查看: 5269|回复: 4
51hei板数码管显示0-9999,求指导
ID:35727 发表于 2012-4-4 21:31 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include<reg51.h>
#inclede<intrins.h>
#define uint  unsigned int
uchar  tape[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f} ;
sbit duan=P2^6;
sbit wei=P2^7;
uchar a,qian,bai,shi,ge;
uint   num;
void display();
void delay(uint z)
    uint x,y;
 for(x=z;x>0;x--)
 for(y=110;y>0;y--);
 main()
{ TMOD=0x01;
    TH0=(65536-50000)/256;
    TL0=(65536-50000)%256;
 EA=1;
 ET0=1;
 TR0=1;
 num=0;
   {  if(a==20)
     { a=0;
  num++;
      if(num==9999)
     num=0;
      qian=num/1000;
         bai=num%1000/100;
         shi=num%100/10;
   ge=num%10;
      display();
void display()
{    P0=0xf7;
 wei=1;
 wei=0;
 duan=1;
 P0=tape[ge];
 duan=0;
 delay(6);
 P0=0xfb;
  wei=1;
 wei=0;
 duan=1;
 P0=tape[shi];
 duan=0;
 delay(6);
   P0=0xfd;
  wei=1;
 wei=0;
 duan=1;
 P0=tape[bai];
 duan=0;
 delay(6);
  P0=0xfe;
  wei=1;
 wei=0;
 duan=1;
 P0=tape[qian];
 duan=0;
 delay(6);
void time0() interrupt 1
  a++;
为什么数码管上只有千位是保持不动。其他位都是闪烁的啊,怎样才能保证其他位也不闪烁啊
ID:37147 发表于 2012-4-5 21:50 | 只看该作者
   ORG 0000H
LJMP MIAN
ORG 000BH
LJMP INT_T0
ORG 0030H
MIAN:   MOV DPTR,#TABLE
         TABLE:DB 3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH
   MOV R1,#200
        MOV R2,#20
        MOV R3,#0
        MOV R4,#0
       MOV R5,#0
         MOV R6,#0
         MOV TMOD,#02H
         MOV TH0,#06H
         MOV TL0,#00H
SETB EA
SETB ET0
SETB TR0
 LOOP:
         MOV P2,#07H
         MOV A,R3
         MOVC A,@A+DPTR
         MOV P0,A
LCALL DELAY10ms
         MOV P2,#06H
         MOV A,R4
         MOVC A,@A+DPTR
         MOV P0,A
LCALL DELAY10ms
         MOV P2,#05H
         MOV A,R5
         MOVC A,@A+DPTR
         MOV P0,A
LCALL DELAY10ms
         MOV P2,#04H
         MOV A,R6
         MOVC A,@A+DPTR
         MOV P0,A
LCALL DELAY10ms
LJMP LOOP
INT_T0:   DJNZ R1,QUIT
           MOV R1,#200
           DJNZ R2,QUIT
           MOV R2,#20
INC R3
CJNE R3,#10,QUIT
MOV R3,#0
INC R4
CJNE R4,#10,QUIT
MOV R4,#0
INC R5
CJNE R5,#10,QUIT
MOV R5,#0
INC R6
CJNE R6,#10,QUIT
MOV R6,#0
 QUIT:RETI
DELAY10ms:
                     MOV 40H,#10
        LOOP1:   MOV 41H,#200
                     DJNZ 41,$
                     DJNZ 40H,LOOP1
                     RET
END
ID:35727 发表于 2012-4-4 23:16 | 只看该作者
谢谢啊。没问题
ID:37419 发表于 2012-4-4 22:24 | 只看该作者
#include<reg51.h>
sbit duan=P2^6;
sbit wei=P2^7;
uint num;
void display(uchar qian,uchar bai,uchar shi,uchar ge);
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
main()
{ TMOD=0x01;
EA=1;
ET0=1;
TR0=1;
num=0;
{ if(a==20)
{ a=0;
num++;
if(num==9999)
num=0;
qian=num/1000;
bai=num%1000/100;
shi=num%100/10;
ge=num%10;
display(qian,bai,shi,ge);
{ P0=0xf7;
wei=1;
wei=0;
duan=1;
P0=tape[ge];
duan=0;
delay(6);
P0=0xfb;
wei=1;
wei=0;
duan=1;
P0=tape[shi];
duan=0;
delay(6);
P0=0xfd;
wei=1;
wei=0;
duan=1;
P0=tape[bai];
duan=0;
delay(6);
P0=0xfe;
wei=1;
wei=0;
duan=1;
P0=tape[qian];
duan=0;
delay(6);
a++;
因板子型号不同,没有进行具体测试,改程序的问题主要是display();函数的位置不对,已经帮你调整好了,你试试应该没问题了
ID:34099 发表于 2012-4-4 22:22 | 只看该作者
动态扫描的时间短一点 可以改为delay(1);
