查看: 3744|回复: 0
ov7640摄像头处理(彩色,灰度,任意窗口)源码
ID:224552 发表于 2017-8-3 23:07 | 显示全部楼层 |阅读模式
ov7640摄像头处理源码
摄像头实验(彩色,灰度,任意窗口):
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "key.h"
  4. #include "sys.h"
  5. #include "lcd.h"
  6. #include "usart.h"
  7. #include "string.h"
  8. #include "ov7670.h"
  9. #include "tpad.h"
  10. #include "timer.h"
  11. #include "exti.h"
  12. #include "usmart.h"
  13. //ALIENTEK战舰STM32开发板实验36
  14. //摄像头 实验
  15. extern u8 ov_sta;        //在exit.c里面定义
  16. extern u8 ov_frame;        //在timer.c里面定义
  17. extern u8 data_ready;
  18. u16 color_r;
  19. u16 color_g;
  20. u16 color_b;
  21. //设置CPU的频率
  22. void ov7670_clock_set(u8 PLL)
  23. {
  24.         u8 temp=0;
  25.         RCC->CFGR&=0XFFFFFFFC;
  26.         RCC->CR&=~0x01000000;
  27.         RCC->CFGR&=~(0XF<<18);
  28.         PLL-=2;//抵消2个单位
  29.         RCC->CFGR|=PLL<<18;
  30.         RCC->CFGR|=1<<16;                  //PLLSRC ON
  31.         FLASH->ACR|=0x12;
  32.         RCC->CR|=0x01000000;          //PLLON
  33.         while(!(RCC->CR>>25));
  34.         RCC->CFGR|=0x02;
  35.         while(temp!=0x02)
  36.         {
  37.                 temp=RCC->CFGR>>2;
  38.                 temp&=0x03;
  39.         }
  40. }
  41. //更新LCD显示
  42. void camera_refresh()
  43. {
  44.         u32 i,j;
  45.         u16 color;
  46.         if(ov_sta==2)
  47.         {
  48.                 LCD_Scan_Dir(U2D_L2R);                //从上到下,从左到右
  49.                 LCD_SetCursor(0x00,0x0000);        //设置光标位置
  50.                 LCD_WriteRAM_Prepare();     //开始写入GRAM
  51.                 OV7670_RRST=0;                                //开始复位读指针
  52.                 OV7670_RCK_L;
  53.                 OV7670_RCK_H;
  54.                 OV7670_RCK_L;
  55.                 OV7670_RRST=1;                                //复位读指针结束
  56.                 OV7670_RCK_H;
  57.                 if(ov7670_config.mode){
  58.                         for(i=0; i<ov7670_config.height; i++)
  59.                         {
  60.                         //        LCD_SetCursor(i+ov7670_config.xsta,ov7670_config.ysta);        //设置光标位置
  61.                         //        LCD_WriteRAM_Prepare();     //开始写入GRAM
  62.                                 for(j=0; j<ov7670_config.width; j++)
  63.                                 {
  64.                                         OV7670_RCK_L;
  65.                                         color = GPIOC->IDR&0XFF;        //读数据
  66.                                         OV7670_RCK_H;
  67.
  68.                                         color<<=8;
  69.                                         OV7670_RCK_L;//因为设置的是 YUYV输出,第二个字节没用,不需要读
  70.                                 //        color |= GPIOC->IDR&0XFF;        //
  71.                                         OV7670_RCK_H;
  72.
  73.
  74.                                         color_r = color&0xf800;
  75.                                         color_b = color>>11;
  76.                                         color >>=5;
  77.                                         color_g =color&0x07e0;
  78.
  79.                                         LCD->LCD_RAM= color_r + color_g + color_b;
  80.                                 }
  81.
  82.                         }
  83.                 }else{
  84.                         for(i=0; i<ov7670_config.height; i++)
  85.                         {
  86.                         //        LCD_SetCursor(i+ov7670_config.xsta,ov7670_config.ysta);        //设置光标位置
  87.                         //        LCD_WriteRAM_Prepare();     //开始写入GRAM
  88.                                 for(j=0; j<ov7670_config.width; j++)
  89.                                 {
  90.                                         OV7670_RCK_L;
  91.                                         color = GPIOC->IDR&0XFF;        //读数据
  92.                                         OV7670_RCK_H;
  93.
  94.                                         color<<=8;
  95.                                         OV7670_RCK_L;
  96.                                         color |= GPIOC->IDR&0XFF;        //读数据
  97.                                         OV7670_RCK_H;
  98.
  99.                                         LCD->LCD_RAM=color;
  100.                                 }
  101.
  102.                         }
  103.                 }
  104.                 EXTI_ClearITPendingBit(EXTI_Line8);  //清除LINE8上的中断标志位
  105.                 ov_sta=0;                                        //开始下一次采集
  106.                  ov_frame++;
  107.           LCD_Scan_Dir(DFT_SCAN_DIR);        //恢复默认扫描方向
  108.         }
  109. }
  110. int main(void)
  111. {
  112.         delay_init();                     //延时函数初始化
  113.         NVIC_Configuration();          //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
  114.         uart_init(9600);                 //串口初始化为9600
  115.          LED_Init();                             //LED端口初始化
  116.         LCD_Init();
  117.         KEY_Init();
  118.         TPAD_Init(72);                        //触摸按键初始化
  119.         usmart_dev.init(72);        //初始化USMART
  120.          POINT_COLOR=RED;//设置字体为红色
  121.         LCD_ShowString(60,50,200,16,16,"WarShip STM32");
  122.         LCD_ShowString(60,70,200,16,16,"OV7670 TEST");
  123.         LCD_ShowString(60,90,200,16,16,"ATOM@ALIENTEK");
  124.         LCD_ShowString(60,110,200,16,16,"2012/9/14");
  125.           LCD_ShowString(60,130,200,16,16,"OV7670 Init...");
  126.         while(OV7670_Init())//初始化OV7670
  127.         {
  128.                 LCD_ShowString(60,130,200,16,16,"OV7670 Error!!");
  129.                 delay_ms(200);
  130.             LCD_Fill(60,130,239,246,WHITE);
  131.                 delay_ms(200);
  132.         }
  133.          LCD_ShowString(60,130,200,16,16,"OV7670 Init OK");
  134.
  135.
  136.         TIM6_Int_Init(10000,7199);                        //10Khz计数频率,1秒钟中断
  137.         EXTI8_Init();                                                //使能定时器捕获
  138.           OV7670_CS=0;
  139.
  140.         config_ov7670_OutPut(20,60,320,240,1);
  141.          while(1)
  142.         {
  143.                 camera_refresh();//更新显示
  144.         }
  145. }
摄像头实验(彩色,灰度,任意窗口).rar
359.28 KB, 下载次数: 15, 下载积分: 黑币 -5
