);
  write_data('R');
  write_data('S');
write_data('P');
write_data('E');
write_data('E');
write_data('D');
write_data(':');
   write_com(0x80+0x4B);
   write_data('R');
  write_data('/');
  write_data('S');
速度显示
void speeddisplay()
{ write_com(0x80+0x07);
   write_data('0');
   write_data(LEDData[m/100]);
   write_data(LEDData[m%100/10]);
write_data(LEDData[m%10]);
  if((m<600)&(m>950))
    {write_com(0x80+0x48);
     write_data(LEDData[(m+1)/100]);
   write_data(LEDData[(m+1)%100/10]);
  write_data(LEDData[(m+1)%10]);}   else
    {write_com(0x80+0x47);
write_data('0');
  write_data(LEDData[m%10]);};
void main(void)
{  a=b=c=d=i=0;
j=0;
m=800;
   n=1;
  flag=0;
   {key();
   if(j==1)
  {init();
while(j&&n)
{key();
PID();
     tt=(1.3*(a+b));
   t=tt;
speeddisplay();
   if(n==0)
    {write_com(0x38);
  write_com(0x0c);
write_com(0x04);
   write_com(0x01);
收藏收藏1 分享淘帖 顶 踩
