查看: 3262|回复: 1
51单片机+ADC0832双通道+NTC热敏电阻测温度+数码管显示仿真程序
单片机NTC热敏电阻仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
数据采集用的双通道的ADC0832模数转换芯片
  1. /******************************
  2. 20221221 prepare by zousongzhu
  3. ******************************/
  4. #include<reg52.h>  //  包含51单片机寄存器定义的头文件;
  5. #include <intrins.h>
  6. #include <math.h>
  7. sbit P34=P3^4;
  8. sbit P35=P3^5;
  9. sbit P36=P3^6;
  10. sbit P37=P3^7;
  11. sbit CS   = P1^0;//ADC0832 PIN1
  12. sbit Clk = P1^1;//ADC0832 PIN7
  13. sbit DATI = P1^2;//ADC0832 PIN5
  14. sbit DATO = P1^2;//ADC0832 PIN6
  15. unsigned int  Tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//共阴数码管显示0~9的段码表
  16. //unsigned int  Tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//共阳数码管显示0~9的段码表
  17. /*******************************共阴LED段码表*******************************/
  18. unsigned char code temptab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  19. /*******************************定义全局变量********************************/
  20. unsigned char dat = 0x00;      //AD值
  21. unsigned char CH;       //通道变量
  22. unsigned int sum=0;
  23. unsigned char sec_time,sec;        //记录中断次数
  24. unsigned char second,min,hour,year,month,day;        //储存秒
  25. //数组下标就是对应温度
  26. code unsigned char Temp_adc[]={
  27. 224,222,221,219,218,216,214,213,211,209,207,205,203,201,199,197,195,193,191,188,
  28. 186,184,181,179,177,174,172,169,167,164,162,159,157,154,151,149,146,144,141,138,
  29. 136,133,131,128,126,123,121,118,116,113,111,108,106,104,101, 99, 97, 95, 92, 90,
  30. 88, 86, 84, 82, 80, 78, 76, 74, 73, 71, 69, 67, 66, 64, 62, 61, 59, 58, 56, 55,
  31. 53, 52, 51, 49, 48, 47, 46, 44, 43, 42, 41, 40, 39, 38, 37, 36, 35, 34, 33, 32,};
  32. //查找相近值,并返回下标
  33. unsigned char Find_data(unsigned char *a,unsigned char x,unsigned char len)
  34. {
  35.         unsigned char i,min,r=0;
  36.
  37.         min=abs(*a-x);
  38.         for(i=0;i<len;i++)
  39.         {
  40.                 if(abs(a[i]-x)<min)
  41.                 {
  42.                         min=abs(a[i]-x);
  43.                         r=i;
  44.                 }
  45.         }
  46.
  47.         return r;
  48. }
  49. /****************************************************************************
  50. 函数功能:AD转换子程序
  51. 入口参数:CH
  52. 出口参数:dat
  53. ****************************************************************************/
  54. unsigned char adc0832(unsigned char CH)
  55. {
  56.       unsigned char i,test,adval;
  57.            unsigned char m;
  58.      adval = 0x00;
  59.      test = 0x00;
  60.      Clk = 0;       //初始化
  61.      DATI = 1;
  62.      _nop_();
  63.      CS = 0;
  64.      _nop_();
  65.      Clk = 1;
  66.      _nop_();
  67.    if ( CH == 0 )      //通道选择
  68.    {
  69.        Clk = 0;
  70.        DATI = 1;      //通道0的第一位
  71.        _nop_();
  72.        Clk = 1;
  73.         _nop_();
  74.         Clk = 0;
  75.        DATI = 0;      //通道0的第二位
  76.        _nop_();
  77.        Clk = 1;
  78.        _nop_();
  79.     }
  80.     else
  81.     {
  82.        Clk = 0;
  83.       DATI = 1;      //通道1的第一位
  84.       _nop_();
  85.       Clk = 1;
  86.       _nop_();
  87.       Clk = 0;
  88.       DATI = 1;      //通道1的第二位
  89.      _nop_();
  90.       Clk = 1;
  91.       _nop_();
  92.    }
  93.       Clk = 0;
  94.       DATI = 1;
  95.     for( i = 0;i < 8;i++ )      //读取前8位的值
  96.     {
  97.        _nop_();
  98.        adval <<= 1;
  99.        Clk = 1;
  100.        _nop_();
  101.        Clk = 0;
  102.        if (DATO)
  103.           adval |= 0x01;
  104.       else
  105.           adval |= 0x00;
  106.     }
  107.       for (i = 0; i < 8; i++)      //读取后8位的值
  108.       {
  109.            test >>= 1;
  110.            if (DATO)
  111.               test |= 0x80;
  112.            else
  113.               test |= 0x00;
  114.           _nop_();
  115.           Clk = 1;
  116.           _nop_();
  117.           Clk = 0;
  118.       }
  119.       if (adval == test)      //比较前8位与后8位的值,如果不相同舍去。若一直出现显示为零,请将该行去掉
  120.        dat = test;
  121.        nop_();
  122.        CS = 1;        //释放ADC0832
  123.        DATO = 1;
  124.        Clk = 1;
  125.
  126.        return dat;
  127.
  128. }
  129. /***********************************************************************
  130. ……………………
  131. …………限于本文篇幅 余下代码请从51黑下载附件…………
Keil代码与Proteus仿真下载: 51单片机 ADC0832 NTC 测温 双通道.7z (64.39 KB, 下载次数: 127)
收藏收藏3 分享淘帖 顶1 踩
ID:432633 发表于 2023-10-26 12:34 | 只看该作者
请问 热敏电阻型号是哪个呀
