查看: 2305|回复: 13
DS18B20和步进电机为啥不会转呢?
回帖奖励 200 黑币 回复本帖可获得 10 黑币奖励! 每人限 1 次
ID:241873 发表于 2017-12-27 10:02 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uint        unsigned        int
#define        uchar        unsigned        char
#define Coil_A1 {A1=1;B1=0;C1=0;D1=0;}
#define Coil_B1 {A1=0;B1=1;C1=0;D1=0;}
#define Coil_C1 {A1=0;B1=0;C1=1;D1=0;}
#define Coil_D1 {A1=0;B1=0;C1=0;D1=1;}
#define Coil_AB1 {A1=1;B1=1;C1=0;D1=0;}
#define Coil_BC1 {A1=0;B1=1;C1=1;D1=0;}
#define Coil_CD1 {A1=0;B1=0;C1=1;D1=1;
#define Coil_DA1 {A1=1;B1=0;C1=0;D1=1;}
#define Coil_OFF {A1=0;B1=0;C1=0;D1=0;}
sbit DSPORT=P3^7;
sbit A1=P1^0;
sbit B1=P1^1;
sbit C1=P1^2;
sbit D1=P1^3;
uchar Speed;
void Delay1ms(uint y);
uint x;
for(y;y>0;y--)
   for(x=110;x>0;x--);
unsigned char Ds18b20Init()
        unsigned int i;
        DSPORT=0;
        i=70;
        while(i--);
        DSPORT=1;
        i=0;
        while(DSPORT)
                i++;
                if(i>5000)
                        return 0;
        return 1;
void Ds18b20WriteByte(unsigned char dat)
        unsigned int i,j;
        for(j=0;j<8;j++)
                DSPORT=0;
                i++;
                DSPORT=dat&0x01;
                i=6;
                while(i--);
                DSPORT=1;
                dat>>=1;
unsigned char Ds18b20ReadByte()
        unsigned char byte,bi;
        unsigned int i,j;
        for(j=8;j>0;j--)
                DSPORT=0;
                i++;
                DSPORT=1;
                i++;
                i++;
                bi=DSPORT;
                byte=(byte>>1)|(bi<<7);
                i=4;
                while(i--);
        return byte;
void  Ds18b20ChangTemp()
        Ds18b20Init();
        Delay1ms(1);
        Ds18b20WriteByte(0xcc);
        Ds18b20WriteByte(0x44);
void  Ds18b20ReadTempCom()
        Ds18b20Init();
        Delay1ms(1);
        Ds18b20WriteByte(0xbe);
int Ds18b20ReadTemp()
        int temp=0;
        unsigned char tmh,tml;
        Ds18b20ChangTemp();
        Ds18b20ReadTempCom();
        tml=Ds18b20ReadByte();
        tmh=Ds18b20ReadByte();
        temp=tmh;
        temp<<=8;
        temp|=tml;
        return temp;
void        main()
        unsigned int tp,j,i;
        tp=Ds18b20ReadTemp;
        Speed=2;
                if(tp>=20)
         Coil_A1
     Delay1ms(Speed);
     Coil_AB1
     Delay1ms(Speed);
         Coil_B1
      Delay1ms(Speed);
     Coil_BC1
       Delay1ms(Speed);
         Coil_C1
       Delay1ms(Speed);
     Coil_CD1
      Delay1ms(Speed);
         Coil_D1
      Delay1ms(Speed);
     Coil_DA1
     Delay1ms(Speed);
                        Coil_OFF;
                        for(i=0;i<10;i++)
                                for(j=0;j<60;j++)
                                        Delay1ms(1000);
ID:78322 发表于 2017-12-27 15:01 | 显示全部楼层
从程序看,你是采样的温度值大于20,就会启动马达,而且,你的温度只采样一次,如果一开始的值小于20,步进电机就不会动。
ID:84283 发表于 2017-12-27 15:27 | 显示全部楼层
ds18b20你没让它工作,导致tp接收不到。
ID:117053 发表于 2017-12-27 16:45 | 显示全部楼层
从程序上分析的话,会不会是因为你的温度没有达到要求,所以导致DS18B20和步进电机不转动。
ID:241873 发表于 2017-12-27 19:23 | 显示全部楼层
立里 发表于 2017-12-27 15:01
从程序看,你是采样的温度值大于20,就会启动马达,而且,你的温度只采样一次,如果一开始的值小于20,步进 ...
可以这样说 我想做的是温度大于这个就可以开始工作 不知道咋样修改 了 可以帮下忙吗
这个就尴尬了 有啥办法修改一下吗
ID:84283 发表于 2017-12-27 19:47 | 显示全部楼层
湮灭GG 发表于 2017-12-27 19:23
这个就尴尬了 有啥办法修改一下吗
把18B20 采集温度的函数放在while中,让它一直执行从而改变得到tp的数值,20摄氏度以上就转。
ID:84283 发表于 2017-12-27 19:49 | 显示全部楼层
这个就尴尬了 有啥办法修改一下吗
也就是这个函数 Ds18b20ReadTemp()
ID:241873 发表于 2017-12-28 10:10 | 显示全部楼层
尴尬了 我把这个放进去之后还是没反应。
ID:267813 发表于 2017-12-28 11:33 | 显示全部楼层
void        main()
        tp=Ds18b20ReadTemp;
        Speed=2;
tp=Ds18b20ReadTemp();
这个地方有点语法错误哈,否则你是根本没有采集温度,温度为0,步进电机当然不动啦
ID:267813 发表于 2017-12-28 11:35 | 显示全部楼层
改为:
        Speed=2;
再试试
ID:241873 发表于 2017-12-28 15:14 | 显示全部楼层
zzzxxxccc 发表于 2017-12-28 11:33
void        main()
这个需要咋样修改
ID:268407 发表于 2017-12-28 16:29 | 显示全部楼层
温度多高啊 ,温度没有达到要求。
ID:262845 发表于 2017-12-30 12:05 | 显示全部楼层
采集温度和驱动要控时序,交差驱动,不能同时控制。
