查看: 4560|回复: 7
我搞的频率计c程
ID:71774 发表于 2015-1-24 18:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>                                   //        自写频率计程序,在学习板上通过
typedef  unsigned char   uint8;
typedef  unsigned int    uint16;
typedef  unsigned long   uint32;
code uint8 number[] = {0xc0,0xf9,0xa4,0xb0,
                                              0x99,0x92,0x82,0xf8,
                                            0x80,0x90};
uint8 a[6];
uint16 counter,counter1;
uint8 ky;
uint32 sec;
sbit ENLED = P1^4;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit KeyOut1=P2^3;
sbit K1 = P2^4;
bit flag;
void refresh_led()
          static uint8 j = 0;
                switch(j)
                   case 0: ADDR0 = 0;ADDR1 = 0;ADDR2 = 0;j++;P0 = number[a[0]];break;
                case 1: ADDR0 = 1;ADDR1 = 0;ADDR2 = 0;j++;P0 = number[a[1]];break;
                case 2: ADDR0 = 0;ADDR1 = 1;ADDR2 = 0;j++;P0 = number[a[2]];break;
                case 3: ADDR0 = 1;ADDR1 = 1;ADDR2 = 0;j++;P0 = number[a[3]];break;
                case 4: ADDR0 = 0;ADDR1 = 0;ADDR2 = 1;j++;P0 = number[a[4]];break;
                case 5: ADDR0 = 1;ADDR1 = 0;ADDR2 = 1;j = 0;P0 = number[a[5]];break;
                default: break;
void Key1(void)
             while(!K1);
              ky++;
             if(ky > 1)
              ky=0;
void Delay(uint16 ms)
uint8 i;
        while(ms--)
          for( i=0;i<125;i++)
main()
        ENLED = 0; ADDR3 = 1;
     KeyOut1=0;
     TMOD=0x15;
     TH0=0;
     TL0=0;
     TH1=(65536-4000)/256;
         TL1=(65536-4000)%256;
     TR1=1;
     TR0=1;
     ET0=1;
     ET1=1;
     EA=1;
                if(!K1)
                Delay(5);
                if(!K1)
                Key1();
          if(flag==1)
                     { flag=0;
                        sec=counter*65536+TH0*256+TL0;
                            if(ky==1)
                         sec=0;
                          a[0] = sec%10;
                        a[1] = sec/10%10;
                        a[2] = sec/100%10;
                        a[3] = sec/1000%10;
                        a[4] = sec/10000%10;
                        a[5] = sec/100000%10;
                counter=0;
                counter1=0;
                TH0=0;
                TL0=0;
                TR0=1;
void t0(void) interrupt 1 using 1
   counter ++;
void t1(void) interrupt 3 using 2
counter1++;
if(counter1==250)
TR0=0;
counter1=0;
flag=1;
refresh_led();
admin + 50 共享资料的积分奖励!
收藏收藏1 分享淘帖 顶顶 踩踩
ID:1 发表于 2015-1-24 18:55 | 只看该作者
补充一下 这应该是用数码管显示的吧,电路下载:http://www.51hei.com/f/ks51.pdf
ID:71774 发表于 2015-1-24 19:59 | 只看该作者
是用6个数码管的,没专门电路,还是在学习板上实验。我的学习板就是金沙滩的。
ID:72756 发表于 2015-1-25 06:40 来自触屏版 | 只看该作者
收藏了,有用,谢谢三元兄。
ID:65226 发表于 2015-1-27 21:17 来自触屏版 | 只看该作者
学习了 谢谢
ID:86621 发表于 2015-8-12 16:44 | 只看该作者
精确度怎么样
ID:86621 发表于 2015-8-13 09:28 | 只看该作者
范围有哪些啊   有什么硬件
ID:4150 发表于 2017-8-31 20:16 | 只看该作者
请问楼主这种测试方法是基于测周法吗
