查看: 7574|回复: 0
STM32 GPIO的PD2和PD3管脚控制LED1和LED2两个灯闪烁
ID:226264 发表于 2017-12-12 18:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
STM32F103的一个例子
  1. /*  本实验使得GPIO的PD2和PD3管脚控制STM32神舟IV号开发板的LED1和LED2两个灯进行闪烁 */
  2. #define     __IO    volatile
  3. typedef unsigned           int uint32_t;
  4. typedef __IO uint32_t  vu32;
  5. typedef unsigned short     int uint16_t;
  6. #define GPIO_Pin_0                 ((uint16_t)0x0001)  /*!< Pin 0 selected */
  7. #define GPIO_Pin_1                 ((uint16_t)0x0002)  /*!< Pin 1 selected */
  8. #define GPIO_Pin_2                 ((uint16_t)0x0004)  /*!< Pin 2 selected */
  9. #define GPIO_Pin_3                 ((uint16_t)0x0008)  /*!< Pin 3 selected */
  10. #define GPIO_Pin_4                 ((uint16_t)0x0010)  /*!< Pin 4 selected */
  11. #define GPIO_Pin_5                 ((uint16_t)0x0020)  /*!< Pin 5 selected */
  12. #define GPIO_Pin_6                 ((uint16_t)0x0040)  /*!< Pin 6 selected */
  13. #define GPIO_Pin_7                 ((uint16_t)0x0080)  /*!< Pin 7 selected */
  14. #define GPIO_Pin_8                 ((uint16_t)0x0100)  /*!< Pin 8 selected */
  15. #define GPIO_Pin_9                 ((uint16_t)0x0200)  /*!< Pin 9 selected */
  16. #define GPIO_Pin_10                ((uint16_t)0x0400)  /*!< Pin 10 selected */
  17. #define GPIO_Pin_11                ((uint16_t)0x0800)  /*!< Pin 11 selected */
  18. #define GPIO_Pin_12                ((uint16_t)0x1000)  /*!< Pin 12 selected */
  19. #define GPIO_Pin_13                ((uint16_t)0x2000)  /*!< Pin 13 selected */
  20. #define GPIO_Pin_14                ((uint16_t)0x4000)  /*!< Pin 14 selected */
  21. #define GPIO_Pin_15                ((uint16_t)0x8000)  /*!< Pin 15 selected */
  22. #define GPIO_Pin_All               ((uint16_t)0xFFFF)  /*!< All pins selected */
  23. #define RCC_APB2Periph_AFIO              ((uint32_t)0x00000001)
  24. #define RCC_APB2Periph_GPIOA             ((uint32_t)0x00000004)
  25. #define RCC_APB2Periph_GPIOB             ((uint32_t)0x00000008)
  26. #define RCC_APB2Periph_GPIOC             ((uint32_t)0x00000010)
  27. #define RCC_APB2Periph_GPIOD             ((uint32_t)0x00000020)
  28. /************ GPIOD <*************/
  29. typedef struct
  30. {
  31.   __IO uint32_t CRL;
  32.   __IO uint32_t CRH;
  33.   __IO uint32_t IDR;
  34.   __IO uint32_t ODR;
  35.   __IO uint32_t BSRR;
  36.   __IO uint32_t BRR;
  37.   __IO uint32_t LCKR;
  38. } GPIO_TypeDef;
  39. typedef struct
  40. {
  41.   __IO uint32_t CR;
  42.   __IO uint32_t CFGR;
  43.   __IO uint32_t CIR;
  44.   __IO uint32_t APB2RSTR;
  45.   __IO uint32_t APB1RSTR;
  46.   __IO uint32_t AHBENR;
  47.   __IO uint32_t APB2ENR;
  48.   __IO uint32_t APB1ENR;
  49.   __IO uint32_t BDCR;
  50.   __IO uint32_t CSR;
  51. } RCC_TypeDef;
  52. /********* GPIOD管脚的内存对应地址 *******/
  53. #define PERIPH_BASE           ((uint32_t)0x40000000)
  54. #define APB2PERIPH_BASE       (PERIPH_BASE + 0x10000)
  55. #define GPIOD_BASE            (APB2PERIPH_BASE + 0x1400)
  56. #define GPIOD               ((GPIO_TypeDef *) GPIOD_BASE)
  57. /************ RCC时钟 <*************/
  58. #define AHBPERIPH_BASE        (PERIPH_BASE + 0x20000)
  59. #define RCC_BASE              (AHBPERIPH_BASE + 0x1000)
  60. #define RCC                 ((RCC_TypeDef *) RCC_BASE)
  61. void Delay(vu32 nCount);
  62. int main(void)         //main是程序入口
  63. {
  64.           /* 使能APB2总线的时钟,对GPIO的端口D时钟使能 */
  65.           RCC->APB2ENR |= RCC_APB2Periph_GPIOD;
  66.         /*-- GPIO Mode Configuration速度,输入或输出 -----------------------*/
  67.         /*-- GPIO CRL Configuration 设置IO端口低8位的模式(输入还是输出)---*/
  68.         /*-- GPIO CRH Configuration 设置IO端口高8位的模式(输入还是输出)---*/
  69.         GPIOD->CRL &=  0xFFFF00FF;
  70.         GPIOD->CRL |=  0x00003300;         /* 设置GPIOD的PD2和PD3配置为通用推挽模式输出50MHZ */
  71.           while (1)
  72.           {
  73.           /* 对BRR设置为1,则GPIO输出为0 */
  74.                   GPIOD->BRR = GPIO_Pin_2;
  75.                 GPIOD->BRR = GPIO_Pin_3;
  76.                 Delay(0x2FFFFF);
  77. ……………………
  78. …………限于本文篇幅 余下代码请从51黑下载附件…………
test2.7z (207.16 KB, 下载次数: 20)
