查看: 2936|回复: 3
stc15单片机频率产生器(粗调+微调)源程序
ID:223281 发表于 2017-12-5 17:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
频率产生器,可以粗调+微调
0Hz -- 999Hz
粗调:直接输入数字,并按确认
微调:加减1步进调整
设置LED显示频率效果
可以多次输入,并设置了复位键
  1. #include "stc15.h"
  2. #include "intrins.h"
  3. #include "gpio.h"
  4. #include "595hc.h"
  5. #define MAIN_Fosc       11059200L   //定义主时钟
  6. u16 counter = 0;
  7. u8 countdown = 5;
  8. u16 i,j,k;
  9. bit start_flag = 0;
  10. bit next_flag = 0;
  11. bit confirm_flag = 0;
  12. bit up = 0;
  13. bit down = 0;
  14. u16 Fre_input = 0;
  15. u16 Fre_counter = 0;
  16. u8 code start[8] = {1,22,24,25,26,17,17,17};
  17. //      Y     P04      P05      P06      P07
  18. //            |        |        |        |
  19. //  X         |        |        |        |
  20. //  P00 ---- K00 ---- K01 ---- K02 ---- K03 ----
  21. //            |        |        |        |
  22. //  P01 ---- K04 ---- K05 ---- K06 ---- K07 ----
  23. //            |        |        |        |
  24. //  P02 ---- K08 ---- K09 ---- K10 ---- K11 ----
  25. //            |        |        |        |
  26. //  P03 ---- K12 ---- K13 ---- K14 ---- K15 ----
  27. //            |        |        |        |
  28. u8  KeyCode = 0;    //给用户使用的键码, 1~16有效
  29. u8  IO_KeyState = 0, IO_KeyState1 = 0, IO_KeyHoldCnt = 0;    //行列键盘变量
  30. static u8 get_flag = 1;
  31. void IO_KeyDelay(void)
  32. {
  33.         i = 60;
  34.         while (--i);
  35. }
  36. void IO_KeyScan(void)    //50ms call
  37. {
  38.         j = IO_KeyState1;   //保存上一次状态
  39.         P0 = 0xf0;  //X低,读Y
  40.         IO_KeyDelay();
  41.         IO_KeyState1 = P0 & 0xf0;
  42.         P0 = 0x0f;  //Y低,读X
  43.         IO_KeyDelay();
  44.         IO_KeyState1 |= (P0 & 0x0f);
  45.         IO_KeyState1 ^= 0xff;   //取反
  46.         if (j == IO_KeyState1)   //连续两次读相等
  47.         {
  48.                 j = IO_KeyState;
  49.                 IO_KeyState = IO_KeyState1;
  50.                 if (IO_KeyState != 0)    //有键按下
  51.                 {
  52.                         F0 = 0;
  53.                         if (j == 0)  F0 = 1; //第一次按下
  54.                         else if (j == IO_KeyState)
  55.                         {
  56.                                 if (++IO_KeyHoldCnt >= 20)   //1秒后重键
  57.                                 {
  58.                                         IO_KeyHoldCnt = 18;
  59.                                         F0 = 1;
  60.                                 }
  61.                         }
  62.                         if (F0)
  63.                         {
  64.                                 next_flag = 1;
  65.                                 switch(IO_KeyState)
  66.                                 {
  67.                                         case 0x11: get_flag     = 0   ;break;//0
  68.                                         case 0x12: get_flag     = 1   ;break;//1
  69.                                         case 0x14: get_flag     = 2   ;break;//2
  70.                                         case 0x18: get_flag     = 3   ;break;//3
  71.                                         case 0x21: get_flag     = 4   ;break;//4
  72.                                         case 0x22: get_flag     = 5   ;break;//5
  73.                                         case 0x24: get_flag     = 6   ;break;//6
  74.                                         case 0x28: get_flag     = 7   ;break;//7
  75.                                         case 0x41: get_flag     = 8   ;break;//8
  76.                                         case 0x42: get_flag     = 9   ;break;//9
  77.                                         case 0x44: get_flag     = 10  ;break;//a
  78.                                         case 0x48: get_flag     = 11  ;break;//b
  79.                                         case 0x81: get_flag     = 12  ;break;//c
  80.                                         case 0x82: up                             = 1   ;break;//d
  81.                                         case 0x84: down                     = 1   ;break;//e
  82.                                         case 0x88: IAP_CONTR    = 0x20;break;//复位
  83.                                         default:   get_flag     = 16  ;break;
  84.                 }
  85.                         }
  86.                 }
  87.                 else    IO_KeyHoldCnt = 0;
  88.         }
  89.         P0 = 0xff;
  90. }
  91. /********************延时函数******************************/
  92. void Delay1ms()                //@11.0592MHz
  93. {
  94.         _nop_();
  95.         _nop_();
  96.         _nop_();
  97.         i = 11;
  98.         j = 190;
  99.         do
  100.         {
  101.                 while (--j);
  102.         } while (--i);
  103. }
  104. void Delay_ms(u16 xms)
  105. {
  106.         for (k=0;k<xms;k++)
  107.         {
  108.                 Delay1ms();
  109.         }
  110. }
  111. /********************** Timer0初始化 ************************/
  112. void Timer0Init(void)                //1毫秒 @11.0592MHz
  113. {
  114.         AUXR = 0x80;                //定时器时钟1T模式
  115.         TMOD = 0x00;                //设置定时器模式
  116.         TL0  = 0xCD;                //设置定时初值
  117.         TH0  = 0xD4;                //设置定时初值
  118.         EA   = 1;                    //开启总中断
  119.         ET0  = 1;                //允许定时器0中断
  120.         TF0  = 0;                //清除TF0标志
  121.         TR0  = 1;                //定时器0开始计时
  122. }
  123. /********************** Timer0中断函数 ************************/
  124. void timer0 (void) interrupt 1
  125. {
  126.         counter++;
  127.     Fre_counter++;
  128.         DisplayScan();
  129. }
  130. /********************** 频率产生 ************************/
  131. void Fre_output(u16 Fre)//T=Fre(ms);f=1000/Fre
  132. {
  133.     LED8[0] = 15;   //F
  134.     LED8[1] = 29;   //r
  135.     LED8[2] = 14;   //E
  136.     LED8[3] = 17;   //-
  137.     LED8[4] = 17;   //-
  138.     Fre = 500 / Fre;
  139.     if(Fre_counter >= Fre)
  140.     {
  141.         P16 = !P16;
  142.         Fre_counter = 0;
  143.     }
  144. }
  145. /********************** 步进加_减 ************************/
  146. //返回1:加
  147. //返回0:减
  148. int up_down(bit up,bit down)
  149. {
  150.         if(up == 1)        //步进 - 加1
  151.         {
  152.                 LED8[7] = LED8[7] + 1;
  153.                 if(LED8[7] == 10)
  154.                 {
  155.                         if(LED8[6] == 9)
  156.                         {
  157.                                 if(LED8[5] == 9)
  158.                                 {
  159.                                         LED8[7] = 9;
  160.                                         LED8[6] = 9;
  161.                                         LED8[5] = 9;
  162.                                 }
  163.                                 else
  164.                                 {
  165.                                         LED8[7] = 0;
  166.                                         LED8[6] = 0;
  167.                                         LED8[5] ++;
  168.                                 }
  169.                         }
  170.                         else
  171.                         {
  172.                                 LED8[7] = 0;
  173.                                 LED8[6] ++;
  174.                         }
  175.                 }
  176.
  177.                 return 1;
  178.         }
  179.         else if (down == 1)                                        //步进 - 减1
  180.         {
  181.                 LED8[7] = LED8[7] - 1;
  182.                 if(LED8[7] < 0)
  183.                 {
  184.                         if(LED8[6] == 0 )
  185.                         {
  186.                                 if(LED8[5] == 0)
  187.                                 {
  188.                                         LED8[7] = 0;
  189.                                         LED8[6] = 0;
  190.                                         LED8[5] = 0;
  191.                                 }
  192.                                 else
  193.                                 {
  194.                                         LED8[7] = 9;
  195.                                         LED8[6] = 9;
  196.                                         LED8[5] --;
  197.                                 }
  198.                         }
  199.                         else
  200.                         {
  201.                                 LED8[7] = 9;
  202.                                 LED8[6] --;
  203.                         }
  204.                 }
  205.
  206.                 return 0;
  207.         }
  208.
  209. }
  210. /********************** 主函数 ************************/
  211. void main(void)
  212. {
  213.         GPIO();
  214.         Timer0Init();
  215.         P16 = 1;
  216.     P17 = 1;
  217.     for (k = 0; k < 8; k++) LED8[k] = 17;
  218.     Fre_counter = 0;
  219.     counter = 0;
  220.
  221.     while(1)
  222.     {
  223.                         if(counter >= 50) //50ms扫描键盘
  224.                         {
  225.                                 IO_KeyScan();
  226.                                 counter = 0;
  227.                         }
  228.
  229.                         if(next_flag==0) //提示信息:input
  230.                         {
  231.                                         for(i=0; i<5; i++)  LED8[i] = start[i];
  232.                         }
  233.                         if(next_flag==1) //有按键按下
  234.                         {
  235.                                         if(get_flag != 12) //输入目标频率:10~999
  236.                                         {
  237.                                                         LED8[5] = LED8[6];//移位
  238.                                                         LED8[6] = LED8[7];
  239.                                                         LED8[7] = get_flag;
  240.                                                         next_flag = 0;
  241.                                         }
  242.                                         else //确认按键
  243.                                         {
  244.                                                 Fre_input = LED8[5] * 100 + LED8[6] * 10 + LED8[7];
  245.
  246.                                                 switch(up_down(up,down)) //步进微调
  247.                                                 {
  248.                                                         case 0: Fre_input --; //减1
  249.        down = 0;
  250.        break;
  251.                                                         case 1: Fre_input ++; //加1
  252.        up = 0;
  253.        break;
  254.                                                         default:break;
  255.                                                 }
  256.
  257.                                                 Fre_output(Fre_input);
  258.                                                 P17 = !P17;
  259. ……………………
  260. …………限于本文篇幅 余下代码请从51黑下载附件…………
频率产生器(粗调+微调).rar (54.25 KB, 下载次数: 29)
收藏收藏1 分享淘帖 顶 踩
ID:60656 发表于 2017-12-12 13:13 | 只看该作者
多谢分享,学习一下
ID:6633 发表于 2017-12-31 21:25 | 只看该作者
学习学习
ID:381390 发表于 2019-9-2 19:33 | 只看该作者
学习,
多谢
