查看: 6811|回复: 0
51单片机采集ne555多谐振荡电路的频率的源码及仿真
51单片机的频率采集仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
  1. #include<reg51.h>
  2. #define uint unsigned int
  4. sbit DAT1=P2^0; //模拟串口数据发送端
  5. sbit DAT2=P2^1;
  6. sbit DAT3=P2^2;
  7. sbit CLK1=P2^4;//模拟时钟控制端
  8. sbit CLK2=P2^5;
  9. sbit CLK3=P2^6 ;
  10. sbit ne=P3^4;
  11. uchar hz,t;
  12. uint count,N;
  13. uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0xff};//0-9,-,?? (?????)
  14. uchar code tab1[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10,0x3f,0x7f};//0-9,-,?? (?????)
  15. void shi(uchar byte)
  16. {
  17. uchar num,c;
  18. num=tab[byte];
  19. for(c=0;c<8;c++)
  20. {
  21. CLK1=0;
  22. DAT1=num&0x80; //(0x80即十进制的128, 二进制的10000000 按位发送)
  23. CLK1=1;
  24. num<<=1;
  25. }
  26. }
  27. void ge(uchar byte)
  28. {
  29. uchar num,c;
  30. num=tab[byte];
  31. for(c=0;c<8;c++)
  32. {
  33. CLK2=0;
  34. DAT2=num&0x80; //(0x81即十进制的128, 二进制的10000001 按位发送)
  35. CLK2=1;
  36. num<<=1;
  37. }
  38. }
  39. void ge1(uchar byte)
  40. {
  41. uchar num,c;
  42. num=tab1[byte];
  43. for(c=0;c<8;c++)
  44. {
  45. CLK2=0;
  46. DAT2=num&0x80; //(0x81即十进制的128, 二进制的10000001 按位发送)
  47. CLK2=1;
  48. num<<=1;
  49. }
  50. }
  51. void xiao(uchar byte)
  52. {
  53. uchar num,c;
  54. num=tab[byte];
  55. for(c=0;c<8;c++)
  56. {
  57. CLK3=0;
  58. DAT3=num&0x80; //(0x80即十进制的128, 二进制的10000000 按位发送)
  59. CLK3=1;
  60. num<<=1;
  61. }
  62. }
  63.
  64. void delay_50ms(unsigned int t) //50MS演示程序
  65. {
  66. unsigned int j;
  67. for(;t>0;t--)
  68. for(j=6245;j>0;j--)
  69. {;}
  70. }
  71. unsigned char scount;
  72. void timer0_int() interrupt 1
  73. {
  74. TR0=0; //关闭定时器
  75. TH0=0x4C; //重装定时器值
  76. TL0=0x19;
  77. TF0=0; //清除溢出标志
  78. scount--;
  79. if(scount>0) //到1s 了吗?
  80. TR0=1; //没到,开定时器
  81. else
  82. TR1=0; //到了,停止T1 的计数
  83. }
  84. void main()
  85. {
  86. unsigned char a[3];
  87. unsigned char i,resh,resl;
  88. unsigned long int freq;
  89. TMOD=0xD1;
  90. //定时器0 工作在定时方式1,定时器1 工作在计数方式1
  91. TH0=0x4C; //定时50ms
  92. TL0=0x19;
  93. TH1=0; //计数值清0
  94. TL1=0;
  95. scount=20; //定时1s
  96. ET0=1; //开定时器0 中断
  97. EA=1; //开总中断
  98. TR0=1; //启动定时器和计数器
  99. TR1=1;
  100. for (i=0;i<3;++i)
  101. a[i]=0;
  102.   shi(a[2]);
  103.   ge(a[1]);
  104.   xiao(a[0]);
  105. while(1)
  106. {
  107. if(!scount) //1s时间到
  108. {
  109. resh=TH1; //取出计数值
  110. resl=TL1;
  111. TH1=0; //计数值清零
  112. TL1=0;
  113. TH0=0x4C; //重装定时器0
  114. ……………………
  115. …………限于本文篇幅 余下代码请从51黑下载附件…………
频率显示.zip (77.81 KB, 下载次数: 55)
