帖子
查看: 1266|回复: 2
Proteus仿真 4x4键盘+虚拟终端相关问题
仿真图如下 要求键盘输入显示在虚拟终端 请教思路
下面的代码可以利用吗
#include<reg51.h>
#include<absacc.h>
#include<intrins.h>
#define uint unsigned int
uchar code segtab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,
0xc6,0xa1,0x86,0x8e,0x89,0x8c,0xff,0xbf,0x8d};
uchar dbuf[4]={0x12,0x12,0x12,0x11};
uchar kbuf[4]={0,0,0,0};
void delay(void)
{ uchar i;
  for(i=0;i<250;i++);
void init_serial(void)
{ SCON=0x50;
  TMOD=0x20;
  PCON=PCON&0x7f;
  TH1=-3;
  TL1=-3;
  TR1=1;
uchar getkey()
   uchar key=0;
   uchar scode,recode;
   P2=0xf0;
   if((P2&0xf0)!=0xf0)
        P2=0xf0;
        if((P2&0xf0)!=0xf0)
           {scode=0xfe;
            while((scode&0x10)!=0)
               { P2=scode;
        if((P2&0xf0)!=0xf0)
        {recode=P2&0xf0;
        scode=0x10;
        while(scode!=0)
                    if(recode&scode==0)
                         { while((P2&0xf0)!=0xf0)
                                   P2=0xf0;
                          return(key);
                        {scode=scode<<1;
                         key++;
             {   scode=_crol_(scode,1);
                 key=key+4;
    return(0xff);
void main(void)
{ uchar i;
  uchar dat;
  P0=0xff;
  init_serial();
       RI=0;
     dat=SBUF;
     if(dat==0x41)
         for(i=4;i>0;i--)
             {SBUF=kbuf[i-1]+0x30;
              while(TI==0);
              TI=0;
         RI=0;
         dat=SBUF;
         for(i=0;i<4;i++)dbuf[i]=0x12;
举报
ID:739545 发表于 2021-6-17 10:34 | 只看该作者
键盘扫描部分可以利用,但是否能实现你的功能,需要你重新整理
举报
ID:893765 发表于 2021-6-17 10:35 | 只看该作者
谢谢您 要求键盘输入显示在虚拟终端 求教思路
举报
