手头上攒了一些手机电池不知道干嘛就寻思着做一些小玩意,于是就有了一个主意就是摇摇棒即简单又好玩,本人喜欢小而巧的东西所以就把这个东西做的很小。
上图是摇摇棒的原理利用人的视觉暂留结合单片机控制LED的亮灭就可以在空中显示字符或者图标
上图是电路图为了把东西做小我选择了STC15F104单片机它有8个引脚去除VCC和GND还有6个I/O口可以显示一些简单的字母和数字单片机内部自带了EEPROM所以利用它可以存储每一次显示的状态(每一次的开关电源就可以切换到下一个显示的字符)程序在最后面。
显示效果:
单片机源程序如下: - #include
- #define uchar unsigned char
- #define EN_EPROM 0x83; //使能EEPROM
- #define S_MODE 0x00; //待机模式
- #define R_MODE 0x01; //读模式
- #define W_MODE 0x02; //写模式
- #define F_MODE 0x03; //擦除模式
- sfr IAP_DATA = 0xC2;
- sfr IAP_ADDRH = 0xC3;
- sfr IAP_ADDRL = 0xC4;
- sfr IAP_CMD = 0xC5;
- sfr IAP_TRIG = 0xC6;
- sfr IAP_CONTR = 0xC7;
- void init();
- uchar num=0,m=0;
- uchar read_dat(uchar addr_h,uchar addr_l);
- void erase_dat(uchar addr_h,uchar addr_l);
- void write_dat(uchar addr_h,uchar addr_l,uchar w_dat);
- unsigned char code tab[10][32]={
- 0xe7,0xc3,0xc1,0xe0,0xc1,0xc3,0xe7,0xff,
- 0xff,0xff,0xff,0xe7,0xc3,0xc1,0xe0,0xc1,
- 0xc3,0xe7,0xff,0xff,0xff,0xff,0xe7,0xc3,
- 0xc1,0xe0,0xc1,0xc3,0xe7,0xff,0xff,0xff
- 0xff,0xff,0xde,0xc0,0xde,0xff,0xff,0xff,
- 0xc3,0xe7,0xff,0xff,0xff,0xff,0xff,0xc1,
- 0xfe,0xfe,0xfe,0xfe,0xc1,0xff,0xff,0xff
- 0xde,0xed,0xf3,0xf3,0xed,0xde,0xff,0xff,
- 0xff,0xff,0xff,0xde,0xed,0xf3,0xf3,0xed,
- 0xde,0xff,0xff,0xff,0xff,0xff,0xff,0xde,
- 0xed,0xf3,0xf3,0xed,0xde,0xff,0xff,0xff
- 0xfb,0xfd,0xd6,0xe8,0xd6,0xfd,0xfb,0xff,
- 0xff,0xff,0xff,0xfb,0xfd,0xd6,0xe8,0xd6,
- 0xfd,0xfb,0xff,0xff,0xff,0xff,0xfb,0xfd,
- 0xd6,0xe8,0xd6,0xfd,0xfb,0xff,0xff,0xff
- 0xea,0xd5,0xea,0xd5,0xea,0xd5,0xea,0xd5,
- 0xfa,0xfd,0xfa,0xff,0xef,0xd7,0xef,0xff,
- 0xf0,0xed,0xdd,0xed,0xf0,0xff,0xff,0xdf,
- 0xdf,0xc0,0xdf,0xdf,0xff,0xff,0xc1,0xfe,
- 0xfe,0xfe,0xc1,0xff,0xff,0xc1,0xfe,0xf1,
- 0xfe,0xc1,0xff,0xff,0xe1,0xde,0xde,0xe1
- 0xc0,0xfb,0xfb,0xfb,0xc0,0xff,0xff,0xff,
- 0xff,0xff,0xde,0xed,0xf3,0xf3,0xed,0xde,
- 0xff,0xff,0xff,0xff,0xff,0xff,0xcf,0xf7,
- 0xf8,0xf7,0xcf,0xff,0xff,0xff,0xff,0xff
- 0xc0,0xde,0xd2,0xda,0xda,0xc2,0xfe,0xc0,
- 0xdf,0xd0,0xd6,0xd6,0xd2,0xde,0xc0,0xff,
- 0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0xfd,0xfb,
- 0xf7,0xef,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,
- 0xfd,0xfb,0xf7,0xef,0xdf,0xef,0xf7,0xfb,
- 0xfd,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xff
- void delay(uchar xms)
- char i,j;
- for(i=0;i for(j=0;j<50;j++);
- void main()
- init();
- num=read_dat(0x00,0x01);
- ++num;
- if(num>=11)
- num=1;
- erase_dat(0x00,0x01);
- write_dat(0x00,0x01,num);
- while(1)
- uchar i=0;
- for(i=0;i<32;i++)
- P3=tab[num-1][i];
- delay(100);
- void init()
- IAP_CONTR = EN_EPROM; //把第7位置1允许EEPROM可以读写
- IAP_CMD = S_MODE; //待机模式无ISP操作
- IAP_ADDRH = 0x00;
- IAP_ADDRL = 0x00;
- uchar E_dat = 0x00;
- IAP_CMD = R_MODE; //模式选择为读EEPROM
- IAP_ADDRH = addr_h;
- IAP_ADDRL = addr_l;
- IAP_TRIG = 0x5A; //使命令有效
- IAP_TRIG = 0xA5; //使命令有效
- E_dat = IAP_DATA;
- return E_dat;
