查看: 1268|回复: 1
用pic想做一个掉电保存,低于4V保存数据,要么就死在里面,要么读出来的数据乱七八...
ID:261626 发表于 2017-12-15 15:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"pic.h"
__CONFIG(0xe824);
void Init();
void dis(void);
void display();
void ep_write();
void delay(unsigned int ms);
unsigned int flag_254us,value;
unsigned int n;
const unsigned char number[10] ={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; //0~9共阳数码管段码表
unsigned char led7;
unsigned char led8;
unsigned char ge,shi;
    unsigned int i,j;
    for(i=0;i<ms;i++)
    for(j=0;j<120;j++);
void Init()
    TRISC = 0x00;
    PORTC = 0x7f;//段选口
    TRISA5 = 1;
    ANSEL = 0x00;
    TRISB = 0x01;
    ANSELH = 0x00;//位选口
    //AD转换
    TRISA1 = 1;
    ANS1 = 1;
    ADCON0 = 0x44;//AN1  f8
    ADCON1 = 0x80;//右对齐,VDD VSS
    ADIE = 0;//中断关
    T2CON = 0x01;//16分频
    PR2 = 250;
    TMR2 = 0;//1*16*250*500ns =254us
    TMR2IE = 1;
    TMR2IF = 0;
    PEIE = 1;//外设中断
    TMR2ON = 1;
unsigned int AD_convert()
    value = 0;
    ADON = 1;
    GODONE = 1;
    while(!GODONE);
    NOP();
    NOP();
    value = ADRESH;
    value = value << 8;
    value += ADRESL;
    return value;
void interrupt t0()
    if(TMR2IF)
        TMR2IF = 0;
        flag_254us++;
        if(flag_254us>1000)
            flag_254us = 0;
            n++;
//void ep_write()
//    shi = n/10;
//    ge = n%10;
//    EEPROM_WRITE(0x05,ge);//保存个位
//    EEPROM_WRITE(0x06,shi);//保存十位
//unsigned long ep_read()
//    ge = EEPROM_READ(0x05);
//    shi = EEPROM_READ(0x06);
//    n = ge + (shi*10) ;
//    return n;
void display(led8,led7)
    RB3 = 1;
    PORTC = number[led8];
    delay(1);
    RB3 = 0;
    PORTC = 0x00;
    RB2 = 1;
    PORTC = number[led7];
    delay(1);
    RB2 = 0;
    PORTC = 0x00;
void dis(void)
    led8 = n/10;
    led7 = n%10;
    display(led8,led7);
    GIE = 1;
    TMR2IE = 1;
    Init();
    n=EEPROM_READ(0x05);
        if(!RA5)
            n=10;
        dis();
        if(n==100) n=0;
        if(AD_convert() < 400)
            EEPROM_WRITE(0x05,n);
ID:261626 发表于 2017-12-15 15:57 | 只看该作者
直接调用pic.h文件的EEPROM。没有自己写
