查看: 1986|回复: 8
单片机矩阵按键和串口配合使用问题
ID:1007138 发表于 2022-3-9 19:21 | 显示全部楼层 |阅读模式
我想问的是为什么只能用hex模式来发送而且怎么才能实现我不点串口助手的发送,只要我一按下按键就能发送到我的pc呢?
#include <reg52.h>
typedef unsigned char uchar;
typedef unsigned int  uint;
uchar code duan[16] = {0x3f,0x06,0x5b,0x4f,
                                                0x66,0x6d,0x7d,0x07,
                                                0x7f,0x6f,0x77,0x7c,
                                                0x39,0x5e,0x79,0x71};
uchar KeyValue;
void delay(uint z) {
        uint y;
        for (;z>0;z--)
                for (y = 0; y < 110; y++);
void chuankouInit() {
        TMOD = 0x20;
        TH1 = 243;
        TL1 = 243;
        TR1 = 1;
        SCON = 0x50;
        PCON = 0x80;  //倍波特率
        ES = 1;
        EA = 1;
void keypros() {
        //uint a;
        P1 = 0xf0;                                  //0xff不行,一定要控制变量先行后列或者先列后行否则要列出所有情况
        if (P1!=0xf0) {
                delay(10);
                if (P1!= 0xf0) {
                        switch (P1) {
                                case (0x70): KeyValue = 3;break;
                                case (0xb0): KeyValue = 2;break;
                                case (0xd0): KeyValue = 1;break;
                                case (0xe0): KeyValue = 0;break;
                        P1 = 0x0f;
                        if (P1!=0x0f) {
                                switch (P1) {
                                        case (0x07): KeyValue += 12;break;
                                        case (0x0b): KeyValue += 8;break;
                                        case (0x0d): KeyValue += 4;break;
                                        case (0x0e): KeyValue += 0;break;
//        while ((a < 50) && (P1!=0x0f)) {
//                delay(10);
//                a++;
void main() {
        chuankouInit();
        while (1) {
                keypros();
                P0 = ~duan[KeyValue];
void chuankou() interrupt 4 {
        uchar receiveData;
        receiveData = KeyValue;
        RI = 0;                   //收完
        SBUF = KeyValue;
        while (!TI);
        TI = 0;   //发完
ID:161164 发表于 2022-3-9 22:11 | 显示全部楼层
先假设你的矩阵按键和串口设置代码正确
  1. void keypros() {
  2.     //uint a;
  3.     P1 = 0xf0;                                  //0xff不行,一定要控制变量先行后列或者先列后行否则要列出所有情况
  4.     if (P1!=0xf0) {
  5.         delay(10);
  6.         if (P1!= 0xf0) {
  7.             switch (P1) {
  8.             case (0x70):
  9.                 KeyValue = 3;
  10.                 break;
  11.             case (0xb0):
  12.                 KeyValue = 2;
  13.                 break;
  14.             case (0xd0):
  15.                 KeyValue = 1;
  16.                 break;
  17.             case (0xe0):
  18.                 KeyValue = 0;
  19.                 break;
  20.             }
  21.             P1 = 0x0f;
  22.             if (P1!=0x0f) {
  23.                 switch (P1) {
  24.                 case (0x07):
  25.                     KeyValue += 12;
  26.                     break;
  27.                 case (0x0b):
  28.                     KeyValue += 8;
  29.                     break;
  30.                 case (0x0d):
  31.                     KeyValue += 4;
  32.                     break;
  33.                 case (0x0e):
  34.                     KeyValue += 0;
  35.                     break;
  36.                 }
  37.        KeyUpdated = 1;
  38.             }
  39.         }
  40.     }
  41. //        while ((a < 50) && (P1!=0x0f)) {
  42. //                delay(10);
  43. //                a++;
  44. //        }
  45. }
  46. bit Hex_En = 0;
  47. void main() {
  48.     chuankouInit();
  49.     while (1) {
  50.         keypros();
  51.         P0 = ~duan[KeyValue];
  52.         if(KeyUpdated)
  53.         {
  54.             while (TI);
  55.             if(Hex_En)
  56.             {
  57.                 SBUF = KeyValue;///不+'0'发数值,+'0'发字符
  58.             } else {
  59.                 if(KeyValue < 10)
  60.                 {
  61.                     SBUF = KeyValue + '0';///不+'0'发数值,+'0'发字符
  62.                 } else {
  63.                     SBUF = KeyValue + 0x37;//10 + 0x37 = 0x41 = 'A'
  64.                 }
  65.             }
  66.             KeyUpdated = 0;
  67.         }
  68.     }
  69. }
  70. void chuankou() interrupt 4 {
  71.     uchar receiveData;
  72.     receiveData = KeyValue;
  73.     if(RI)
  74.     {
  75.         RI = 0;                   //收完
  76.     }
  77.     if(TI)
  78.     {
  79.         TI = 0;   //发完
  80.     }
  81. }
ID:213173 发表于 2022-3-10 06:35 | 显示全部楼层
串口发送放在按键松手后
  1. #include <reg52.h>
  2. typedef unsigned char uchar;
  3. typedef unsigned int  uint;
  4. uchar code duan[] = {0x3f,0x06,0x5b,0x4f,
  5.                         0x66,0x6d,0x7d,0x07,
  6.                         0x7f,0x6f,0x77,0x7c,
  7.                         0x39,0x5e,0x79,0x71};
  8. uchar KeyValue;
  9. void delay(uint z)
  10. {
  11.         uint y;
  12.         for (;z>0;z--)
  13.                 for (y = 0; y < 110; y++);
  14. }
  15. void chuankouInit()
  16. {
  17.         TMOD = 0x20;
  18.         TH1 = 243;
  19.         TL1 = 243;
  20.         TR1 = 1;
  21.         SCON = 0x50;
  22.         PCON = 0x80;  //倍波特率
  23.         ES = 1;
  24.         EA = 1;
  25. }
  26. void keypros()
  27. {
  28.         P3 = 0xf0;//0xff不行,一定要控制变量先行后列或者先列后行否则要列出所有情况
  29.         if (P3!=0xf0)
  30.         {
  31.                 delay(10);
  32.                 if (P3!= 0xf0)
  33.                 {
  34.                         switch (P3)
  35.                         {
  36.                                 case (0x70): KeyValue = 3;break;
  37.                                 case (0xb0): KeyValue = 2;break;
  38.                                 case (0xd0): KeyValue = 1;break;
  39.                                 case (0xe0): KeyValue = 0;break;
  40.                         }
  41.                         P3 = 0x0f;
  42.                         switch (P3)
  43.                         {
  44.                                 case (0x07): KeyValue += 12;break;
  45.                                 case (0x0b): KeyValue += 8;break;
  46.                                 case (0x0d): KeyValue += 4;break;
  47.                                 case (0x0e): KeyValue += 0;break;
  48.                         }
  49.                         while(P3 != 0x0f);
  50.                         SBUF = KeyValue;
  51.                         while (!TI);
  52.                         TI = 0;   //发完
  53.                 }
  54.         }
  55. }
  56. void main()
  57. {
  58.         chuankouInit();
  59.         while (1)
  60.         {
  61.                 keypros();
  62.                 P0 = ~duan[KeyValue];
  63.         }
  64. }
  65. void chuankou() interrupt 4
  66. {
  67.         uchar receiveData;
  68.         receiveData = KeyValue;
  69.         RI = 0;                   //收完
  70. }
ID:1007138 发表于 2022-3-10 12:05 | 显示全部楼层
lkc8210 发表于 2022-3-9 22:11
先假设你的矩阵按键和串口设置代码正确
感谢,懂了,但是为什么有些数据会不正常显示呢?出现一个口,然后多按几次有正常了,这是我单片机的问题还是串口助手问题还是什么?
wulin 发表于 2022-3-10 06:35
串口发送放在按键松手后
串口发送放在按键松手后
ID:161164 发表于 2022-3-10 17:13 | 显示全部楼层
小小彩姬 发表于 2022-3-10 12:05
感谢,懂了,但是为什么有些数据会不正常显示呢?出现一个口,然后多按几次有正常了,这是我单片机的问题 ...
感觉是晶振问题
如果用的是12MHz的晶振会有误差的
每当需要串口通讯时
最好用11.0952MHz或倍数的晶振
ID:1007138 发表于 2022-3-10 17:46 | 显示全部楼层
lkc8210 发表于 2022-3-10 17:13
感觉是晶振问题
如果用的是12MHz的晶振会有误差的
每当需要串口通讯时
haode,xiexie
ID:121859 发表于 2022-3-10 18:06 | 显示全部楼层
发送程序放到中断外面,比如按键检测那里就可以了。现在的情况是必须要接收到一个数据才能发送键值。想要发送ASCII码 ,可以将键值+0x30
