查看: 5113|回复: 4
51单片机PCA9685驱动9个舵机舵机的源程序
ID:235638 发表于 2018-12-21 11:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
51单片机PCA9685驱动板驱动舵机
  1. #include<reg52.h>
  2. #include <intrins.h>
  3. #include <stdio.h>
  4. #include <math.h>
  5. typedef  unsigned char  uchar;
  6. typedef  unsigned int   uint;
  7. unsigned char buf;
  8. sbit scl=P2^6;
  9. sbit sda=P2^7;
  10. #define PCA9685_adrr 0x80//  1+A5+A4+A3+A2+A1+A0+w/r
  11. #define PCA9685_SUBADR1 0x2
  12. #define PCA9685_SUBADR2 0x3
  13. #define PCA9685_SUBADR3 0x4
  14. #define PCA9685_MODE1 0x0
  15. #define PCA9685_PRESCALE 0xFE
  16. #define LED0_ON_L 0x6
  17. #define LED0_ON_H 0x7
  18. #define LED0_OFF_L 0x8
  19. #define LED0_OFF_H 0x9
  20. #define ALLLED_ON_L 0xFA
  21. #define ALLLED_ON_H 0xFB
  22. #define ALLLED_OFF_L 0xFC
  23. #define ALLLED_OFF_H 0xFD
  24. #define SERVOMIN  115 // this is the 'minimum' pulse length count (out of 4096)
  25. #define SERVOMAX  590 // this is the 'maximum' pulse length count (out of 4096)
  26. #define SERVO000  130 //0度
  27. #define SERVO180  520 //180度
  28. #define SERVO80   284 //80度
  29. #define SERVO110  340//110度
  30. void delayms(uint z)
  31. {
  32.   uint x,y;
  33.   for(x=z;x>0;x--)
  34.       for(y=148;y>0;y--);
  35. }
  36. void delayus()  //大于4.7us
  37. {
  38.           _nop_();
  39.                 _nop_();
  40.                 _nop_();
  41.                 _nop_();
  42.                 _nop_();
  43. }
  44. /*---------------------------------------------------------------
  45.                  IIC初始化
  46. ----------------------------------------------------------------*/
  47. void init()
  48. {
  49.     sda=1;                //sda scl使用前被拉高
  50.     delayus();
  51.     scl=1;
  52.     delayus();
  53. }
  54. /*---------------------------------------------------------------
  55.                  IIC????????
  56. ----------------------------------------------------------------*/
  57. void start()
  58. {
  59.     sda=1;
  60.     delayus();
  61.     scl=1;       //scl高 sda拉低 ????IIC启动
  62.     delayus();
  63.     sda=0;
  64.     delayus();
  65.                 scl=0;
  66.                 delayus();
  67. }
  68. /*---------------------------------------------------------------
  69.                  IIC停止
  70. ----------------------------------------------------------------*/
  71. void stop()
  72. {
  73.     sda=0;
  74.     delayus();
  75.     scl=1;                         //scl??? sda??????? ????IIC??
  76.     delayus();
  77.     sda=1;
  78.     delayus();
  79. }
  80. /*---------------------------------------------------------------
  81.                  IIC应答
  82. ----------------------------------------------------------------*/
  83. void ACK()
  84. {
  85.     uchar i;
  86.     scl=1;
  87.     delayus();
  88.     while((sda=1)&&(i<255))
  89.                 i++;
  90.     scl=0;
  91.     delayus();
  92. }
  93. /*---------------------------------------------------------------
  94.               写字节
  95. ----------------------------------------------------------------*/
  96. void write_byte(uchar byte)
  97. {
  98.     uchar i,temp;
  99.     temp=byte;
  100.     for(i=0;i<8;i++)
  101.     {
  102.         temp=temp<<1;
  103.         scl=0;
  104.                                 delayus();
  105.                                 sda=CY;
  106.                                 delayus();
  107.                                 scl=1;
  108.                                 delayus();
  109.     }
  110.     scl=0;
  111.     delayus();
  112.     sda=1;
  113.     delayus();
  114. }
  115. /*---------------------------------------------------------------
  116.               肚子节
  117. ----------------------------------------------------------------*/
  118. uchar read_byte()
  119. {
  120.                 uchar i,j,k;
  121.                 scl=0;
  122.                 delayus();
  123.                 sda=1;
  124.                 delayus();
  125.                 for(i=0;i<8;i++)
  126.                 {
  127.                                 delayus();
  128.                                 scl=1;
  129.                 delayus();
  130.                 if(sda==1)
  131.                 {
  132.                                 j=1;
  133.                 }
  134.                 else j=0;
  135.                 k=(k<< 1)|j;
  136.                 scl=0;
  137.                 }
  138.                 delayus();
  139.                 return k;
  140. }
  141. /*---------------------------------------------------------------
  142.                 ??PCA9685?????
  143. ----------------------------------------------------------------*/
  144. /*---------------------------------------------------------------
  145.                 ?PCA9685????,??
  146. ----------------------------------------------------------------*/
  147. void PCA9685_write(uchar address,uchar date)
  148. {
  149.                 start();
  150.                 write_byte(PCA9685_adrr);        //PCA9685?????
  151.                 ACK();
  152.                 write_byte(address);  //???????
  153.                 ACK();
  154.                 write_byte(date);          //???
  155.                 ACK();
  156.                 stop();
  157. }
  158. /*---------------------------------------------------------------
  159.             从PCA9685读数据有返回值
  160. ----------------------------------------------------------------*/
  161. uchar PCA9685_read(uchar address)
  162. {
  163.                 uchar date;
  164.                 start();
  165.                 write_byte(PCA9685_adrr); //PCA9685?????
  166.                 ACK();
  167.                 write_byte(address);
  168.                 ACK();
  169.                 start();
  170.                 write_byte(PCA9685_adrr|0x01);        //?????????????,?????
  171.                 ACK();
  172.                 date=read_byte();
  173.                 stop();
  174.                 return date;
  175. }
  176. /*---------------------------------------------------------------
  177.                         PCA9685复位
  178. ----------------------------------------------------------------*/
  179. void reset(void)
  180. {
  181.                 PCA9685_write(PCA9685_MODE1,0x0);
  182. }
  183. void begin(void)
  184. {
  185.                 reset();
  186. }
  187. /*---------------------------------------------------------------
  188.                                         PCA9685修改频率
  189. ----------------------------------------------------------------*/
  190. void setPWMFreq(float freq)
  191. {
  192.                 uint prescale,oldmode,newmode;
  193.                 float prescaleval;
  194.                 freq *= 0.92;  // Correct for overshoot in the frequency setting
  195.                 prescaleval = 25000000;
  196.                 prescaleval /= 4096;
  197.                 prescaleval /= freq;
  198.                 prescaleval -= 1;
  199.                 prescale = floor(prescaleval + 0.5);
  200.
  201.                 oldmode = PCA9685_read(PCA9685_MODE1);
  202.                 newmode = (oldmode&0x7F) | 0x10; // sleep
  203.                 PCA9685_write(PCA9685_MODE1, newmode); // go to sleep
  204.                 PCA9685_write(PCA9685_PRESCALE, prescale); // set the prescaler
  205.                 PCA9685_write(PCA9685_MODE1, oldmode);
  206.                 delayms(2);
  207.                 PCA9685_write(PCA9685_MODE1, oldmode | 0xa1);
  208. }
  209. /*---------------------------------------------------------------
  210.                          PCA9685??????
  211. num:??PWM????0~15,on:PWM?????0~4096,off:PWM?????0~4096
  212. ??PWM????4096?,?0??+1??,??on???????,?????off?
  213. ??????,????4096????????on???0?????,?on??0?,
  214. off/4096????PWM?????
  215. ----------------------------------------------------------------*/
  216. void setPWM(uint num, uint on, uint off)
  217. {
  218.                 PCA9685_write(LED0_ON_L+4*num,on);
  219.                 PCA9685_write(LED0_ON_H+4*num,on>>8);
  220.                 PCA9685_write(LED0_OFF_L+4*num,off);
  221.                 PCA9685_write(LED0_OFF_H+4*num,off>>8);
  222. }
  223. void main()
  224. {
  225.           init();
  226.                 begin();
  227.                 setPWMFreq(50);    //设置50hz
  228.
  229.                 SCON=0x50;           //设定串口工作方式
  230.     PCON=0x00;           //波特率不倍增
  231.     TMOD=0x20;           //定时器1工作于8位自动重载模式, 用于产生波特率
  232.     EA=1;
  233.     ES = 1;              //允许串口中断
  234.     TL1=0xfd;
  235.     TH1=0xfd;             //波特率9600
  236.     TR1=1;
  237.         //  delayms(1000);
  238.                 //60度=0.5ms+(60/180)*(2.5ms-0.5ms)=1.1666ms
  239.                 //利用占空比=1.1666ms/20ms=off/4096,off=239,50hz对应周期20ms
  240.
  241.                 setPWM(0, 0, SERVOMAX);
  242.                 setPWM(1, 0, SERVOMAX);
  243.           setPWM(2, 0, SERVOMAX);
  244.                 setPWM(3, 0, SERVOMAX);
  245.                 setPWM(4, 0, SERVOMAX);
  246.                 setPWM(5, 0, SERVOMAX);
  247.                 setPWM(6, 0, SERVOMAX);
  248.                 setPWM(7, 0, SERVOMAX);
  249.                 setPWM(8, 0, SERVOMAX);
  250.                 while(1)
  251.                 {
  252.                  switch(buf)
  253.                  {
  254.                                 case 0x11: setPWM(0, 0, SERVO110); break;
  255.                                 case 0x12: setPWM(0, 0, SERVOMAX); break;
  256.                                 case 0x13: setPWM(1, 0, SERVO110); break;
  257.                                 case 0x14: setPWM(1, 0, SERVOMAX); break;
  258.                                 case 0x15: setPWM(2, 0, SERVO110); break;
  259.                                 case 0x16: setPWM(2, 0, SERVOMAX); break;
  260.                                 case 0x17: setPWM(3, 0, SERVO110); break;
  261.                                 case 0x18: setPWM(3, 0, SERVOMAX); break;
  262.                                 case 0x19: setPWM(4, 0, SERVO110); break;
  263.                                 case 0x20: setPWM(4, 0, SERVOMAX); break;
  264.                                 case 0x21: setPWM(5, 0, SERVO110); break;
  265.                                 case 0x22: setPWM(5, 0, SERVOMAX); break;
  266.                                 case 0x23: setPWM(6, 0, SERVO110); break;
  267.                                 case 0x24: setPWM(6, 0, SERVOMAX); break;
  268.                                 case 0x25: setPWM(7, 0, SERVO110); break;
  269.                           case 0x26: setPWM(7, 0, SERVOMAX); break;
  270.                           case 0x27: setPWM(8, 0, SERVO110); break;
  271.                           case 0x28: setPWM(8, 0, SERVOMAX); break;
  272.                                 default:break;  //接受到其它数据,蜂鸣器响
  273.                  }
  274.                 }
  275. }
  276. void  serial() interrupt 4
  277. {
  278.                  ES = 0;                //关闭串行中断
  279.                  RI = 0;                //清除串行接受标志位
  280.                  buf = SBUF;            //从串口缓冲区取得数据
  281.
  282.                  ES = 1;    //允许串口中断
  283. }
以上代码51hei下载(请大家多多指教):
51单片机PCA9685驱动板驱动舵机.zip (35.92 KB, 下载次数: 90)
收藏收藏4 分享淘帖 顶2 踩
ID:64089 发表于 2019-8-12 08:39 | 只看该作者
不错的资料,我手上有PCA9635,不知道是不是可以通用驱动。
ID:647922 发表于 2020-2-10 16:13 | 只看该作者
94行是不是应该是while((sda==1)&&(i<255))
ID:208314 发表于 2021-4-5 16:19 | 只看该作者
测试无任何反应。
ID:1007619 发表于 2022-3-11 23:41 来自手机 | 只看该作者
可以驱动吗
