查看: 1582|回复: 0
TFT2.4吋驱动代码
ID:216053 发表于 2017-6-30 11:52 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include "stm32f4xx.h"
#include <math.h>
#include "delay.h"
#include "LCD.h"
#include "pic.h"
void IO_init(void);
void delay_ms(unsigned long ms);
void delay_ns(unsigned long ns);
void set_cs(void);
void reset_cs(void);
void set_res(void);
void reset_res(void);
void set_rs(void);
void reset_rs(void);
void set_wr(void);
void reset_wr(void);
void set_rd(void);
void reset_rd(void);
void write_com(unsigned char para);
void write_data(unsigned char para);
void out_data_port(unsigned short data);
void clear_display(void);
void systick_init(void);
unsigned char input_data_port(void);
unsigned char out_or_input_flag =1;
int main(void)
systick_init();
    IO_init();
    delay_ms(100);
    set_rd();
    LCD_Init();
    delay_ms(100);
        LCD_Clear(LCD_BGR2RGB(RED));
        delay_ms(200);
        LCD_Clear(LCD_BGR2RGB(GREEN));
        delay_ms(200);
        LCD_Clear(LCD_BGR2RGB(BLUE));
        delay_ms(200);
        display_pic(gImage);
        delay_ms(3000);
        display_pic(gImage_2);
        delay_ms(3000); }
void IO_init(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 |GPIO_Pin_1;
        GPIO_InitStructure.GPIO_Mode= GPIO_Mode_OUT;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_Speed =GPIO_Speed_100MHz;
    GPIO_InitStructure.GPIO_PuPd =GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 |GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Mode= GPIO_Mode_IN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    write_com(0x01);
    delay_ms(10);
void write_com(volatile unsigned char para)
    reset_rs();
    reset_wr();
    delay_ns(20);
    out_data_port(para);
    delay_ns(20);
    set_rd();
    delay_ns(20);
    reset_rd();
    delay_ns(20);
    reset_cs();  // 0 : select
    delay_ns(20);
    reset_rs(); // 1 : command
    delay_ns(20);
//  reset_wr();  // 0
//  set_rd();
    //delay_ns(2);
    delay_ns(20);
  reset_wr();
    delay_ns(20);
    set_rd();
    set_wr();
void write_data(volatile unsigned char para)
    set_rs();
    reset_wr();
    delay_ns(20);
    delay_ns(20);
    set_rd();
    delay_ns(20);
    reset_rd();
    delay_ns(20);
    delay_ns(20);
    set_rs(); // 0:  data
    delay_ns(20);
//  reset_wr();  // 0
//  set_rd();
    //delay_ns(2);
    delay_ns(20);
  reset_wr();
    delay_ns(20);
    set_rd();
    set_wr();
//  set_cs();
    set_rs();
void out_data_port(unsigned short Data)
    GPIOC->ODR= Data;
    unsigned charData;
   out_data_port(0XFFFF);
        Data =GPIO_ReadInputData(GPIOC);
      return Data;
void set_cs(void)
    GPIOA->BSRRL= GPIO_Pin_7;
void reset_cs(void)
    GPIOA->BSRRH= GPIO_Pin_7;
void set_res(void)
    GPIOA->BSRRL= GPIO_Pin_6;
    GPIOA->BSRRH= GPIO_Pin_6;
void set_rs(void)
    GPIOA->BSRRL= GPIO_Pin_5;
void reset_rs(void)
    GPIOA->BSRRH= GPIO_Pin_5;
void set_wr(void)
    GPIOA->BSRRL= GPIO_Pin_4;
void reset_wr(void)
    GPIOA->BSRRH= GPIO_Pin_4;
void set_rd(void)
    GPIOA->BSRRL= GPIO_Pin_3;
void reset_rd(void)
    GPIOA->BSRRH= GPIO_Pin_3;
unsigned char poll_button(void)
    if((GPIOA->IDR& GPIO_Pin_0) == 0)
        return(0);
        return(1);
unsigned char MCU_WAIT(void)
        return(0);
        return(1);
    if(SysTick_Config(SystemCoreClock / 18000))  //10000 6KHz main loop
        /*Capture error */
        while(1);
    NVIC_SetPriority(SysTick_IRQn,15);
